SuperDan
Administrators
    15
Everything posted by SuperDan
  1. Hmmmm.... ~$1500.00 for Tomei pistons or ~$700.00 for a set of CP's.... tough choice.
  2. LOL!I want a T-shirt with that on it.
  3. Oh, another thing I read was that you need to use RB26 rod and main bearings, supposed to be a drop-in fit in the block.
  4. You would be boring up from 78mm (I think) to 82mm, that should cover it.
  5. Z Cars Rule is correct, the block will need to be clearenced a little. I was quoted $175 to hot tank, bore/hone and notch the bottom of the piston bores from my local machine shop. These guys have the correct 83mm head gasket and can get you the CP pistons made, they quoted me $700 -> http://www.jgycustoms.com/RB20DETparts.htm
  6. The default age display is allready set to "Show all threads".
  7. From what I understand the block just needs to be notched at the bottom of the piston bores to clear the rods, about 1-2 mm of metal needs to be removed. My machine shop dude quoted me ~$175.00 to hot tank, check, bore, hone and clearance the block.
  8. lets chat > http://forums.hybridz.org/chat/flashchat.php
  9. Shhhhh..... BTW, CP will make the pistons for $700.00, alot cheaper than the Tomie's $$$$$
  10. or... you cuss, swear and go to your local Nissan dealer, leave a depost for the special tool need to remove the damn thing. It's the same one they use for the VG30's
  11. An example of what you are searching for would help.
  12. Also, I have increased the maximum number of pics you can have in your garage from 10 to 30
  13. It's always somthing . Fixed
  14. Well, 50/50 is not bad The garage information converted just fine it seems but the Timeslip database had to be wiped out and re-installed fresh, oh well not bad I was more concered about the garage information since re-entering your timeslip information is pretty quick. You can add/edit your information by going to your user cp, on the left menu Vehicle Profile is for the Timeslip app and vBgarage is for your garage/car profile. Have fun. Dan
  15. Our server will be up and down tommorow while I re-install / upgrade our Timeslip database and Members garage software. After looking as the upgrade procedures I would say there is a > 90% chance that the current information stored in the database will transfer over intact. Yes, I am as excited as you all are Dan
  16. Thanks Matt, I was wondering if that was going to be my only option at this point Anyone have part #'s for the gear and the washer/belt guide behind it, I pretty much destroyed that a few days ago.
  17. Delete one of your private messages, does it go back to normal?
