510sr20det
Everything posted by 510sr20det
I need both side front struts for 240z 2" dia for MY car . do not need springs, hats or inners, just bare struts. call Mack @ 951-704-4142
what shape and price?? can you send pictures?? got several that we cracked or warped badly.
EGR smog tube on the back of the back and 02 sensor on front center, trying for an actual smog able car.
got one thanks everyone for the help.
Still looking for a good 79-83 L28 non-turbo exhaust manifold. Need to be in very good shape no cracks or warped #1 and #6 runners. Will to pay a fair price. Mack 951-704-414two or sales@mckinneymotorsports.com
NEED a EGR tube so we can get a customers car to pass smog. If we can not get it passed may have to scrap it or send out of state. Has owned car since new wants to keep it. NA car. Mack @ McKinney Motorsports
McKinney Engine & Gearbox Mount Alignment Issues?
510sr20det replied to NylonAdmiral's topic in Nissan RB Forum
trans crossmember for 1973 (late ) to 74 , 75, 76-78 style crossmember. there are several different sizes based on year and if floor pan has cat spacing. -
0n late 1973 and later the stock body bracket must be cut out to provide clearance for the trans. see attached pictures. -
280z Full Restomod with custom body kit & RB26
510sr20det replied to redlinevo7's topic in Nissan RB Forum
Really NICE car ' Mack@McKinney- 110 replies
- 280z
- restoration
(and 8 more)
Tagged with:
RB26dett transmission HELP! & 32 vs 33 engine
510sr20det replied to brianZortiz's topic in Nissan RB Forum
Call us we will try to help you.. Mack @McKinney Motorsports 951-304-9300 leave MSG if we can not answer. -
note 2 says single cylinder operation
I need an exhaust manifold for a 1982 L28 NA motor with down pipe if possible, just flange ok.. Mack 951-704 414two
I need a stock 280z exhaust manifold and down pipe. so the car will pass smog. Must be in good shape. call me at 951-304-930zero or cell 951-704-414two
any progress
No Power to Half of Each Injector
510sr20det replied to taaron's topic in S30 Series - 240z, 260z, 280z
the second side is GROUND from the computer to complete the circuit. -
They used many of our SR20DET swap parts with a Wiring Specialties harness. Mack
I have one that pretty rust free. not sure its suited for complete stock, very good for more swap restomod car.. Mckinney coil overs installed and motor swap kit of your choice.. $5800.00 firm.. Mack 951-704-4142 leave # will call you back if interested..
- 1 reply
- 280z shell
- 280z
(and 1 more)
Tagged with:
350z speed sensor physical location (not the wire)
510sr20det replied to 69sroadster's topic in Z33 Series - 350Z
GPS most simple. can use ABS but more work.. -
We are looking for a 280ZX for a shop MULE to build swap kits for the car. Need a cheap/free/loaner car that has a straight frame. body and interior don't matter. These kit do not require much cutting so loaner OK and a FREE kit of your choice... takes about 8-12 months for them all.. Call or email Mack McKinney @McKinney Motorsports
will not work.... all parts of a kit work together cannot mix and match. Use the CX trans cross member and mount..
It takes 3 thing to make a motor run AIR, spark and fuel. If you have all 3 it should run. so one is missing.. Have injectors been cleaned?? WE find on used JDM motors usually 1 to half of them clogged, dripping so that could be it.. New plugs??? if you have access to CONSULT have a balance test done.
there are 2 RB26 AWD 240z in Japan. Motor must be moved forward for alinement of axles. a ton of work for little or no real gain... Great for showing off your work..
wiring specialities 12v wire goes directly to fuel pump 12v side bypassing stock relay..
You need an aftermarket fuel pump like a WB 255 /450. the stock pump will not cover a boosted RB25 motor safely .
