inline6
    7
Everything posted by inline6
  1. Thought it was about time for a small update on this saga. I pulled the head off of the engine a while back so I could drill out the oil supply restrictor in the block to .125". With the head off, I found some odd wear on the bores. So, I sent the short block back to my engine builder to be disassembled, checked, and specifically for some touch up honing. We suspect the wear possibly came from running too rich during attempts to tune the carbs... and possibly bits of the metal from the cam problems causing some havoc. According to my engine builder, all crank journals, rod journals, respective bearings etc. were fine. The cylinder walls weren't perfect. So, we went ahead and honed it as planned. Short block is being reassembled now and will be on the way to me soon. I'll be pulling the oil galley plugs on the head and checking to be sure there is no debris or obstruction. Plan for restart includes: Red Line full synthetic oil - high zinc content Red line assembly lube on cam lobes Block heater to heat oil north of 100 degrees for startup Pressure oiling kit to blast oil through all oil galleys just before startup Rebello camshaft spray bar - replacing the factory oil spray bar Same induction set up - everything adjusted as prior, when engine last ran - assures quick initial start up With the oil restrictor now .125" instead of ~ .078" and no chance of any restriction (everything will be tripple checked), along with the list above, I think I will not have another repeat of this problem.
  2. I like the Jags that Run option. There is a nice write up showing what makes the radiator special here: http://www.jagsthatrun.com/V8-chapters/V8-DatsunZ-Cooling-System.pdf I think you would need the Rad ($185), the mounting kit ($80), and the DAT-128 kit which is for running hoses from the new rad to the L series engine instead of a V8. They would be able to confirm. http://www.jagsthatrun.com/Datsun_Order.html#anchor When I bought it years ago, the mounting brackets were galvanized steel. Now, it looks like they are aluminum, and come with electric fan straps too. I just happen to be looking at electric fans now, so maybe I'll upgrade to the aluminum kit. Also, just saw the Koyo radiator at the Koyo site: http://www.koyoradracing.com/news.asp?id=61 Looks nice and I like that it mounts to the stock location, but that thing is thick - and in the example car shown, there is no engine fan installed, stock or electric. Doesn't look like there is much room for a fan there to me. G
  3. BHJ is making me a new hub that is sized for my crank, which is a tad undersize. $300 and we'll be back in action.
  4. Yep. Learned that the hard way when I used the bolt and washer with a Euro damper many, many years ago. Never want to hear that death rattle coming from an L series again. G
  5. With my recent engine build, I used a Rebello BHJ crankshaft damper (a used one). The engine has about 600 miles on it and is apart for other reasons. At the time of build, the damper had some visible wear/markings on the ID of the hub, but we decided it was good enough still to use. Given the photos of the "damage" that happened within only about 600 miles of engine tuning, and what my engine builder said after removing it from the crankshaft: "Your harmonic damper now has only .0002 interference fit to the crank snout. .0005 is the accepted minimum on non "problematic", internally balanced engines. .0007-.0012 is preferred for most engines and .0015 is the maximum which requires careful chamfering of components and the use of E.P. grease for installation. I weighed your damper and it was about seven pounds total weight (bathroom scale). It might be of benefit to obtain a damper with an inertia ring with a higher weight (moment of inertia)." I am faced with making a decision. Either pursue getting a new hub for this damper, which I do not know is even possible at the moment. Or, buy a new one of the same part number from Rebello (It is the BHJ street version) Or, go with another brand, such as ATI. My engine is basically the same as a Rebello 3.0 L engine (but with an 88mm bore instead of 89mm which puts it at about 2.9 L instead) with a lightened and balanced crankshaft (only about 3-5 lbs lighter than a stock L28 crankshaft), and a 7800 max RPM Kinetic Sunbelt cam. I've read various posts in the forums regarding "tuning" of dampers. I'd like to understand this tuning better so I can make as informed of a purchase decision as possible for my specific application. I would appreciate any guidance. G
  6. I thought about that when I was posting. My car is also predominantly a track car, but I still drive it on the street every now and then. As with my other cars, I enjoy pulling to redline in first, shifting to second, then letting off. It's annoying when I can't enjoy that because of gear crunch. It won't be an issue at the track. Yeah, I am so like that.
  7. Man, that is a bummer. I've been hoping that this would take care of it once and for all. I hate the 1st to 2nd crunch. Any chance that you don't have the timing spot on? If that is right, then what is left to look at? Could the dog teeth be worn a bit too much on second gear?
  8. Oh! Totally makes sense that the seal will be pushed away from the shaft as any pressure pushes on it. Wow. Learned something today.
