10
Everything posted by stony
And im not going with eagle because i got a really good price on the crower rods....that is all.
All Eagle "ESP" Connecting Rods are manufactured from a TWO-PIECE FORGING.
The industry standard by which other rods are measured. Manufactured exclusively from USA made, 4340 billet chromoly steel. The standard billet rod is the strongest, most durable rod, and is intended for high horsepower applications. And for the record I have changed a HG just before this latest rod bearing thing. Not sure where you got this from???? Now it has been in and out of the car many times for mock up stuff but that’s about it.
Little update on this…. The folder ♥♥♥♥ finally called me back after many calls and emails about getting my refund for the fucked injectors he sold me a while back. He gave me a number to Phantom injection (used to be venom). Told me to ask for a guy named Bobby. Talked to this guy and he is oblivious to what the folderfuck is doing to the venom name and I explained my situation and referred him to Google “venom injector scam†and that he might be interested in what kind of business tom folder is conducting. He stated the head office will be very interested in this situation and he would look into it. The I asked him so what are you going to do about getting me a refund. He said sir I will work this today and get back to you ASAP. More to come.
The eagle rods i can still get for 550 plus shipping but for another 200 i can get billets.... what would you do? Im looking at turning 9K rpm and 30+PSI so that is just a little bit of piece of mind for me
Anyone have a couple extras laying around??? Let me know. There is another guy up here in alaska building an rb26 and somehow lost his when his block cam back from the machine shop
I'm not going to post this up in the for sale area just yet as it is kinda specific to this area. Well I went ahead and ordered a set of Brian crower billet rods. I thought I had HKS rods till I removed them and looked at them… They are actually Carrillo rods. I have 5 good ones and if you buy a new rod from Carrillo to replace the bad one it will cost 385 plus shipping…. Anyone interested in the set of 5???? 300.00????? What about a stock r32 crank with a oil pump mod done to it? Needs to be turned 100.00????? You may ask why you don’t just do that yourself... Well im kind of in a time crunch and the Carrillo rod is at least a month out, the crower rods will be here next week. Another reason is I don’t have any really good MACHINE shops up here in Alaska I could trust with a crank they have never worked with before. 3RD I’m going to step it up some and I want to make sure the rods are up to the task. So if anyone out there is interested let me know. I will have the crank out of the block by the end of the week. Rods are ready to go now.
HMMMM when i merged the threads the old name changed????? Anyways that thread is for links and the such this one is for part numbers ect ect
Found this while i was trolling FA good info Thought this might be useful also: Part numbers for RB26DETT only, unless otherwise noted. Ignitor pack- R32/33- 22020-05U00 Spark Plugs- PFR6A-11 Clutch Pull to push conversion- Late Model R32, R33 and R34’s Front cover assembly :32110-05U11 (japan part only) Gasket :32112-05U12 Clutch fork :30531-01S00 (same part for a 1991-1993 240SX) Spring :30514-14600 Spring :30534-E9000 T/O bearing :30502-14601 Bearing sleeve:30501-S0160 / 30501-N1601 (14mm for twin / trip disc) Bearing sleeve: 30501-K0404 (24mm for single disc) Dust cover :30542-31610 Slave cylinder :30620-21U01 Flywheel bolt: 12315-04U00 Factory Clutch R32 GTR Disc- C0100-05U15 Cover-30210 - 05U01 Bearing- 30502-21000 R33 GTS Disc- 30100-21U01 Cover- 30210-21U00 Throw out bearing- 30502-12U00 (300ZX part) or 30502-45P00 (300ZX part) Bearing Sleeve- 30501-S0200 (18mm) R33 GTR Disc- 30100-0V708 Cover- 30210-24U00 Bearing- 30502-12U00 R34 GTR Disc- 30100-0V708 Cover-30210 - AA300 Bearing- 30502-12U00 R32/33 Brembo Brake pads- F 41060-12U87 R 44060-12U87 Belts- RB26 R32 4 Ribs AC- 925 mm Power Steering- 950 mm Fan- 880 mm RB26 R33/R34- 4 Ribs AC- 910 mm Power Steering- 969 mm Fan- 875 mm R32- RB25 AC- 4 ribs 925mm PS- 3 ribs 845mm Fan- 4 ribs 860mm R32- RB20 AC- 4 ribs 925mm PS- 3 ribs 855mm Fan- 4 ribs 860mm R33- RB25 AC- 4 ribs 910mm PS- 3 ribs 845mm Fan- 4 ribs 850mm R33-RB20 AC- 3 ribs 910mm PS- 3 ribs 855 mm Fan- 4 ribs 850mm R34- RB25/RB20 - 4 Ribs AC- 910mm PS- 865mm Fan- 890mm Water Pump-21010-58S25 N1 Water Pump- 21010-21U26 N1 oil pump- 15010-24U01 Thermostat-21200-42L06 for the RB25DET and RB26DETT. Part # is 21200-42L00 or 21200-42L01 for the RB20DET. R32 ABS Unit- 47600-05U00 R33 ABS Unit- 47600-15U00 R32 Power steering pump- 49110-05U00 Intake gasket- 16175-05U70 (3 needed) Nismo AFM’s 22680-RR580 Standard AFM’s 22680-05U00 Lower rad hose- 21603-72L00 Upper rad hose- 21501-05U00 R32 ATTESA valve- 49836-01U00 R33 AC Compressor- 92600-24U15 R32 Clutch master Cylinder- 30605-05U00 R32/33 CAS 23731-02U10/1 R32 Starter- 23300-20P00 N1 Block- 11000-24U00 Injector O-Rings- 16635-78A00 Valve cover gasket- 13270-58S11 and 13270-58S01 Valve cover half moon seal- 11051-58S00 R32 AAC- 23781-05U11 R32 GTR ECU- Hitachi- 23710-05U02/01 R32/R33 Twin Cam valve cover strip- 13290-05U00 R33 Front Hood Spoiler-65834-24U00 R32 Oil Pressure Sender- 25070-30P01 R33 AC Hoses Flexible low pipe - 92480-98U00 Front cooler high line- 92440-24U20 Flexible low hose- 92490-24U10 R33 Heater core compatible with Z32 heater for you must reuse your plastic inlet and out lines- TBA RB26 Dip Stick- 11140-05U02 R32/33 Starter- 23300-20P05 R32 Alternator (Mitsu unit) 23100-20P10 (90 amps) 23100-86L11 Mitsu (90 amps) and 23100-86L12 Mitsu R33 Alternator 23100-70T13 Mitsu (80 amps) 23100-70T03 hitachi (80 amps) 2/97~up 23100-0V010 Mitsu (80 amps) R34 Alternator 23100-0V016 R32 2WD model Alternators 23100-59S01, 23100-85L00 Hitachi 23100-85L10, 23100-85L11, 23100-85L11 Mitsu Found this on GTR UK BNR32 Part Number Item Description Common To Other Source Notes 13028-20P25- Belt - Timing no 16400-72L00- Strainer Assy - Fuel U13 21200-42L05- Thermostat Assy Y32 22401-58S15- Plug - Spark KN13 w/CA18DE 28890-01U00- Blade Assy - Windshield no 28890-51S10- Blade Assy - Windshield B13 28790-56E00- Blade Assy - Rear Window U12? 30100-04U00- Disc Assy - Clutch no 30210-73L00- Cover Assy - Clutch no 30502-21000- Bearing - Clutch Release Z31 turbo 46210-04U00- Hose Assy - Brake, Front no 46214-01A11- Hose Assy - Brake, Rear B13 37521-01U26- Bearing Kit - Center (Driveshaft) no from 89/11 to 90/08 38300-84M79- Final Drive Assy no without EAL sensor 39241-73L25- Repair Kit - Seal, Outer (outer CV boot, rear) Z32 non-turbo 39741-03P27- Repair Kit - Seal, Inner (inner CV boot, rear) Z32 non-turbo 30611-71L25- Piston Kit - Clutch Master Cylinder WD21 '90-'91 30621-26E25- Piston Kit - Clutch Operating Cylinder no 32114-Y4000- Seal - Oil, Front Cover (Transmission) D22 '00+ KA24DE 32112-04U00- Gasket - Front Cover (Transmission) S13? 32136-U0100- Seal - Oil, Rear Extension (Transmission) D22 '00+ KA24DE 32870-V5003- Socket Assy - Control Lever (shifter bushing) S13 32862-V5001- Boot - Control Lever (inner shift boot) S12 38342-P9000- Seal - Oil, Differential Side Z32 non-turbo 38440-N3100- Bearing - Differential Side WD21 '90-'93 38189-21G00- Seal - Oil, Drive Pinion WD21 '88-'90 38120-13210- Bearing, Drive Pinion, Front Z32 non-turbo 38120-10V00- Bearing, Drive Pinion, Rear Z32 non-turbo 39711-73L00- Joint Assy - Inner (rear CV joint) Y32 43210-AA000- Bearing - Rear Axle, Inner no 43206-01U00- Rotor - Disc