proxlamus©
Everything posted by proxlamus©
  1. hey your in colorado.. cool! where ya live in CO?
  2. Miata's = amazing.. best car i have ever driven.. if only they had more power... but handeling wise.. its a dream even stock and MPG! man oh man!
  3. installing a throwout bearing backwards installing brakes upside down with the bleeder on the bottom forgetting to ground an HEI module putting in the dizzy shaft 180 degrees off
  4. Ok.. buy those Sportmax 16x8 002 wheels and your ride would be effn SIICCKKK!!!
  5. nice work on those coil overs... no way Alex did that.. haha j/k
  6. weight = slow but this is awsome man! thanks for sharing the pics!! I wanted to do this soo bad with the Z.. but I didnt want some Subaru STi roll up at a stop light and smash me
  7. Phil this is like my issue with the HEI.. something SOOO simple and soo stupid and un thought of is always the problem... garsh.. good work though!!
  8. it's a DSM (Eclipse) BOV.. they have a stock setting of what... 10-14psi?! you need to CRUSH the top to allow more boost or it will leak.. unfortunatly the puppy is too tight now .. and you are having compressor surge.. but damn I love that noise
  9. now that looks very very very well done!! Good work my man! I was nervous about the old ones after seeing others comments
  10. no.. the command valve adjusts the variable vain technology if I recall. but I dont know for sure.. worth a shot to do some research
  11. Walk through on how it works.. pictures and install. http://forums.turbobricks.com/showthread.php?p=925829 Basically its a small "relay" with 3 wires... and it uses a fast acting valve. (boost control "kit") http://www.sparkandfuel.com/catalog/product_info.php?cPath=34&products_id=39 and ofcourse.. the MegaManual for the boost controller and how to tune http://www.msextra.com/manuals/MS_Extra_Hardware_Manual.htm#boost I am buying the parts this week =) Ohh.. btw it is tuned using a TPS and RPM map.. so yes you can have 5 psi all the time below 3/4 throttle then have 20psi at full throttle or have 10psi till 3,800rpm then kick in to 20psi.. help launch the car or lower the boost at high RPM's to prevent detonation
  12. yeh it was a bad HEI unit.. and I forgot to ground the base of the new HEI unit.. yes it had a ground wire, but I guess the base of the HEI needs to be grounded too! Let me find you a link for the boost control stuff... http://forums.turbobricks.com/showthread.php?p=925829 Walk through on how it works.. and install. Basically its a small "relay" with 3 wires... and it uses a fast acting valve. (boost control "kit") http://www.sparkandfuel.com/catalog/product_info.php?cPath=34&products_id=39 and ofcourse.. the MegaManual for the boost controller and how to tune http://www.msextra.com/manuals/MS_Extra_Hardware_Manual.htm#boost
  13. Nice!! Phil why didnt you try the Megasquirt Boost Controller?! its costs $24 and it uses a boost map.. so depending on RPM you can select how much boost you want to run.
  14. How about Megasquirt for PSP! (playstation portable)
  15. the most expensive thing on that order is the Innovate Wideband setup LoL
  16. umm.. 400rwhp with a zx 5 speed?! uh oh Z32 time
  17. From DIYautotune.com RadioShack link for 470ohm 1k resistors
  18. um.. boost by 2,300-2,500 RPM?! with a HY35w??! what the thats not right.. in what gear?! My boost comes in around 3,100 rpm in 4th gear... but full boost by 3,800 RPM.. please share your fuel/spark maps.. because Holy crap I want that
  19. on this note.. I am trying to hook up the Innovate LC1 to the Megasquirt unit... If i hook up the wiring directly MS reads the proper AFR according to my guage.. but I am supposed to install an in-line 1/4watt 1k resistor?! Well with the resistor inline.. Its all screwy and the readings are WAY off ** EDIT - ahh.. i need a 1/4 watt 470 ohm! not 1k!
  20. they are steel! cool... they look stainless from the pics! =) thanks roost
  21. are the bad dog frame rails stainless steel?! any problems welding these rails to the steel underbody using a mig?! If it is stainless do I have to use gas? or can I use a stainless wire flux?!
  22. you need to configure 1) Innovate to give out a 0-5v signal 2) megasquirt to read a 0-5v signal I told you megasquirt tuned is a whole new car.. its incredible
  23. Welcome http://forums.hybridz.org/showthread.php?t=84860 this will answer all of your questions
