Haha your funny.... its a straight downpipe with 4 in Dia staight muffler that is about 6 inches long. It dumps right after the front wheel. Entire thing is about 2.5 feet long
Initial break in done. Idles perfect from initial startup to operating temps at 850- 900 rpm.
https://www.youtube.com/watch?v=eya5yDBnH1I&feature=youtu.be
Its snappier for sure. May be because of no converter yet.... but last time i started it up like this it for sure sounded lazier. Rings are good so far no smoke.
I did the math on the 1000CC to 1600cc injector upgrade and made the changes in the AEM. damn thing started right up like nothing ever happened. !!!!!
<iframe width="420" height="315" src="https://www.youtube.com/embed/qu_HpSQ6rms" frameborder="0" allowfullscreen></iframe>
So stock impression is 8.5:1 that's with .9mm headgasket. I had a 1.2mm with normal compression hks pistons so my guess my comp was lower then stock. Now I'm just above stock. I'm guessing (based on all calc) will be about 10.1. On e85 this should wake it up considerable off boost.
It was a long time ago so maybe I'm not remebering correctly.... but what I'm saying is with a stock rb26, r200 and stock rearend... I would drop clutch around 4500 and get lots of wheel spin. 275x50x15 dr. So even a lunch close to that your in the low 10s.
Wait, what prompted the backhalve? 2 pages ago you had a kickass, rearend, exhaust and interior???....
mine weighs 2600 with me in it. about 750 to the wheels....
https://youtu.be/nyVILCgmRAw
If you 870 to the wheels..... hope your doing a 7;50 cage
I agree with the compression thing if I was running a manual. Gotta remember I'm on a powerglide with a 6000 stall. I'm trying to generate some more power off boost to help with the stall and spooling turbo. Right now having to hit it with 150 shot to get it on the stall. Without it, the damn thing won't go above 4000rpm. About 1500 rpm short of where it needs to be to produce boost.
Cant find the dyno video but i was only making just a tad over 100hp at 4300. the converter needs more then that.
Still waiting on my dial indicator but eyeballing the the piston to deck... its just below being flush with top of the block. also the intake squish pad is removed on my head.
Here is a pic i took the first time I rebuilt it.
Here is a pic of the combustion chamber. This is an old pic before taking 2mm off