  9. Working on transmission a bit while my engine is back at the engine builder. It appears I have another transmission leakage issue. What I thought was oil leaking out the of the back of the engine (I thought past the rear main side seals) is almost certainly transmission fluid. This means I have leaks coming from both the back and now, the front transmission seals. The thought occurred to me... I am currently running Redline MT90 transmission fluid. This stuff certainly seems "thinner" than what I've typically run in the past. Is it too thin? One other issue is I may have the front transmission seal installed backwards. I tried looking at the 280ZX workshop manual to determine, but I wasn't able to tell conclusively. I see 2 shiny rings around the mainshaft where the seal rides... so this is confirming to me that the part of the seal that touches the mainshaft is in a different spot than some time prior. Here is a pic showing the front seal installed with a new front seal just sitting off to the side - reversed from the one installed. Not sure why it would be leaking though as it looks to me like the seal is still riding on a spot on the mainshaft that looks like it would work. That said, I still think I need to pull it out and flip it around. Can anyone confirm? [edit] - yeah... it is in backwards. Clearly, the spring side of the seal isn't supposed to be facing the outside of the transmission where dirt and stuff can get to it. I am still not convinced that flipping it around will stop the leak though as the lip of the seal appears to be riding squarely on the mainshaft surface that it should be - it is just offset to near the edge of that surface. So, I wonder if the MT-90 is too "thin"?
  10. Tiny bit of good news for me in such a long time with this car - the pump I got yesterday is the real LD pump. Same ground off markings and stick on Aisin label. The impeller was about 1/16th" smaller than 3".
  11. During the full rebuild, the press fit plugs were all removed and the oil galleries cleaned METICULOUSLY. Engine has to come out to have the freeze plug spikes (I forget what they are called) installed anyway. I guess I have no choice but to remove the head. Incidently, oil temp has a major impact on flow as seen by some vids another HybridZer sent me. My videos were with 10W30 redline at like 65 degrees.
  12. I took the oil pressure sender out and used that hole in the mail gallery for the tank supply location. I did not measure psi while operating it. I have a regulated air supply from my compressor that I set at 120 psi when I filled the tank. I also have a 60 psi air gauge. Just before doing the second video, I measured the pressure in the tank, and judged it to be about 80 psi by the amount the needle was past 60 psi. During the 20 minute run with fresh cam and freshly re-ground rockers I saw 70 psi coming from the oil pressure gauge - this being read from the oil pressure sender which was in the stock (and same) location in the block. I have no idea what oil pressure the head is seeing. I might be able to remove the npt fitting at the back of the cam (I had one installed there instead of a press fit plug) and rig some kind of pressure gauge there to see what I've got for oil pressure inside the cam. Would that be helpful? Does anyone have a good number for me to compare to? I can regulate the tank pressure to 70 psi or whatever and then get a number for pressure at the cam...
  13. Finally got moved and had a chance to hook up a pressure kit. I put a quart or so into the small tank and pressurized the tank to 120 psi. Didn't take the best video footage on the first one. Second one was much better. With the second video, I had an estimated 80 psi left in the tank. The spray bar is clearly useless. Take a look: Video 1: http://www.youtube.com/watch?v=rXAo8S7Wetc Video 2: http://www.youtube.com/watch?v=sFZM4P1Dfqo So... Is that enough flow?
  14. Some got the right one from them it seems from the activity in the last few weeks. We'll see if the one I get is right or wrong. That they wouldn't or couldn't measure means that can't confirm the statement that they don't have the right pump for you. I mean, how do they know for sure if they didn't look at or measure them?
  15. I just did a search for WPN-079 on RA's site and it brought up two listings - first the valeo and second an application of 81 Datsun 810 and 82-83 Maxima only - look at the second listing, not the first one. Manufacturer listed is AISIN. Part numbers listed match the box that is pictured about page 3 (I think by Dreco) in this thread - a confirmed correct pump. I only bought one - there are three left. I'll let people know what comes, though by then, I doubt there will be any left.