Brake, Rear Z32 '90 40210-33P02- Bearing Assy - Front Wheel Z32 40206-04U00- Rotor - Disc Brake, Front no 54524-01U67- Link Complete - Front Suspension, Upper RH no 54524N 54524-01U67- Link Complete - Front Suspension, Upper LH no 54500-01U01- Link Complete - Transverse, RH no 54500 54501-01U01- Link Complete - Transverse, LH no 54590-01U25- Extension Complete - Knuckle Arm, RH no 54590 54591-01U25- Extension Complete - Knuckle Arm, LH no 56112-A0100- Bush P11 56112 54618-56S11- Rod Assy - Connecting, Stabilizer S14 56112-V0100- Bush P11 56112+A 54468-01U00- Rod Complete - Tension, Front Suspension no 54476-35F20- Bush - Mounting, Tension Rod G50 54613-01U11- Bush - Stabilizer no 54050-01U11- Bumper Assy - Bound no 43252-30P00- Seal - Grease, Rear Hub Z32 non-turbo 55157-33P00- Bush Z32 43052E 55152-35F00- Bush G50 43052D 56219-33P00- Bush Z32 43052F 55130-32P00- Link Complete - Upper, Rear Suspension Rear Z32 8903 - 9008 55130M 55120-71L00- Link Complete - Upper, Rear Suspension Z32 8903 - 9006 55120 56113-33P00- Washer - Rear Stabilizer S13 56113M 54612-35F00- Bush - Rear Stabilizer Z32 56243+A 54612-01P00- Bush - Rear Stabilizer Z32 56243 55501-35F00- Arm Assy - Rear Suspension, RH Z32 non-turbo to 9006 55501 55502-35F00- Arm Assy - Rear Suspension, LH Z32 non-turbo to 9006 55502 54613-71L10- Bush - Rear Stabilizer S13 56243+B 55490-01U00- Damper Assy - Dynamic, Rear Suspension no 55475-35F00- Stopper - Member Mounting Lower S13 55475M 56217-71L00- Bush - Rear Shock Absorber P11 55154-30P00- Ball Joint Assy - Rear Axle Z32 turbo 55114-39F10- Link - Lower, Rear Suspension S13 55114+A 55114-39F00- Link - Lower, Rear Suspension S13 55114 48203-39F25- Boot Kit - HICAS Actuator S13 36530-71L00- Cable Assy - Brake, Rear Right no 36531-71L00- Cable Assy - Brake, Rear Left no 46011-30P25- Piston Kit - Tandem Brake Master Cylinder no same as GT-R 46010-04U20- Cylinder Assy - Brake Master no Three different brake master cylinders listed - check first 48080-50M11- Joint Assy - Steering, Lower KN13 49110-04U00- Pump Assy - Power Steering no 49200-04U00- Gear Assy - Power Steering (steering rack) no 49271-04U00- Rack Assy - Power Steering no 48521-72E00- Socket Assy - Tie Rod, Inner P10 48520-71L25- Socket Kit - Tie Rod, Outer no 49365-10V26- Seal Kit - Oil, Rear Housing (of steering rack) B14 49277-42L00- Seal Set - Piston Z32 '90-'92 49297-10V25- Seal Kit - Housing, Power Steering Gear U12? 48203-10V25- Boot Kit - Power Steering Z32 22433-60U01- Coil Assy - Ignition G50 '91 does not include protector 22020-05U00- Transistor Ignition Unit no same as GT-R 23731-79S10- Camshaft Position Sensor no two listed, check first 25080-89903- Sensor - Temperature Z32 25080X 25070-55S60- Sensor - Oil Pressure Z32 '90 25085-89900- Sensor - Boost Z32 23100-59S01- Alternator Assy no 23300-20P00- Motor Assy - Starter no 23343-20P00- Switch Assy - Magnetic (starter solenoid) B14 '94 GA16DE MT 25567-71L01- Body - Combination Switch no 25570-71L00- Switch Assy - Mirror Control no 24345-51E60- Cover - Connector (for battery connector) P10 24080-01U00- Cable Assy - Battery Earth no 24077-01U00- Harness Assy - Engine no 24022-F6100- Wire Assy - Fusible Link F31 24022 24022-55S60- Wire Assy - Fusible Link no 24022+A 24010-01U13- Harness Assy - Main no 25560-02U00- Switch Assy - Combination no 25260-01U00- Switch Assy - Wiper no 25260P 25260-01U10- Switch Assy - Wiper no 25260PA 25290-01U00- Switch Assy - Hazard no 25160-01U00- Switch Assy - Lighting no 25350-01U00- Switch Assy - Rear Defogger no 25540-01U22- Switch Assy - Turn Signal no 25450-01U10- Switch - Sunroof no 25401-04U00- Switch Assy - Power Window, Main no 25431-01U00- Switch Assy - Power Window, Assist no 28515-01U00- Amplifier Assy - Auto Power Window no 28511-01U01- Amplifier Assy - Windshield Wiper no 28475-01U00- Sensor