Mayolives
    6
Everything posted by Mayolives
  1. I installed a pair of rebuilt cv axles in my used R200 lsd differential and after a short session on a road course track, my car acted as if the transmission was not in gear and/or I had lost the clutch. The car would not move. After being towed to my pit area, I discovered the drive shaft was turning when the transmission was engaged but the rear wheels were not moving. My first thought was a differential problem, but upon further tear down and inspection, I discovered a broken cv axle. The joint near the differential was in pieces. I purchased the rebuilt cv axles from Modern-motorsports and what occurred happened on their first trip under a load. My question is, why did the car not move with only one broken cv axle? Why didn't the other axle propel the car? I haven't opened the differential but I did drain the gear oil and it was clean and new. Any thoughts on the condition of my lsd? Is it ok? Did I get a bad cv axle from Modern-motorsports?
  2. For those who are interested, we found our problem when testing at the dyno this past Saturday. I am using 55 lb Seimens fuel injectors and theie duty cycle was maxed out when attempting to run boost pressure above 20 psi. and we were able to tune out a little lean area that apparently was causing a slight hesitation around 4200 rpm. The Profec B Spec 2 worked best on low boost setting using 30 % gain, and on hi boost a 15% gain. Out final boost settings create 14 psi on lo and 19 psi on hi. The car now pulls hard and make gobs of hp and torque.
  3. John, Thanks again for your input. I have a laptop but used the tuner's computer when we tested. I should have downloaded the files to my machine and will do so asap. Yes, the dyno is an expensive place to work to bugs out of my car, but I have little choice in the matter. My car is a dedicated race can, full cage, no headlights, turn signals, tags, state inspection, insurance etc. There is really no place to "road" test it.
  4. John, Yes, I am using the tec 3R engine mgmt sys. I don't have any of the data logs. They are stored on the Electromotive guy's lap top. He mapped and remapped but could not get the hesitation to stop. We have decided to go back to th dyno this Saturday to give it another try. After reading post at other forums, I think we need to lower the gain settings. The Evo guys use this EBC but run lower settings for the gain. I'll keep you posted.
  5. Is anyone here using a Greddy Profec B Spec II boost controller on their L28 ? I'm searching for answers concerning the controller's tuning. I'm using it on a new engine with many bells and whistles including an Electromotive Tec 3R ignition system, GT35r turbo and a Tial waste gate that currently has a 14.5 lb spring installed. I'm running a conservative lo boost setting of about 14 psi with my gain set around 50%. This produces lots of hp and torque but the engine has a little stumble around 4200 rpm and then makes steady boost to the shift point. I have tried a high boost setting of 20psi with the gain set at 45% and still have the same little engine stumble. My questions is, what gain settings are other user's running on this engine. We spent a lot of time on the dyno and have really tuned this thing to the max but I still have the little stumble. I'm convinced that it is boost controller, waste gate problem that produces the stumble. Any suggestions?
  6. I have an interest if a group buy is in the works.
  7. John, We will get it worked out and I do plan to be at this month's T1 event. Can't wait to hear your German stories.
  8. My tuner is an Electromotive factory rep. who knows what he is doing. So I will rule out this as a tuning problem. After the stumble at 4500 rpm, the engine pulls hard and makes steady boost to the shift point. The engine is new, so we are doing most of the runs at 6000 rpm max. We have made a couple of 7000 rpm pulls and the reaction is the same.
  9. If I remember correctly, one side of the controller valve is connected to the top port of the waste gate and the other side is connected to the charge pipe between the inter-cooler and the turbo. On the dyno, the engine makes boost, then stumbles at or near 4500 rpm, and then again makes boost up to the desired rpm shift point. I'm running an Electromotive ignition system and we have tried to turn the stumble out, with little success. This whole process makes a lot of hp and torque, but the stumble would make it very tricky if not impossible to handle on a road course. This car is a dedicated race car and will not be street driven.
  10. I have a Tial WG38 waste gate with a 14.5 psi spring and a GReddy Profec B boost controller. The controller has a hi and a lo setting. I have the low setting at 14 psi and the hi set at 20 psi. When dyno tuning, I'm having problems holding boost on the high setting. If I install a 23 psi spring, will my boost controller still be able to open the waste gate on the low 14 psi setting or will the stronger 23 psi spring over ride the controller?
  11. John, You are a traitor! But....I still really like the car. Good luck on the purchase. Please keep us posted. Where is the link to "Hybrid Porsche.org?
  12. The Tail waste gate has two ports. Thier instructions say to use the top one for the boost controller and to use the other one, on the side, to "supply air from the intake manifold, before the throttle plate". Please refer to the Tail website at http://www.tialsport.com/. Then click on the "technical" tab near the top and then click on "waste gate installation diagram". Thanks for you thoughts and advice.
  13. I have installed a GT35 turbo and Tial waste gate on my L28 and need some supply hose installation advice. I'm using a throttle body from a BMW which has a port on it's side that I would like to use for the air supply to the side port on the Tial waste gate. Will this work ok or should the air source be located father up the intake plumbing pipe and away from the throttle body?
  14. South Carolina.....6/7 percent on house sales and as much as 10 percent for lot sales. Commission varies on large tracks of land and is often negotiated to a set amount.
  15. My 82 zx turbo has a high pitched whistling sound that comes from the rear of the car after the engine is turned off. When I open the gas tank cap and relieve the pressure it stops. Obviously, the sound is coming from the fuel system and has something to do with fuel pressure in the tank. Any ideas about what is causing this sound?
  16. phantaz,.... Where was the valve located? What did you do to reset it?
  17. Mat, I will take three when they are ready.
  18. I just sold two new Sparco Circuit seats because they were not comfortable. I have an average biuld, 5'11" 170 lb, 34" waist, and the seats were very tight on my legs and the upper wings blocked my side view. IMHO, you should always try before you buy.
  19. I received Arizona Z Car's new billet mustache bar and brace set for the LSD finned cover. They are beautiful pieces and the fitment is perfect. Thank you Dave for providing these ultra high quality parts for our cars. The links below are to some pictures of the install. The bracket in the picture hold the fuel cell. http://i18.photobucket.com/albums/b105/mayolives/HPIM0402.jpg http://i18.photobucket.com/albums/b105/mayolives/HPIM0400.jpg
  20. I received Arizona Z Car's new billet mustache bar and brace set for the LSD finned cover. They are beautiful pieces and the fitment is perfect. Thank you Dave for providing these ultra high quality parts for our cars. The links below are to some pictures of the install. The bracket in the picture hold the fuel cell. http://i18.photobucket.com/albums/b105/mayolives/HPIM0402.jpg http://i18.photobucket.com/albums/b105/mayolives/HPIM0400.jpg
