wax
Everything posted by wax
  1. Its an ada conversion I went nuts with the devcon inside after that shaping port filling other stuff etc
  2. 2008 yamaha superjet 8mm power valve lamey engine and spare race engine What could have been but never happened One weird ass china ped with a reed valve conversion and extra ports , pipe you name it I build it but dont want to ride it It hurts to much 2006 yamaha aerox moped racing Guy on the bike behind didnt seem to be as happy i was when I got pole in qualifying
  3. Wow this guy must be cashed http://www.youtube.com/watch?v=kHmvkRoEowc&feature=fvw
  4. wow the little datsun goes well I would save up for one of those Seriously that ferrai has way to much droop in it, its ruining its handling big time Look at the height changes in the front as he acclerates
  5. Thats an awesome looking drag car you have there I love the sound of that engine as much as your compitetion must hate it
  6. Yeah thats kinda wild Looks like a handfull, will be follwing this thing to see how it goes, easy to tell your right down on power there compared to the 240z( at the moment) Why a front engine dragster ??
  7. Sounds like an awesome thing I can see it being the thing I will do when I decide to bare metal my car
  8. If you use a rb25 or an rb30 block your sump hassles will be alot less
  9. It seems os giken may be making more heads http://www.viczcar.com/forum/index.php/topic,4235.45.html
  10. When i was working on alfas with the down draft webers We had a system using water in a tube and used it to balance the carbs It hooked to the bottom of each carb and it would show the vacum each carb was pulling You would need to do it with all 6 cylinders but its the easiest way to balance the carbs
  11. Who ever looked at a whale penis and said wow we can make that into a car seat Im not homophobic but really sitting in a chair skin to skin with another creatures penis just isnt doing it for me.
  12. That looks awesome i would love to go down that route as well Im always tossing it up in my head if to go normally aspirated or not The sound they make is amazing
  13. Thanks guys more pics coming soon I have ported the stock exhaust manifolds. I have seen the aftermarket ones break all the time, you can get the stock to work almost as well with out the breaking
  14. I was going to use a l28 in my car but then thought nah lets go rb engine So i went and brought a rb26 head if your going to do it then you have to do it right huh So it was off to get stripped down and hot tanked The thing that always concerned me was getting a sump to work in my z car After talking to people i found that the nissan patrol sump would fit I started looking for one of those but was unable to find one I did however find an rd28 sump of the diesel Interesting enough it uses a rubber gasket on the base to seal it The issue with this sump is that it has an extra bulge on the bottom to increase its oil capacity. This would drag on the road in a z-car so it had to go. Ok so time for an engine block, read it and weap every non australian rb fan Yes thats right i paid 10.50 for this engine. It cost more to actually drive and pick it up than it did to buy it Then the block was sent off to be hot tanked All painted up The head is all ported now and just have to get the seats cut and start to bolt it all together
  15. Yeah it will be a bit tight but its going to fit, Once its all welded up i will start work on cutting the hold for the watergate. then i will just blend it in on the down pipe I woul dlove to run it as a screamer but the police dont like that sort of thing here in australia
  16. Thanks Yes i will be using an external waste gate i will run it underneath the manifold.
  17. And for all the people that seem to want to find fault in everything, Now the turbo doesnt hit the side of the car it has about an inch clearance its the angle its taken at
  18. Ok well its finished pretty much Just have to weld it all solid now please excuse the mess in my car this is all pre my doing
  19. They are mild steel bends, 3mm thickness.This is what i use on all the turbo manifolds i have built to such date it works just fine I think you will find is the angle that the pic is taken on makes it look closer than it is . Have a look at the pic of the other manifold up top it will run as close if not closer than the one i have made.
  20. I will be cutting the flanges between the cylinders to allow for the pipes to move I also have an electrical furnace i will be putting the manifold into to normalise it after its all been welded. I appreciate your coments about the pipes but the picture makes them look closer than they are , i also have had used this thermal coating before and i know how effective it is , if this was not good enough i would simply wrap the pipes in tape , though this would be a pain
  21. Have a look at this link and you will see the coating i am applying to the manifold when its finished http://ceramic-coatings.org/products/heat.aspx#E