Assy - Steering no 26025-01U00- Housing Assy - Head Lamp, RH no three kinds listed, check first 26075-01U00- Housing Assy - Head Lamp, LH no 26719-C9946- Bulb (headlight) G50 '91-'93 26011AD 26124-01U00- Body Assy - Combination Lamp, RH (front) no 26129-01U00- Body Assy - Combination Lamp, LH (front) no B6554-04U00- Body Assy - Combination Lamp, RH (rear) no B6559-04U00- Body Assy - Combination Lamp, LH (rear) no 26552-04U04- Rim - Combination Lamp, RH (rear) no 26557-04U04- Rim - Combination Lamp, LH (rear) no 28930-01U00- Nozzle Assy - Washer, No. 1 (driver's side) no 28931-01U00- Nozzle Assy - Washer, No. 2 no 28970-01U00- Nozzle Assy - Rear Window Washer no 28920-71L10- Pump Assy - Washer no 27140-71L10- Core Assy - Front Heater U12 27220-91L00- Motor & Fan Assy - Blower P10 21410-04U00- Radiator Assy no 21501-04U00- Hose - Radiator, Upper no 21503-72L00- Hose - Radiator, Lower no 21430-01F01- Cap Assy - Radiator B13 48470-04U00- Cover Set - Steering Column no G2716-89901- Dam Rubber - Sealant S13 72750-04U10- Moulding Set - Windshield no 72712-05U05- Glass - Windshield no 72725-04U10- Fastener - Moulding no G2716-89902- Dam Rubber - Sealant (rear window) D21 79780-04U10- Fastener - Moulding no 79712-04U17- Glass - Rear Window no 79750-04U10- Moulding - Rear Window no 80730-F6100- Motor Assy - Regulator, RH S13 80731-F6100- Motor Assy - Regulator, LH S13 80720-04U00- Regulator Assy - Door Window, LH no 80721-04U00- Regulator Assy - Door Window, LH no 80300-04U00- Glass Assy - Door Window, RH no 80301-04U00- Glass Assy - Door Window, LH no 83306-04U10- Glass Assy - Side Window, RH no 83307-04U10- Glass Assy - Side Window, LH no 96365-35F00- Glass - Mirror, RH Z32 96366-35F00- Glass - Mirror, LH Z32 96321-01U00- Mirror Assy - Inside no 10101-73L25- Gasket Kit - Engine Repair no 11042-72L25- Gasket Kit - Valve Regrind no 12279-42L00- Seal - Oil, Crankshaft Rear no 11121-42L00- Gasket - Oil Pan no 11044-58S01- Gasket - Cylinder Head no 13270-58S01- Gasket - Rocker Cover no 13270-58S11- Gasket - Rocker Cover no 15255-40F00- Cap Assy - Oil Filler B13 w/GA16DE 11220-02U02- Insulator - Engine Mount, Front no 89-'91 11320-41L03- Insulator - Engine Mount, Rear no 13231-58S12- Lifter - Valve no same as twin-cam CA engines 13070-73L00- Tensioner Assy - Belt (timing belt) no 14035-72L10- Gasket - Manifold (intake manifold to head) no 14032-72L00- Gasket - Intake Manifold (intermediate) no 14036-58S00- Gasket - Exhaust Manifold no 14415-V5300- Turbocharger Inlet Gasket Z31 turbo 14445-V2700- Turbocharger Outlet Gasket no 14465-26E00- Gasket - Inlet Tube (turbo compressor) Z32 turbo 8907-8912 15196-P7600- Turbocharger Oil Outlet Gasket Z31 turbo 14401-72L26- Turbocharger Gasket Kit no 15010-79S05- Pump Assy - Oil no 13510-19V00- Seal - Oil, Crankshaft Front no 22620-02U00- Throttle Position Switch no 16175-79S00- Gasket - Throttle Chamber no 22670-72L02- Regulator Assy - Pressure (fuel pressure) no 25060-01U00- Sender Unit - Fuel Gauge no 21010-42L25- Pump Assy - Water no 17042-73L02- Pump Assy - Fuel no 17251-79915- Cap Assy - Filler B12 BCNR33 Suspension part numbers 54618-05U00- front anti-roll bar link (goes on the end of the roll bar) 40160-AR510 front inner ball joint 40160-05U00 front outer ball joint 54613-01U11 front anti-roll bar bush 54614-05U00 front anti-roll bar bracket R32/33/34 Wheel bearings 40210-05U00- Front 43280-AA3001- rear 43281-AA3001- rear Hub seals 40232-33P55- front 43252-40P00- rear R34 CAS- 23731-5L300 Updated 3rd, 4th and 5th gear trans part (R32-R33) 32606-30P10 Coupling sleave 32251-30P14 2nd gear 32604-30P60 ring 5th 32261-12014 3rd gear 32604-30P61 ring 32811-05U10 shift fork 32611-AA510 Coupling sleave 32609-70L15 Shifting insulator X3 32201-05U71 Main drive gear 32604-40P61 ring 32605-30P11 Hub 32603-30P00 Spring shifting X2 32212-AA504 Counter gear 32230-054U24 First gear 32137-AA500 Plate 32341-30P04 Over drive gear ( 5th gear ) 32245-30P60 Reverse gear 32220-30P60 Reverse gear 32614-30P60 Ring 32615-30P60 Shifting insulator X3 32214-01G21 Corn counter 32616-30P20 Coupling sleave 32282-30P61 Reverse gear 32320-VB361 Shaft 32139-VB300 retainer 32312-30P24 gear 32320-VB361 shaft 32139-VB300 retainer should i sticky it?
