29
Everything posted by jhm
@Mr.Roboto, FYI -- tried several times, and am unable to open the image(s); and it doesn't seem to be a working link either. If others are having the same issue, you'll probably need to reload. If you want to message me the image(s), I can try loading from my end. Your call...
Wow...she's looking great, Ben! Nice rebuild after that off at GTA a while back.
Anyone ever used Gyraline DIY alignment tool?
jhm replied to kaibiagi's topic in Brakes, Wheels, Suspension and Chassis
Ditto. I think the major tech hurdle is the smart phone's gyro, directional and positional accuracy, which likely just isn't there yet to enable the measurement of tenths of degrees. Maybe @Sam Henao would like to chime in with test/user/anecdotal/etc data? This would be such an awesome capability if it worked as advertised. -
Wow! Welcome, and kudos to you for taking on this level of project...it will be extremely rewarding to see it coming back to life. You might want to check out ClassicZCars.com, as well -- they have a very big restoration community there. As an example, check out this thread to see some really nice custom structural metal work: https://www.classiczcars.com/forums/topic/61483-240z-fabbing-new-front-rails/. There are a couple of good vendors for replacement body panels, or you can fabricate your own. https://www.baddogparts.com/store/ https://kfvintagejdm.com/ https://www.facebook.com/DatsunRescue (Adam Sylvester is a genius at locating those impossible-to-find used parts for very reasonable prices). If you're not hung up on this project being a "restoration" (vs resto-mod), that'll free up all kinds of options for you. Example: rather than replacing that half-dash with an expensive, hard-to-find original dash; build your own custom aluminum dash. Looking forward to seeing this beauty come back to life. Cheers!
jhm replied to FastFloridian's topic in S30 Series - 240z, 260z, 280z
Nice pieces, and great progress! -
Welcome to the forum -- glad to have you join us! (What took you so long to join?? 😜) Nice job on the 240, and documenting the build. It looked a lot like my 260 did, when I dragged it out of a field 8 years ago not too far from you (Black Mtn). Looking forward to seeing the progress on the RB-swap. As you probably already know, there are some great track events nearby in VA and NC.
Hey guys....not pointing any fingers, but I would like to remind everyone to keep the discussion civil per our Forum Rules (#12 & 13, specifically). We're all on the same team here. Thanks very much.
@Pfunk63, did you get what you need and is your account working correctly for you now?
Done! (I think.) Give it a try and let me know if it works for you now.
Welcome back! Looking at your account info, I see the following message: "Account locked from logging in using this IP address until 01/24/25 10:28 AM following 3 unsuccessful login attempts." So we have a couple options. 1) You can try logging in after the requisite wait time. (You may have to use the "Forgot Password" process, if you don't remember your old password.) 2) I can "merge" your old account with your new account; which should give you full access/control of both accounts. I'm not sure, but I think it may default to your new username; but you may also have the option of renaming it to whatever you want. 3) Now that your new account is approved, you can access and view all your old posts & photos....correct? Does that suffice? Let me know how you'd like to proceed. Cheers!
First off, welcome to the forum. While the purpose of this site is to discuss technical topics that pertain to the modification of the Datsun/Nissan Z cars (240Z, 260Z, 280Z, 300ZX, 350Z), we welcome car enthusiasts of all brands and manufacture. While you are perusing the forum, please take a few moments to familiarize yourself with forum Rules and Guidelines, found here: https://forums.hybridz.org/topic/111201-hybridz-forum-rules-read-now-before-posting/ Second, you are posting to a discussion thread that hasn't been active for over 20 years. Rather than "necroposting" on a 20-year old discussion thread, it may be more useful/productive to begin a new discussion thread for your specific/current issue. Finally, you may have more luck with your specific/current issue on a forum for Mazda cars or Mazda CX-5s. There seem to be a plethora of those -- a quick Google search yielded the following results: https://www.mazdaforum.com/forum/mazda-cx-5-54/ https://mazdas247.com/forum/categories/mazda-cx-5-forum.549/ https://www.cx5forum.com/ https://www.cx50forums.com/threads/cx-5-forum-all-new-forum.1407/ Not trying to discourage you from HybridZ; but any of these Mazda forums would probably yield more fruitful results in resolving your CX-5 technical issues and problems vs a forum dedicated to the Datsun Z sports car.
