HowlerMonkey
  1. Injectors get constant power with the key on. The ecu delivers the negative signal. I've seen many nissan ecus fuse the injector driver and the zener diode when connecting the battery backwards.
  2. I'll check whether I still have one out of my 1984 maxima which I fit a r200 to. Have never shipped out something larger than an envelope so I need to check around on how it would best be shipped. Back in a day or so.
  3. I'm speaking from experience even though it was 24 years ago at the Z shop of miami.
  4. "A" cam will have zero negative effect on the stock ecu because the stock ecu is unbelievably non-exact.
  5. I was referencing the "increasing tension on the bolts" which will not happen since you won't be heating the flywheel without also heating the bolts.
  6. Take off the driver's kick panel and gently wiggle the wires that go into the ecu. Often only takes a light touch.
  7. The P79 "a" cam might be interesting in a p90 head.
  8. The bolts will get longer as they "expand".
  9. Because the L28 is rear sump and the maxima requires a front sump. You would have to modify the oil pickup and add a new dipstick for the front sump location. All that kind of jazz exists in this thread that shows some of the engine fitment issues of putting the L28 into a front sump car. http://forums.hybridz.org/index.php/topic/74589-l28et-into-infiniti-m30-begins/ The L24 in my car was in pristine condition and handled tire burning boost fine for 40,000 or more miles.
  10. Here.....let me bring it on topic. The L6 in this car (this is an L6 forum) is a L24. It doesn't possess enough power in stock form but I've turbocharged them using the 280zx turbo hardware on the L24 longblock. Pretty much the only non-stock things needed are to fabricate a downpipe from the 4 bolt flange back and to fit a turbo drain. The rest can come from the 280zx turbo donor car. Here's a thread with pics that might help. http://forums.hybridz.org/index.php/topic/74546-fs-1984-maxima-5-sp-turbo-l24e-west-palm-florida/
  11. Long time, no see Grumpy.....welcome back. I've found that getting a working drivetrain (or leaving one in that still runs) is a good motivator....even if the engine is just a placeholder. I've also done a quick sanding and getting paint right over blemishes and rust to get the car one color (and possibly preview your color choice) that kept me motivated. As long as you have made sure the surface is good for paint adhesion, you can fix the bad spots later and it's far better than a car sitting in primer.
  12. Sweet.....maybe better access to the GCRs will inspire more racers.
  13. I thought SCCA charges money for the GCRs.
  14. A 110 welder draws about twice the amps at the same settings as a 220 welder. This makes the circuit from the panel to the outlet you are using very important. I use a snap-on FM140 I picked up for 600 bucks in brand new condition. It's not a century welder but rather a CK systematics welder and has the biggest transformer I have ever seen in a 110 welder.........and I have welded until the torch is too hot to use. I believe the 100% duty cycle is not an empty boast with this unit......as long as it's plugged into a strong enough circuit.
  15. My bud build a few similar machines when he worked as a fabricator for mosler.
  16. Then it shouldn't be hard to produce a part number or a picture. The LD28 patrols were not turbo. The RD28 patrols were available with turbo.
  17. Yet nobody....even the guys in the New Zealand forums, have seen one that didn't have a modified L20et or L28et manifold.
  18. Then you can post the part number of the exhaust manifold so I can check it against my nissan diesel fiche.
  19. Pics? I've worked on many nissan forklifts and ordered parts for them and I don't remember seeing any turbos attached to LD28s either in real life or on the microfiche. The only LD28s with turbos I have seen were some marine conversions and a couple of conversions done for industrial pumps. As far as turbo choice? Mercedes runs a 45 trim T3 on a 3 liter 5 cylinder om617 engine. Many volvos and saabs used 45 trim T3s and I see them everywhere at the junkyards.
  20. What LD28 was offered with a turbo by the manufacturer?
  21. I used a recirculation valve picking up from right in front of the throttle body and ran that to the turbo inlet as described above. The car has a stock "vacuum control valve" that is enough for the small volume of boost in the stock J pipe but I added a recirc. valve when the intercooler went on since the volume of pressurized air is much higher. It's dead quiet unless you have the air cleaner top off.....then you can hear it working. Be careful choosing valves as some are pulled open by vacuum at idle and require that they are plumbed somewhere between the maf and the turbo inlet. If you run these valves with the dump open to the atmosphere, you will be pulling air through the valve and bypassing the maf.
  22. I've got the entire setup but am having second thoughts at swapping the LD28t for the current L28et in my Infiniti M30. I feel the setup needs a car with better aero than what I have so maybe a 240sx will have to do.
  23. I use a snap punch and all but one has come out over the years........so I used a regular punch on that one. I was at a party and some girl asked me to give her a ride home while claiming to love Z cars. Some wannabe suitor decided to hide my keys in an attempt to give her a ride home himself but I had a snap punch in the center console and further impressed her when I stripped the column cladding, quickly took off the lock, and drove off with her. Once the snap off bolts are out, you remove the switch from the back of the lock and use a screwdriver to start the car.