I would agree this is the most likely scenerio that happened.... For the record before anyone starts Why did you sheap out on a filter crap... it wasnt that at all. To tell you the truth i wasnt aware that were such crap filters on the market. This is not going to turn into a pissing match about what filter i should have used. Closed end of story... DONT USE FRAM!!! I'm going to sticky this so people can read the info on the filters. thanks for all the advice guys.
Dude get rid of that ♥♥♥♥♥♥♥ piece of ♥♥♥♥ filter.... http://forums.hybridz.org/showthread.php?t=133446
Alright The Chef Is Back!!!!!
To tell you the truth i didn't buy it cause it was cheap i bought it cause it was the first filter i found that matched the one i had. SOOOOO I got some more info from insiders in japan that knew the guys that built this motor that it may or may not of had an issue before this with the same bearing it it was just replaced... yea just that one... So it was bound to happen. The ONE thing i learned for sure on a hi dollar motor... unless you built it yourself open it up and check all your tolerances!!! The crank is ordered. and working on getting one matching rod from HKS. then bearings and some gaskets and i will be good to go. turbo rebuid kit should be here any day
here ya go video is better plug in pan I say start it if you have oil in it :>
Best spot for Autometer oils pressure sensor ?
stony replied to Canadianz's topic in Nissan RB Forum
I would say replace the stock sender location. if it goes thru the ECU... it just goes thru it to maybe light a light or something nothing important if you are going to be running a gage anyways -
Well photo bucket is down and i cant upload pics to hybridz for some reason... I looked in the rb20 skyline FSM and it doesn't show it on the oil pan... my guess it may be a z31 thing and it look like either a low oil idiot sensor or a oil temp sensor. Either way it sits in a cup that is sealed and it doesn't look like it needs to be there in my pan. As in it wont leak oil if its not there.
Have you put oil in the engine???? Does it leak out of there???? I looked at my pan and there is some kind of sensor in it. when i removed it way back when it had 1 wire coming out of the middle of it and i just cut it off. i say put oil in it and start it... pics coming soon
i wonder if it just wasn't up to the extra volume that the JUN oil pump was putting out? either way i will not be using a fram filter again for the rest of my life!!!
Well, I'm not sure what caused this...it was either all the bearing material clogged the filter and made it fail ( not supposed to happen) or the filter failed send crap into the engine causing the #1 bearing failure.. not sure but either way here are some pics. What i saw when i pulled the filter. I had already cut off the top and removed the orange seal. After top was cut off. Seal moved out of the way
UMMMM how bout what oil filter for the rb26 ordered from nissan to save on special orders. I'm going to go with an oem filter since teh fram i used last time failed.
Its still snowing!!!!!WTF!!!
HMMM tyndago He does know alot BUT... seems to me that if you dont agree and buy something he is selling it's crap... everyone has an opinion and he tries to force feed his to everyone. Sorry me no likey
Today i wake up to this ♥♥♥♥!!!
Turbo is getting new bearings.
His userID is MJR on zeroyon.com.
