Invincibleextremes
    18
Invincibleextremes last won the day on January 21
Invincibleextremes had the most liked content!
3 Followers
Contact Methods
  • Website URL
    http://Www.youtube.com/invincibleextremes
  • Location
    Usa
Recent Profile Visitors
11863 profile views
Invincibleextremes's Achievements
Explorer
Explorer (4/14)
  • Dedicated Rare
  • First Post Rare
  • Collaborator Rare
  • Week One Done
  • One Month Later
Recent Badges
26
  1. 2016 camaro front struts from Strange were adapted to fit Justin Gilberts 1,xxxx hp build for maximum adjustment 2 way.
  2. Unless somebody has a faster timeslip, fastest IRS s30 (barely) so far is Terry Garmon with 8.42 @ 166 mph in the 1/4 mile. Also included is a picture of Rick dunns 700hp car with the newest version of the rear swap, and a picture of all the components laid out, including the axles. The setup has evolved over the years, but even the earliest versions are out there putting down thousands of miles with all kinds of high and medium hp levels.
  3. while I don't post often, I DO recieve notifications from my threads, so I'm not hard to find and contact. facebook and Instagram are the easiest way.
  4. The arms that are currently part of the complete setup come fully boxed for extreme hp applications and have a half inch spacer that you either leave behind the spindle for stock wheel placement, or place in front of spindle to move the wheel back. If you choose to move the spindle, you must also move the strut top as well so it doesn't bind. so far the best 1/4 mile time on this setup is 8.5 @ 163 and it doesn't skip a beat.
  5. Weld in plate to get the max caster and bring strength back to the shock tower. The reason for the needed caster mod, is the mustang spindles have an offset bearing, and were designed for 8 degrees of caster in general. Proper wheel placement in a Datsun s30 requires the offset balljoint and shock top. David in the dark blue car just cut his front fenders instead, and kept his ball joint in the normal location.
  6. new front bolt on control arms available that make the 2014 mustang spindle swap a bolt on deal. green car also has baer brakes and he really likes them. the suspension picture isn't of the new arms, but is of the spindle swap in general. This particular car has modded stock arms. faded red car has the front spindle swap and the rear 2015 mustang hub and diff swap too.
  7. 175 mph back to back Class wins for Davids Blue 260z with a 434ci LSX running a half mile event. Terry's green car has over 1,000whp but turned down for pump gas it pulled a 1.3 60ft on a 6.0 @ 118 run for the 1/8 mile. his best so far has been 9.3 @ 150 mph in the 1/4 mile and 5.9 @ 126 in the 1/8.
  8. There's an optional piece now that replaces the mustache bar and rear drop downs and drastically strengthens the rear of the car and completely illuminates the toe issues these cars sometimes come with from the factory. The newest version of the mustache replacement is lighter and has more provisions for fuel line routing. It ties in the mustache bar anchor points with the 4 drop down bolts, making the entire back of the car incredibly strong, while still having proper isolation in the rear differential mount for the cradle via common aftermarket mustang bushings.
  9. David hit 171 mph repeatedly in the half mile event recently and looked darn good doing it. He also spent the weekend kicking butt at ls fest proving once again the absolute reliability of the super 8.8 setup. His lsx 434 hit a best of 10.3 @ 141 mph with a DA of over 4000 and him using a 100 shot.
  10. This is the sister thread to the rear diff swap thread. More people do the diff swap than the front actually, and many do all 4 corners. Thread for the rear is in the drivetrain forum.
  11. Good news is by the time you decide, you will hopefully have seen my own rusty pile on the road, or at least more and more super 8.8 swapped projects out and about this coming show season.
  12. Stock smallest is the v6 2005 brakes, they are 11.5 and comfortably fit 16 inch wheels, and struggle with 15s. There are aftermarket 2005 to 2014 front brakes by wilwood and others that are 4 piston calipers and are specifically designed for 15 inch wheels. At that point, you still benefit from the taller balljoint, the Ackerman, and camber at the hub adjustment, but aren't saving much money, because s197 aftermarket brakes aren't 200 dollars like the factory refurbished ones are.
  13. Definitely agree with using the biscuit style and then squeezing some caster out of it as well. You won't need much camber on the street, and that's where the caster really helps you out. Maybe a hassle to adjust, but you won't have to cut, so thats your only option unless you want to change your track width on those kinds of adjustments.
