19
Everything posted by Gollum
doing a v8 conversion on a 280zx, couple q's
Gollum replied to gompers's topic in S130 Series - 280ZX
The only "issue" with the rear end is that the semi-trailing arm design is prone to squat. In drag racing this isn't the biggest deal in the world but in road racing the squat combined with body roll causes the rear end to want to steer outwards, which takes quite some getting used to... There's lots of rally cars with this design that have made it work, but less examples on the tarmac. And guys make 300hp to the wheels all the time with the L28ET, and I've never seen one brake anything in the back end, especially if you have the beefier turbo half shafts (which mate to corresponding hubs if I remember correctly). And these guys are making well over 300 lbs, if not more like 350, which is the realm a 5.7 liter NA V8 should be around with 300hp. Only difference is that the torque of a turbo motor hits a little softer initially while snapping the clutch on a V8 can introduce a lot of shock, even at low RPM. But I still don't foresee any issues. Just find a LSD R200 if you can, or weld it if you don't mind the drawbacks. -
It's all awesome stuff, but I think you might have a hard time selling it for 2k, and he's my take on it. Heim joints aren't expensive, just labor intensive to do well and takes welding skills. The brakes, though beefy, won't be to everyone's liking. They're huge, and I'm betting are quite heavy. The center fin design doesn't look terribly efficient and thus there's just a lot of wasted weight in the design, which every hardcore racer will care about. Anyone who's not hardcore is going to want something more blingy like 6 pot willwoods. The struts/coils will suffer the same fate I'm afraid, as hardcore racers know that struts that get used need to be rebuilt often enough, and springs are springs, and are a dime a dozen. And again, those that aren't studying strut dynos will probably want something with anodized threaded tubes. The REAL thing of value that I want more info on, is that diff arrangement. Looks like a modified perch for some other type of diff, and I'm really curious what type of diff it is that's pictured there. All in all, it MIGHT be worth $2k to the right person, and I can certainly agree to that if we're talking about the right time to the right buyer. Ebay? I'd expect it to go for $500 min $1k max.
240z, 260z or 280z, chassis/body differences
Gollum replied to Teekass's topic in Brakes, Wheels, Suspension, and Chassis
Nope, it's impossible. Never been done. ....aww come on, I had to. Yes it can be done, but will require some grinding on the chassis to make things fit nicely, and if I recall correctly might require making some custom brackets. The main issue is that the front nose area of the chassis itself was changed, not just the bumper design and such. They added serious reinforcement to hold that heavy bumper way out there, and in the process made changes that make it difficult to just slap a 240Z bumper and lights on there. But yes, it's definitely doable. There's hundreds, if not thousands of people that have done it. -
They reason I like the 260z/early 280z is that in all reality they're NOT considerably heavier than the 240Z. That's a common misconception. Yes there's differences, but the weight that's truly "unremovable", is where you want it. The BIG differences in weight ARE removable. Just converting an early 280Z over to 240Z style bumpers or even just running bumperless will get you really close in weight to the late 240Z. The 260Z has virtually the same chassis as the early 280Z, but you also get the benefit, if you have an early 260Z, of the lighter bumper arrangement and being very easy to turn into a 240Z visually. All in all, most changes were making the cars BEEFIER, which I like. My '75 weighed 2460 last I weighed it, and it's got the stock turbo manifold + turbo + stock downpipe. Those are HEAVY bits. I've seen plenty of show car early 240's tip the scales over 2300lbs... But I've got the R200 and a stiffer chassis to boot. And not to mention that the 280Z and 260Z can be found for a few less dollars because they're not as desirable to the collectors... I'm sure that right now my car is down under 2400 lbs, and I still have a steel hood. I'm curious though if I might even be under 2300 lbs already, as gutting my doors seems to have shaved a LOT of weight. For what I'm building, it really doesn't matter if I start with a 240Z or a 280Z, but I'm going to put off doing a cage as long as I can, because that will inevitable end up being a "how much do I tube the chassis" never ending trail. So until I do go that route, the extra mass of the actual chassis itself is very welcome.
The main issue with razor blades has to do with technique, not the tool itself. You need to keep the blade FLAT, and since they warp easily that means you need to keep the pressure minimal. This also means you have to avoid getting too much of the blade off the edge otherwise it will again... warp, and then gouge the corner of the edge you were running off of. I've scrapped several heads with just razor blades and I'm not sure I'd do it any other way unless I had access to machine shop type tools and could take just a .001 or less off. But even in that case you'd want to get it as clean as possible first so you can verify how clean it is. I'd be careful with ANYTHING assisted, be electric or air. Any type of grinder will have the ability to create low spots. The rule of thumb in this realm is that if it's EASY to get the crud off, then it's too EASY to take metal off. You're looking for something that's more of a "buffer" than a "sander/grinder". Wire wheels are a big no-no. I haven't tried the mentioned plastic wire wheels, but they sound promising if used right. I'd still hook it up to something variable speed like a dremel to be safe though.
260Z = best S30 chassis imo. Nuff said I think. Other than: Post a link to that cars thread once you get it started EDIT: Sorry, there is no best. But I'll still say that the 260Z is a least hassle chassis for those of us trying to go fast in the S30 chassis.
Sweeeeet. I give a big thumbs up to the S12, and even more so it's not the STOCK turbo CA... The DET motors are certainly interesting and it's sad they don't get more attention.
