MikeBZ
Everything posted by MikeBZ
  1. Had lots of slop in my clutch pedal, I thought maybe the return spring had broke but it was the clevis pin that connects the pedal arm to the clutch master cylinder...... How many more shifts do you think I had..... Check yours! And the brake pin.
  2. It's been covered a lot, But you'll need a drive shaft from a 280z that originally came with a R200 diff. Typically 75-78 5speed 280z's I dont know what car the R200 you already swapped in came from, but you can also pull the drive shaft input flange from the diff of the 280z you get the drive shaft out of. You'll need a puller to remove the flange from the diff
  3. Found 2 pics of a Z with these wheels.
  4. I'm sure you've already pulled the distributor and set the oil pump shaft to the proper position with the engine at TDC. If you still cant turn the Dist enough to get the proper timing, the timing marks on the pulley may be off, or the cam gear was not positioned correctly when the timing chain was installed ? I'd pull the distributor, pull the valve cover, ensure you are at TDC and verify the timing marks on the pulley, and start fresh setting the timing ?
  5. Also make sure the fans are setup up correctly, I once had a fan on the engine side of the radiator thinking it came setup as a "puller". When in fact it was setup as a pusher. The fan was fighting the natural air flow when the car was moving,..
  6. 70-78 Drums interchange. Get which ever one they have in stock. You can adjust for the 1/16 of an inch.
  7. Saw these and thought they might look pretty cool. They're on eBay in silver and chromium black in 15x8 0 offset I saw this post- http://forums.hybridz.org/index.php?/topic/71395-rota-grid-drift-wheels/page__p__827050__hl__Chromium%20Black__fromsearch__1entry827050 Anyone have a pic of what they look like on a 240z
  8. 81 ZXT in stockton CA (not my ad), Good for a swap if the price was right http://stockton.craigslist.org/cto/1630814004.html i have a 81 280zx trubo car dat neads tags 3 years back and it neads a battery 2 start and the car has abouth 168,xxx miles 2seter t top and authomatice car... ask for smily 513 2604... i wode trad 4 a 300z 90 and up 5speed 2plus2 only or a 89 and up 5.0 mutang 5speed hard top....tank u Location: e.stockton
  9. I saw a 82 Diesel Maxima station wagon at the pick n pull in rocklin CA. Saturday 3/13 If anyone has the time and need for the Crank shaft..
  10. These ? http://www.autozone.com/autozone/catalog/parts/partsShelf.jsp?displayName=Fuel+Injector&currentPage=1&categoryDisplayName=Fuel+Delivery&navValue=14900120&itemId=120-0&parentId=49-0 $43 x 6 = 258.00 I google'd the part number for a flow rating but couldnt find anything. I would be worried that they might not be "turbo" injectors or that you could get a mix and match of different injectors, some turbo some NA, although autozone has a different part number for the NA injectors Arizona Z car sells them for $49 each and you are getting TURBO injectors for sure, $36 more for all 6 is cheap piece of mind. If you're going to drop the cash for new injectors you should decide what your power goals are and maybe just upgrade now. Instead of buying stock turbo injectors
  11. Thanks for everyone's advice I've been looking at different T3/TO4E turbo's but am on somewhat of a limited budget. GT35's and the GT3076 are for sure out of my price range. I have bought 2 used stock turbo's that turned out to be junk..... Most of the info I've found about the ebay turbos seems to be hit or miss, which is why I asked about these 2. Most of the reviews on them or feedback is done when the person opens the box and see's their shiny new part.... Godspeed had their turbo's reviewed by honda tuning magazine and they came out ok, but some claim the company cherry picked the good ones for the review... Cheap Fast Reliable They say you can choose 2 but not all three...
