If i run the rails in series it would be end to end, I'm guessing you mean parallel? I'm hoping the stock size metal fuel pipe will supply enough fuel for these injectors.
Well, the throttle bodies come with an injector in each one, so I would either have to fill the hole, or run an injector in there. Also, the throttle bodies will be roughly 6 inches from the head, and that gives the fuel a little more time to mix thoroughly with the air.
yep! I think i got 28mpg ONCE after installing the megasquirt, and then after that my right foot just got too heavy
The plan is to maintain basically the same map for the lower load region, since it will be the same injectors, just different way of getting air in there. I plan on running it on speed density at first, and I'm crossing my fingers that I won't have to do a whole lot of re-tuning because my car runs amazingly right now. The second table will control the second set of injectors, (dual table) and won't affect anything until 4000rpm and above 70kpa.
prox, you can cut up the little pipes that connect the injectors in half and connect fuel injection hose in between the two halves (after you space the throttle bodies) to keep the fuel in the rail... easiest way to get the job done until you can fab up a fuel rail. Are you going to be running 12 injectors as well? i don't think the stock gsxr injectors will handle the needs of a L6 turbo.