  16. Aaah! I have been moving for the last week or so and haven't been watching the forums.
  17. I had to pay $100 just to have the rear of the new cam drilled/tapped for an NPT plug which I did before assembly this second time around. Front is sealed by the cam gear bolt of course. I'm in the middle of moving this weekend, so I can't do much with the car at the moment. Rocker arms have been removed but the cam is still in the engine. I am on the lookout for the pressure outfit my builder is sending me. Garrett
  18. Rockers: All: 1 and 2: 3 and 4: 5 and 6: 7 and 8: 9 and 10: 11 and 12:
  19. No, I have not visually checked to see if oil is getting to every lobe. I was/am scared to death to turn it over at cranking speed to test that... And I don't think turning the oil pump shaft at power drill speed is sufficiently fast enough to observe (accurately) oil flow from the spray bar... My engine builder is sending me his pressurizing outfit, so I can hook it up to the block and check oil flow without cranking. Ya know... another thing... my valve springs are running 56 lbs pressure at installed height, so it's not like I have this excessive valve spring load I am dealing with. Within a few seconds of starting the oil pressure gauge showed just north of 70 psi (yes, I know, this is at the block main passage) and stayed pretty much right there for the full 20 minutes (maybe dropped 2-4 psi as oil got warm). Ran it at 2500 RPM only! For F sake.
  20. Ok. Cam number two is "effed". This is not fun people. Various cam lobes: The rocker with the most damage: And a close up: At this point, I think running both internally oiled and spray bar is complete SHITE. Clearly there is not enough oil getting to this cam.
  21. Fired up the engine tonight with the new cam in it. I ran it at 2500 RPM for 20 minutes and shut it off. This time around, I have a chill cast Estas blank, ground with the same master Integral Cams used to make the first cam, but there has been no nitride treatment. I used redline assembly lube on the lobes and main journals. And instead of using Mobil 1, I am using Redline racing oil. Was a $100 for two gallons delivered, and the comp pan took it all. Of course, since the engine has run before, and carbs are adjusted, etc. I got initial fire up after two very brief turns of the starter. I confirmed with my engine builder that the oil restrictor supplying oil to my cylinder head remains unmodified. I didn't know that the hole should be enlarged for my application. Not doing that until the head comes off for freshening. I have the stock spray bar for now in addition to the internal oiling of the cam. I'd like to get either the billet one from LarryZ or maybe the Rebello one. Fingers crossed that I don't have a problem with the cam or rockers this time.
  22. So Tony, what is the scoop on running internally oiled cams along in conjunction with the stock sway bar - one has to drill the restrictor in the supply from the block to that head or not? I have seen you comment in another thread (Post 15) that this should be done when running both an internally oiled cam with the stock external spray bar. If there isn't a definitive word, then how about a recommendation? Or a guess? My engine's bottom end is fresh with correct bearing clearances. I want to say 2.5 thou, but I'm being lazy by not looking at my build specs right now. By the way, I've been trying to get my hands on the billet spray bar from LarryRacer240Z, but it has been half a year and still none have been manufactured by his supplier. Maybe for my 50th birthday (in six years) i'll get one.
  23. Was reading the forums about running both internal oiling and the stock cam spray bar and I see that there is discussion about opening up the restrictor in the top of the block to .100" as well as running the turbo oil pump. I am running the pump, but I think the restrictor is stock sized. Could that be part of my problem? I am just now installing a replacement cam... and don't want to fire it up only to experience the same problem. Other things I will be changing is, I am running Redline Racing oil instead of Mobile One. This was per the recommendation of Megacycle Cams. Garrett
  24. Thanks for the input. Very good sucking sound coming from the top of the trans when I drained the oil to remove the rear extension. Oil came out very smoothly. So, air vent is open. Inspected the periphery of the oil seal machined cut-out. A couple of very minor nicks, but otherwise looks good. Must be something else.
  25. I took the rear housing off of the trans and pressed the old bushing out. Upon close examination, it isn't bad at all. In fact, the ID on it is tighter than the new one. I used some 2500 grit sandpaper to clean it up a tad. It actually fits more tightly on the yoke sleeve than the new ones. Since it is longer, and obviously in ok condition, I put it back in instead of the new one. Now, I am back to square one. I don't know why I have this rear oil seal leak. Was it my imagination that I saw lots of deflection when pushing on the yoke of the driveshaft while it was in the car? The bushing obviously limits deflection... The stock driveshaft yoke sleeve measures 1.475 OD. The Inland Impire Driveline yoke sleeve measures 1.476 OD. The new bushing measures 1.482 ID... The stock bushing is probably a few thousandths smaller ID... I dunno. The main shift rod, that I replaced the o-ring and little oil seal on before, is perfectly dry. Absolutely no leakage there. I took the rear oil seal from the spare transmission and slid it onto the yoke sleeve. It actually fits a bit tighter than the relatively new oil seal that was on the trans in the car. So, I'll throw that one away and buy another new one from Nissan. But, I've replaced that with a new OEM one before... and still had the leak. I suspect another new one won't change anything. Pretty stumped. I hate fluid leaks.