Battery Not Charging After Lights Being Left On
jhm replied to 268Z's topic in S30 Series - 240z, 260z, 280z
Just curious....what voltage levels do you have on the system when the engine is running? (And you may need to take readings at multiple points in the system to help narrow down where the problem(s) is/are.) -
Chassis stiffening always a good thing. Here's a link to some good ideas, if you're looking for additional inspiration. https://imgur.com/a/chassis-stiffening-inspiration-R27sh -
This might be helpful. Also, there are a couple vendors left that produce the rear inner axles necessary for a Subie R180 swap...but they have been drying up the last few years. Regarding backlash...that seems to be a forever issue with the R180. I've had significant play in every R180 I've owned, both open and LSD versions.
Did you use a different lower transmission mount when you swapped the automatic to T5; and if so, did it change the overall angle at which the engine/transmission sits? This could possibly make any components "forward" of the engine mounts sit higher in the engine compartment (relative to their original position). Can't think of any other reason why you'd have clearance issues now, vs no issues before the swap.
@Sandy455, glad to see you found what you needed. As a "Member", I'm not sure if you have the ability to Delete a post. Do you see a symbol (3 dots) in the upper right corner of your posts? If so, the drop-down menu should give you the options to "Edit", "Hide", "Delete", etc. If that doesn't work for you, I can "Hide" or "Delete" your post for you; but honestly, you may just want to leave it. Folks often refer back to old posts for reference or historical context. (e.g. Someone else in similar situation as you sees that @jeffer949 and @calZ have an N42 that they might be willing to part with.) LMK how you'd like to proceed.
Welcome to the forum....glad to have you!! Wow, Apex Track Attack package -- you're obviously not afraid to drop some $ into this project. Looking forward to seeing how you like the results once it's finished. For the widebody kit, are you looking at ZTrix? John Washington, long-time member here, builds top-quality pieces and complete kits. This is his IMSA widebody kit: https://www.ztrix.com/fender-kits/imsa Cheers!!
When analyzing the wiring diagrams, pay attention to plug type and wire color (wire color *may* be off from year to year due to factory production considerations, but IME it's usually correct). If your car's a '71, those plugs are probably things like Choke Warning Light, Radio, Power Antenna, etc. Also, be mindful that the wiring for Automatics is different than for Manual Transmission. Welcome to the Forum!
The factory wiring varies from year to year, and model to model. What year and model S30 is your car? A Factory Service Manual (FSM) is invaluable; and they contain detailed wiring diagrams for the entire vehicle. If you don't yet have an FSM, you can download them free for all years at: https://www.xenonzcar.com/s30/fsm.html
Hey @fusion, I had similar issue last time I replaced my hatch weatherstripping. I did not do anything special in that area, and it hasn't been an issue since. The seal just conformed to fit over time...the seal 'bulb' looks like it's squashed a little thinner in that area. The hatch closes fine, and I haven't had any leaks (it's been several years). At the time, I think I used generic weatherstripping from Pep Boys; so maybe it's a different overall thickness than the Kia weatherstripping? Mine appears very similar to your pics, but I don't remember it causing any difficulty in closing the hatch. Sorry -- probably not much help to you.
Wow! That is INSANE, if it works as advertised. It has the potential to really speed up suspension and steering adjustments if so. Did some googling, and could only find manufacturer ads...it would be nice to see some real-world results. If I understand the literature correctly, the utility (and accuracy) of the device lies within the app for your phone. So when you purchase the "device" (just a plastic holder for your phone), you're also purchasing the app. Is that your understanding of it also, @kaibiagi? Thanks for posting this up!! -
Thanks for that! I used a Cal-Style gasket from VR on my windshield years ago, and have been happy with it -- fits pretty well, not overly-difficult to install, and no leaks. At the time, Vintage Rubber was the only vendor I could find with trimless Cal-Style gaskets in stock. It'd be nice if there were other vendors out there to choose from.
