DuffyMahoney
Donating Members-
14
Everything posted by DuffyMahoney
I fit all of that stuff under the car. Wasn't too hard and looks nice. Just FYI.
Built a passenger kick plate out of aluminum. I will powder coat it to match my stock one (sort of darker matchbox )This ecu location is about the best location I can find.
Mine seem fine, but driving will tell, I have a few adjustments on each section of the intake linkage.
I am going to leave that port stock. I just tapped my intake to NPT.
I think the average Z guy thinks I am nuts doing these mods to my low miles series 1:) So far not a single hole or permanent thing has been done to my car though. Thanks!
Efi Fuel system is in and wired. Happy with how it turned out. ITB here i come. All pushlock. I might switch some of it out to 5/16 from -6 braided. The braided seems a little large and out of place.
I got my platinum racing r35 harness installed on my r35 coils. Pretty happy with how it looks. I might shorten the last 3 wires an 1/8th of an inch.
Vac line is done. I am happy with the looks. I asked the company to make me a nicer booster fitting. We shall see.
I got my Jeep cas back from the machine shop. It’s nice and tight on the keyed shaft. Should work perfectly. I used the original dizzy collar as well.
I own a set of Jenvy 45 ITBs and I wouldn't say there were well made at all. Pretty thin material, casting doesn't look that nice. Butterflies seem cheap. No cap on the shaft without the throttle arm. I didn't pick the OERs just because of how the fuel rail looks. I think it looks odd.
Yes
I have a K r180 with a osgiken LSD and 4.11. So no Subaru parts:)
I own a vintage FET. It’s setup for 40 carbs. I love my SK. I will figure it out.
I have a 100 micron pre and 10 post filter. I made some mounts for them. But I’m having issues fitting both. I might just got cheap clear 100 micron inline pre filter.
I re tappped my intake. I’m not going to mess with the jenvys
Was the oer 1/8 hose barb?
Your setup looks very nice and well thought out. My idea will look great when I’m done. It will take some effort. I want all braided lines. Even the aluminum tube between the ITBs will have a faux braided line over them. The whole fuel system is braided push lock AN fittings. King of a mix of old and new. I don’t want push lock fittings. Not my style.
I am so glad I didn't do the vac log on the ITBs. So I am going to attempt to re tap my BSPT threads to NPT (I have had great success with it actually) Then use these. https://www.universalpowerconversion.com/miniature-male-branch-tee-hose-barb-brass-p-3356.html https://www.universalpowerconversion.com/miniature-male-branch-tee-hose-barb-brass-p-3368.html So the runners will all have a 1/8 NPT by 1/8 Hose barb T. That way I can connect to a map sensor and also the FPR. Then on the runner with 1/4 NPT, I will use the 1/4 NPT by 1/8 hose barb, then tap it for a 1/8 NPT by 3/8 Hose barb (3/8 will go to the brake booster). Then I have nice braided vacuum hoses to make the balance tube/ vac log. Should look good and solve all my issues.
My intake only can do 5 of the 6 runners. So I need to figure it out. They told me these would work. I will pull mine off tomorrow and look it more. https://www.universalpowerconversion.com/miniature-male-branch-tee-hose-barb-brass-p-3422.html
I asked some more questions. Here is the original email. Maybe IAC can handle the idle and allow me vacuum?
Man that sucks. Jenvy is the one that said to use it for a vacuum port. I will find the email
