HowlerMonkey
  1. Stay away from any LT1 ecu that has the numbers 16159278 on it. These are for the 92 and 93 cars....possibly other years and the ecu itself experiences failure rates about 10 bizzillion times those of other LT1 ecus. Delco used a conformal coating on the boards that is applied as a liquid that hardens into a flexible coating. Sadly, the formulation of this coating tends to expand with age. This is not good because it expands under the suface mount components on the board like tree roots under a sidewalk and has been known to even pop large chips right off the board. Standard, blue streak, and a1 cardone have varying degrees of failure fixing these and I have personally spent many an hour using super secret chemicals to remove the coating without damaging the boards and components yet these ecus still have a super high rate of intermittence........even after resoldering most every component. It's best to go with a system from a later car.
  2. Any of you guys worked with trying to attenuate the noise between the block and the knock sensor so the valvetrain noise doesn't trigger it? I guess I need to do some capturing of the "sound" by various sensors and check the waveform under true knock and no knock conditions so maybe we can find out which sensor works best for the nissan L6. The problem with knock sensing is that different sensors have different outputs determined by the knock frequency of the application for which they are tailored. I just got done running 87 octane in a f54 with flattops and a p90 head with 8 pounds of boost (intercooled) and am finding no audible pings or knocks so it's possible my infiniti M30 ecu using a M30 knock sensor screwed into the f54 block knock sensor hole is actually working as it should........but I doubt it's optimum because I'm sure the vg30 sounds the sensor expects to hear are a little different in character. One of the perks of having a dead silent exhaust system is being able to actually hear what's going on with the engine.
  3. I use 1 1/4 inch long hex bolts that are of the correct thread and use a fender washer on between the chain and the block then I snug them up slightly beyond finger tight and pull away. Never use the factory bracket on the rearmost stud of the exhaust.........unless you just screwed in a new one only minutes earlier.
  4. Wow, that's really fast. I'm guessing windshield rake is mandated to be stock?
  5. The 240sx trans will not bolt in. But....people have swapped the front case of your 280zx trans. onto the 240sx trans. with a certain amount of work and resizing some things. Your best bet is if they have another one to give you and you might get one that had been reman. relatively recently.
  6. You could send it in to blue streak for R and R or use the critical core program where you get a functioning unit returned to you. http://www.bsecorp.com/products_remanufactured_services.php You would have to do it through an auto parts store or a shop that deals with them. Also....remember that the 280zx ecu is generally not compatible.
  7. Doesn't the swap require similar work as a bearing and synchro replacement?
  8. Bearings and a couple of synchros should quiet it up but definately look for gear damage as I suspect that a bearing has gone south and it's possible that bearing parts might have damaged other things.
  9. If you don't have spark, it's possible the ecu is not seeing a rpm signal from the distributor which will cause it to also not fire the injectors. Also......check whether you have +12v on one of the injector terminals when the key is on.
  10. Good question. I'm wondering where I can source a tank in either plastic or something without zinc for a future LD28 with turbo project.
  11. Thanks......would check these out but there are no ford diesel trucks that seem to make it to junkyards. I'll keep searching for the honda baro sensor or just weatherproof one from mouser.
  12. I use boat gas tanks and connectors........they type you use for outboards on smaller boats. You put a T fitting between the tank and the pump for the return line from the injection rail.
  13. Would a factory crank trigger setup be illegal?
  14. I'm looking for possible sources for one or two of these sensors I can pull from a junkyard and audition before dropping money on a new one. These sensors measure pressure altitude for the engine management and are not to be confused with a MAP sensor. These are 3 wire sensors that have no vacuum hose going to them.........they're just mounted wherever the manufacturer feels best. Many older nissans and other manufacturers have them mounted to the board of the ecu and I can source these from mouser or digikey but I'm looking for something a bit more weatherproof. Most of the posts on the web that come up in a search are people incorrectly referencing the map sensor.......which sometimes does the same job during initial key on but are far less sensitive than a standard baro. sensor. I see some hondas have them but have taken off many interior panels where the manual states they are located only to find nothing. I was wondering if anyone here knows another make that uses such a sensor?
  15. If the P79 is in good shape and has never been apart, leave the cam it has in it. I swapped a p79 for a p90 and back and have noticed no difference in performance at 8psi boost levels.
