Everything posted by heavy85
That's easy - flare (flair?) it! Cameron
rear poly bushings on outboard end of CA
heavy85 replied to blueovalz's topic in Brakes, Wheels, Suspension and Chassis
Moving the rod ends closer to the strut would increase the force through them due to being a shorter moment arm resisting the tire wanting to spin around the strut. For the small amount of movement you're talking about I doubt it would be much but pretty easy to figure as it's just a ratio of the old vs new distance with respect to the centerline of the strut. Without spacers would save weight but we're obviously talking ounces here so I doubt you care. Cameron -
Any reason to keep the package tray?
heavy85 replied to heavy85's topic in Brakes, Wheels, Suspension and Chassis
Are you sure? Mine is a '72 and the tray is very thin sheetmetal. Thin enough I can easily just push on it and it visibly deflects quite a bit. Definitely a lot thinner than the floor pans for example which I have to beat on pretty good to get them to move around. Looks like almost an afterthought to provide some storage and a flat spot for luggage as it's just tacked on top of the the more substantial floor structure below. Cameron -
PICS: Custom rollcage fabrication/install
heavy85 replied to mull's topic in Brakes, Wheels, Suspension and Chassis
What I mean is they connected to the wheelwell but the load comes into the strut tower. So there is no direct connection from the loads which come from the strut to the cage - the load has to go from the strut into the strut tower then into the wheelwell and finally to the cage. From a loadpath perspective seems like a less than efficient design - to me you would want to tie into the tower and not the wheelwell. Maybe the cross bar is welded to the front of the tower but it's hard to tell? PS: sorry, didn't mean to hi-jack Mull's thread Cameron -
I always thought the package tray area provided some level of side stiffness by connecting the wheelwell to each other and the tranny tunnel. However, after playing with it for a while I realized the metal is soooo thin that I can't imagine they could really provide much if any strength. I'm thinking why not just remove it and maybe run a tube across to tie the wheelwells and tunnel together. Thinking it might be a lot stiffer for the same weight. Could also potentially allow me to move the battery forward and down which would be good. Anyone studied or done this have some comments? Thanks Cameron
Why would they have not tied the cage into the rear strut towers? Cameron -
John, I remember you once saying your front strut tower bars on the ROD were design using FEA plus I just like your design from a structural standpoint so would like to steal it for my car if you dont mind. Do you have any details other than the one pic on your sight? Maybe any close-up photo's, material thicknesses, etc. I'm most interested in exactly how you re-inforce and tied into the firewall and strut tower. Thanks Cameron
Sorry to get back on the subject but ..... I just opened the box with the 2x3 tubing in it. Holy heart attack batman that stuff is waaaaaaayyyyyyy overkill OMHO for a Z plus they weigh about 16 lb each side! I've got to rethink this SFC thing because that's just silly beefy (no offense to those who've pioneered this method as it's definitely stout). Maybe I'm over-reacting but those things seen better suited for a truck or something. What about what I suggested a couple posts up and split the 2x3 in half into two 1x3 U pieces and use one half attached to the inside of the rocker and the other half to the bottom of the floor? Then attach the front of the rocker to the engine rail & T/C bucket. Cameron
The 'piece of crap' (wife's description) is coming home
heavy85 replied to heavy85's topic in Gen I & II Chevy V8 Tech Board
My wife's a sweetheart. Wasn't feeling well the other night and went to downstairs to find her cleaning up the other garage bay - the one the Z's not in. Looks like the 'maro is will be inside for the stripping! Cameron -
That's a cat??? Would have fooled me ... and who photochopped it's eyes ...
No just the rear edge of the passengers side back. Not looking forward to the work of parting it out but sure am looking forward to the smile on my face when I punch it for the first time . Cameron -
Holly crap - that could not have hit at a worse spot! I'm really starting to rethink the 2x3 SFC as I think there is a more efficient way to get the stiffness. Been looking around at Camaro/Mustang SFC and most the ones I've found were 2x2 or 2x1.5 albeit .125 wall thickness. Those are more used for drag racing which can put a lot of twist in a chassis ... and are 1000 lb heavier. For the little ole Z I'm wonder if I should take the 2x3 (I already ordered) and cut it in half to make two 1/3 U shaped pieces. Cut off the factory rail (I have to replace my factory subframe since it is beat to hell and back and is pretty much useless now otherwise I'm not sure I would even touch them) and replace them with one of the U's and take the other U and weld it to the inside of the rocker. Then tie in the U at the front of the rocker with a tube diagonally forward to the engine frame rail / TC bucket. Could kill two birds with one stone and end up with the same weight I would have added with just the SFC and not have to disturb my not very rusty floorboards. I'm going to cut out the factory seat brackets to lower the seat and just go with 1x1 directly on the floor. To tie it in even bettey maybe run a couple extra side to side bars from the reinforced rockers to the tunnel with a backing plate to spread the load into the tunnel. This extra bar would be right in front of the seat as high as possible without interfering with the bottom of your legs. What's everyone think? In the end I'm going for as much stiffness and driver safety as possible while minimizing weight. Thanks Cameron
Please help - cant find perf brake shoes!!!!
Thanks for the tip John - ordered a set today. They said Ferodo is basically non-existant anymore but that these are built to the same basic specs as the Ferodos and they sell quite a few into vintage racing applications. They are called 'Spectraone' (dont quote me on the spelling) and come from a company in Canada. They were only like $26 so we'll see how they do. Cameron -
240Z Autocross Suspension Setups (all-out)
heavy85 replied to zredbaron's topic in Brakes, Wheels, Suspension and Chassis
Lots of good advice up here that you should take in and apply, but also consider you can make up three seconds just by switching to race tires from street tires. Tires make a HUGE difference. Cameron -
Thanks for the links. To close out the list does anyone know where to find some Ferodo Green Stuff shoes? Courtesy says they are NLA and MSA only has ones for '75 and newer. Anyone know who sells them for the 240's? Thanks Cameron -
I'm more than tired of locking up the fronts in just about every corner because the rears suck. Have Hawk front pads which are nice but the rear shoes are just stock and cant come close to keeping up. I've been searching for Ferodo or other performance shoes but cant find any. Does anyone know where I can get some? Thanks Cameron PS - MSA says their Green Stuff shoes only fit the 280Z where I have a '72 240. PPS - still #2 fastest raw time (# 3 PAX) today behind the Z06 ... as I've been all year but next year it'll be a different stroy with the LS1 installed .... if I can get these stupid brakes working. I'ld just go to rear disks but I've spend all my money on the LS1.
I like that idea and it's about time to change the oil anyway. Where exactly would I see the V07 marking - anyone got pics? Thanks Cameron
