moms'z, Would that exlplain the dropping tach?
A few more updates:
Pin 10 on the ecu is only getting power while cranking, which means it is not normally getting power from where its supposed to be getting it from
The main relay is fine. I pulled it and tested it.
My ignition lock is funky and only cranks the car if you push the key in simultaneusly (oops, just gave away my theft deterrent secret) and if i turn the key to the start position, push it in to start the car, and then release the "inward" motion, the engine will stay on. I can rev it and everything, but as soon as i bring the key back to "on" the engine will shut off.
The fact that the engine will turn on and act like normal indicates that there is nothing in the EFI circuitry that is faulty, just a power to the ecu under "on" condition on the ignition lock.
I pulled the ignition lock/ switch, and tested for continutity and it all checks out.
I think i have narrowed it down to missing power to a lead from somewhere. It seems like a blown fuse, but nothing is blown. I think i've checked the fuses 20 times now.
Jeez I feel like i'm doing the whole ElaineZ posts over at zcar.com...