  16. Is the pressure line that leads to the wastegate actuator plumbed to the turbo housing (stock setup)? If so, the slight restriction in your intercooling system is the culprit. The pressure your wastegate is seeing when plumbed to the turbo housing is before the pressure drop through the intercooling system so it's probably operating as normal and the actuator is seeing and reacting to target boost levels but the pressure drop through the intercooler/piping is responsible for the boost you see at the intake manifold. To check this, run a gauge Tee'd in on the wastegate actuator hose and see what the turbo is seeing and compare it to what you are reading off the intake manifold. You could change the "boost reference source" from the turbo housings to after the restriction of the intercooler and piping and you should end up with more consistent boost control. One thing to consider before moving the wastegate pressure source......if your pressure drop across the intercooler/piping is too much and you're already running the turbos near thier limits, you could cause the turbos to overwork because they would be controlled by the pressure after the pressure drop. If you're nowhere near the limits of the turbos, you should be fine. All intercoolers introduce some restriction but some more than than others so this is a good time to see if your issue is caused by too much restriction. Of course....after writing this, I see tony covered it on an earlier thread. http://forums.hybridz.org/index.php/topic/100405-280zx-turbo-boost-issues/ When moving the wastegate signal to the intake manifold, keep in mind that an older actuator diaphragm might not be happy being fed near 30 inches or more of vacuum when decelerating since it has lived it's entire life never having seen anywhere near that vacuum level...........but....also discussed in that thread was a poppet type boost controller. These also have the benefit of acting as a one-way valve which should keep the wastegate from being sucked to death.
  17. +1 on the longshifter. Those short shifter guys have it all wrong. If you're using the FS5W71b, I do know that the "ears" that the shift lever pin go through are longer or shorter depending on the year. Lengthening the shifter will lengthen your shift throws (fine with me) but, if you want a shorter throw, you will need to have the pin higher relative to the trans. Some short shifter kits do this already. This ,may require lengthening the "ears", the shift lever below the pin, and whatever length you want to add up top. If you're going with a Z32 type trans, there are a few options but a "short throw shifter" (not just a short lever) for that trans. coupled with the longer lever should net you close to stock throw with the longer shift lever.
  18. If you're going through all this fabrication, might as well go to the r230.
  19. What's really amazing is how well the factory "J-tube" and "vacuum control valve" work. Sure, the air is damn hot but there is only a fraction of the pressure drop you find as compared to the average intercooler setup.
  20. Maybe it's aftermarket and designed to run with the cap normally used with the automatic setup? I'm reaching...because the cap would interfere with the input shaft.
  21. I know this is an old thread but none of the answers above is correct. This part is called the "vacuum control valve" but it's operation is different than it's name implies. In operation, it is a blow off valve which vents excess pressure between the turbo outlet and the throttle plate when the throttle is closed while under boost. Yes, it vents into the intake manifold runner. Because of the way this car manages conditions in which the injectors are on/off, shoving air from the J-pipe through this valve into the intake manifold has no ill effect because the injectors will be off during the condition in which this valve is open. If you are using a different ecu or injection scheme (or your tps is adjusted wrong), this valve's operation can cause it to hang rpms for a little bit because it's operation assumes the injectors are off when it is open. Another up side to this scheme is that all air metered is put through the engine rather than some metered air being vented to the atmosphere. It's actually a pretty brilliant scheme and likely responsible for stock 280zx turbos lasting longer than they would if the column of air would be allowed to "stack up" and spike in pressure when the throttle plate is closed. That said, it's capacity to flow is probably not enough when used alone with higher boost, added volume of pressurized air (intercooling system), or a larger turbo. If you're already running a blow off valve, removing this and/or plugging it should have zero effect
  22. The Mickey Thompson drag radials started having having belt shifting after 10 runs over 250mph, many runs over 200mph, and more than a few donuts. We started some inquiries with manufacturers a couple of years ago and a few prototypes have shown up but mum's the word at this point until a design is finalized and tested.
  23. No intercooler Stock M30 ecu with stock 280zx turbo injectors and dropping resistors. 19 degrees of initial timing 7 pounds of boost no intercooler 93 octane position #1 on the cam sprocket victor reinz head gasket stock m30 exhaust system with catalytic convertor in place.
