Mayolives
    6
Everything posted by Mayolives
  1. TimZ, G Force is using my NWC tailhousing and is modifying it for me. The input (pilot) shaft will remain the same. How much farther forward will the new shifter be? How much do I need to alter the stock hole in my tunnel?
  2. My T5 (NWC) is at G Force and will hopefully be ready for me to install within the next few weeks. I read a post somewhere, pertaining to modifications needed to install a T5 in a 240, but I'm installing it in my 78 280 body and it will have an aftermarket Long shifter. Will any modifications be needed to the shifter/tunnel area for this install? John Coffey's sticky says the length of the T5, from the bellhousing to the center of the shift pivot, is 29 inches.This is about 1/4" shorter that the same dimension of the five speed I removed from the car. Any other installation tip on the subject would be very helpful.
  3. I drained, what probably was, the original factory transmission gear oil from my 60,000 mile, 82 zxt. The fluid did not appear to be ATF. It appeared to be "normal" gear oil. I replaced it with Redline 75W90NS. My T5 shifts smoothly and is very quiet. I think I made the correct fluid choice.
  4. Z Racer...Private message me at mayolives@aol.com. I have a zx rear louver.
  5. The price paid is determined by, believe it or not, only a few factors in most cases Buying and reselling houses is my business and I have been doing this for many years. On average, I complete about ten deals each year. Factor number # is determined by how much the BUYER wants the house and is willing to pay. The other important factor is, you guessed it, how bad does the SELLER wants and needs to sell the property. My first offer is normally twenty percent less than asking price with an offer to close in ten days., no strings attached. Then the ball is in the seller's court.
  6. I had a new one, "back in the day" and it was a great car. I ran the s--- out of all it's five gears. We called it the poor man's Mercedes.
  7. Mayolives.......My Father's name was Mayo, hence, Mayo still lives in me. Mayolives
  8. Mike, I'm using AZC Wilwood, competition, five lug conversion on all corners. SUPER braking!
  9. I use a DeWalt 18 volt cordless. It's the cat's meow.
  10. I'm using Spoork's custom (Lonewolf) intake with an Electromotive Tech 3R ignition set up. We installed the map sensor in the rear of the intake body and it works as it should.
  11. I'm using it on my track car fuel system with AN style fittings. From the tank to the pump to the fpr and to the injectors. It's good stuff and unlike the metal braided products, the installating is easy on the hands.
  12. Too much. And I thought that I was an adrenalin junky! This guy is out there!
  13. CSR Performance Products make an electric water pump for the L28. http://www.csr-performance.com
  14. Not to hijack my own thread, but any thoughts about which gear oil should be used in the comp. box ?
  15. It's a Nissan competition 5 speed. I'm really excited about having it and can't wait to give it a try.
  16. Search has not provided any information. Could it be that this has not been discussed? I'm swapping transmissions and would like to clean and flush the transmission before installing it. I thought about using diesel fuel. Any opinions about what would work best, which procedure to use or how long to let the agent inside the transmission?
  17. I have a good one. PM me at mayolives@aol.com.
  18. This all sound quite reasonable to me. But if you give me a set of the nasty wide rims, you will feel beter in the morning!
  19. There has been a lot of discussion on the subject. I have a similar problem and although I have not tried to fix it yet, I was able to find direction from searching Hybrid and reading the fsm. There are several vac. operated switches that are normally the culprit. They are located under the dash and are not easy to get to but can be replaced. The fsm explains what each one does and how to test them. Good luck!
  20. I rebuilt mine. It worked fine. Nissan Bushing #80410-01G00, Nissan Pin #80406-V5002 are the replacement parts that I used. You will need to shorten the new pin.
