A buddy and I are tuning his Z32. He built up a vg pretty strong and it running ceramic coated forged pistons, hks rods and balanced crank. Stock heads (well stock appearing :>), ported and extrude honed stock exh manifolds, stock extrude honed upper intake manifold, a set of the new HKS gtrs turbos. he is producing 550rwhp and 480ft lbs of torque.
he is running 106 race fuel. egt doesn’t get above 580C, total timing is at 30 degrees, air inlet temps are in the low 140s, A/F is rock steady at 11.5 all the way thru to 6200 rpm.
My question is I have heard that with race gas you will not detonate you will just not make anymore power if you put too much timing into it.
The problem is right now at about 5000RPM the torque curve takes a dive till about 5500 rpm and then starts rising again till about 6000 rpm
In the pic below (not the actual dyno chart) the black line is the original run and the red line is the run after several runs of advancing the timing in that area to try and get a nice curve with one peak.
Anyone care to comment on what else can be done to fix this curve. I was thinking since we have hit the limit on what timing will do.... leaning it out in that same area is the next step. We are being very conservative with the tune to stay as safe as possible and still hit the 600rwhp goal.
 Also what are safe A/F ratios when using 106 unleaded race gas.