  12. I'm looking at these 2 turbo's for my 240z build. The motor is an F54 Flat top piston NA block with a P90 head, stock cam, stock turbo injectors, and stock ECM. I will be using an intercooler, and 2.5 inch down pipe and exhaust with a straight through magnaflow muffler. I'm looking at 8-9 psi max Here are the turbo's I am considering #1 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=180471774388&viewitem=&sspagename=STRK%3AMEWAX%3AIT T3 TURBO INTERNAL WASTE GATE TURBO CHARGER .63ar T3 internal wastegate turbo Intake: 3 inch Inlet: 2 inch Compressor trim: Compressor Wheel diameter: 54.28 /71.32 Turbine Wheel diameter: 55.79 /63.36 Exhaust Trim: .63ar Turbine flange type: T3 flange Down pipe flange type: 2.5 v band Actuator setting : 8 psi Cooling type: oil cool only And Door number 2 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=290400802988&viewitem=&sspagename=STRK%3AMEWAX%3AIT Intel 3" Outlet 2" Bearing Wet Floating Bearings Oil Inlet 1/8 NPT Oil Inlet Flange Standard T3/T4 Flange Swaps 350 WHP Working Pressure 5~20 PSI Compressor .60 A/R Compressor Turbine .63 A/R Turbine Compressor Wheel Exducer: 3" Inducer: 2" Turbine Wheel Exducer: 2.2" Inducer: 2.58" Hot Side 2.5" v-band They look to be the same, just seeing if anyone has any advice or has purchased these turbos and what their opinions are. Thanks
  13. Not my ad, http://modesto.craigslist.org/cto/1609199135.html 71 240z It has the rare triple WEEBERS and Heathers..... (His terms)......
  14. Not mine but could be a deal for swap parts. Take the LSD R200 out and sell the rest. I dont have room for a parts car at my house...... 87 Nissan 300zx Turbo $700. Sacramento CA http://sacramento.craigslist.org/ctd/1591623089.html 1987 Nissan 300ZX - Has Small Front Dent On Fender - $700 (Roseville) Date: 2010-02-08, 10:51AM PST Reply to: sale-bjssx-1591623089@craigslist.org [Errors when replying to ads?] Salvage title 1987 Nissan 300zx for sale at AutoGator. 1987 Nissan 300ZX Turbo runs and drives,has small front dent on fender and needs the passenger window fixed.It will be a salvage title. For more info, please visit: http://autogator.pageweavers.com/details.php?vstockno=R4714&template=builder More salvage vehicles are available at http://www.autogator.com/salvagecarsforsale.html Contact Doug at 916-960-1505 AutoGator Auto Dismantling 1961 PFE Rd. Roseville, CA 95747 http://www.autogator.com
  15. I would redo the timing. Reset TDC and clock the distributor. If you still have the same problem, run to pick n pull and get another e12-80 module. Although usually if the module is bad you dont get any spark..... I wouldnt try to use the e12-92 module..
  16. How about a video on how to remove the caliper brackets OFF a maxima.....
  17. One of the best Z's I've ever seen ! Here is some info about the classes that I found http://www.zcca.org/downloads/ZCCA_JudgingManual_2009.pdf Looks like you're in Nissan Modified, Street modified has to have the L6 engine.
  18. + 1 for Gold Just seems to add to the overall look of the car compared to the silver wheels
  19. I've seen several hot rods with a north star V8 as well as sandrails. Here's info on an adapter to adapt a RWD 700-r4 transmission to a northstar V8 http://www.phoenixtrans.com/html/adapters.html PT700NSA NorthStar Adapter Engine Cad Northstar V8 Trans- S-10 STYLE 700R4 Starter- Northstar Flywheel- stock Northstar
  20. The 9mm is in reference to the rod bolt size. Most L24 rods use 8mm rod bolts. People building a stroker motor want the extra strengh of the 9mm bolts
  21. you dont need to convert to the 72 harness. Here's a diagram to install the e12-80 distributor
  22. I was just there today as well, no wheel lock key anywhere.... some jack must have taken it or is coming back for the wheels later.... Most tire shops have wheel lock extractor sockets that you either hammer on, or they chew into the lock as you loosen it. They might let you borrow one if you give them a deposit.
  23. Try rotating the adjusters in both directions. Use a flashlight and make sure you're going the right way. Also chisel the center of the drum near the stub axle. Sometimes rust gets in that crack and the drum wont budge. Good luck, I layed on the ground with a flashlight and a small flat head screwdriver and turned the adjusters, then used a BFH and tapped all around the perimeter of the drum. I heard the brake shoe clunk on the inside, it had seized to the drum....
  24. NO smog in CA for the 240 and its lighter than the 280zx. Get the 240 and put the turbo motor in it.
  25. Found some, thank you Scott_M67