The real question is: If its just a parts car, do you have room and time for it? If so, buy it no matter what.
Goals Goals Goals Goals If we don't know your goals for the build how can we actually help? Is this a street car? Will it see track use? What kind of track use? What kind of budget are we talking about? What kind of level of performance are we talking about? Fast as a new mustang? Fast as a Corvette? Fast as an enzo? What's your experience level? Have you done engine swaps before? Can you weld? Rebuilt a motor before? What access to tools do you have? Have a cherry picker? Welder? Grinder? Decent Bench? Assortment of jacks and stands? The list goes on here... JohnC's response is quickly becoming a drone response. I almost think he might have a script that makes that post for him... And there's a GOOD reason why. For any of us to make the decision of which engine to go with for you is WRONG. That's like having us tell you who you should marry. It's YOUR choice to be made. Sure one girl might have the goods in bed, but the other one might cook, clean, AND make decent money... We can't tell you which is "right". Now, all that said... ANY of the datsun longblock combos, including your stock '79 getup will make an EASY 300whp turbocharged. And that's without any porting, aftermarket cam, special intake, etc. Basic list of parts I'd suggest: Turbo manifold Turbo (T3/T4 hybrid works well for a street setup) 300cc+ injectors, 400+ preferred Any 'ol intercooler that fits Turbo intake will make integration with HVAC easier 36-1 Trigger wheel + Sensor MS 2, or 3 Coils (LSx work great, or EDIS-6 is fine too) MS Wire Harness Laptop with serial port Manual Boost Controller That's most of what you'll want to get started. It's important to not even consider using the stock EFI to turbocharge your current engine. The ignition timing will be WAY wrong and there's no good way to fix it without computer tenability. The stock turbo dizzy is easy to hookup to MS allowing you to use the factory coil (as long as you have the turbo vehicle's ignitor or convert to a GM HEI box). The downside is that the turbo dizzy is getting hard to find for cheap, and you can easily just install a trigger wheel and sensor and have something that's a cleaner install, possibly cheaper, and much more reliable of signal. But, if you have very little tuning experience and it kind of scares you, just buy the RB or SR, whichever you prefer. They're both fine motors. They'll make power with much less brain input.
You can always convert it. I know guys that have converted the same car back and forth a couple of times... Easiest, though not always the cheapest, is to just find someone getting rid of a manual S130. Finding all the parts piece meal can be quite annoying, especially if you're trying to do the conversion in a weekend.
262 isn't terrible for 12psi with no water/meth on pump fuel. What intercooler setup does that car have again? That car has certainly made some decent power in the past, hopefully you can only improve on it.
Where the hell is the datto in this pic? ...aww just kidding. Nice cars all around, even the fobra. I'm personally partial to manual transmissions, but that's because an auto never really does what I want, when I want. To me they're only useful for going really fast in a straight line, and consistently.
So sad. Not only does this "other V8" section get very little traffic, but Z32 stuff doesn't get much attention either! I'm sure 90% of us think this project is awesome, so don't feel like we don't love what you're doing!!! Keep the updates rolling.
I won't deny that's a possibility, and I'd rather not get into the politics of it either. But it SHOULD be noted so that people understand, there were more Ford Model T's sold as alcohol cars than gasoline cars. That's how prevalent alcohol was back then as a motor fuel. Alcohol was made by most farmers at the end of a crop cycle with the excess that couldn't be sold or stored, especially if it was rotting. Thus alcohol was easier and cheaper to find than petroleum fuels. When oil became big oil alcohol disappeared almost overnight with the lower cost. As the oil barrel price is high, alcohol becomes viable again as long as agencies "stay out of the way". If I chose to get the required permits I could make alcohol as a fuel for under $1.50/Gallon. Standard 100% markup and I'd be right near gasoline price per BTU. Thus, I personally feel that for some, this will always be a viable fuel, and we all know there's been an alcohol class in NHRA for a LONG time, and it ISN'T going anywhere anytime soon. As stated before, it's history in the automobile industry and racing industry is actually very deep with a lot of heritage. The whole "green fuel" thing is more of a political move. There's nothing "new" about it. Other than corrosion obstacles (which ARE able to be overcome with relative cost effectiveness) there's not a single "bad" thing about it. I personally hope E85 gets killed off in favor of an alcohol fuel that DOESN'T contain gasoline, but that would require manufactures to design engines with enough compression to not be gasoline compatible.
Or you can run E85 which is now commonly available in much of the country, and really I would understand completely doing a "mild" street L motor with 11:1 with that head if E85 is the intended fuel. If the head can be found for cheap, that's a pretty darn cheap way to make a decent little motor for not much coin. You'll spend more money converting your fuel system than you will on the longblock rebuild/assembly costs. I only bring this up because E85 wasn't nearly as common just 5 years ago, let alone almost 10 years ago when I joined HBZ. In today's world, a budget E85 street motor might make sense, while 10 years ago I'd say you were a bit strange for doing such a thing.
If runner size can be RPM power specific, and if exhaust manifold primary size can be RPM specific, why can't valve size? I can certainly agree if the statement is made that the larger valves won't hurt low end enough to matter to most people. And I agree that valve unshrouding is far more important than actual valve size. But at the end of the day nissan used smaller valves in certain combos for a reason. You see the same thing in the V8 realm to an even greater degree. You can find two SBC motors from the 60's, one from a truck, and one from a muscle car, and they'll have radically different valve sizes. They were designed around two totally different power bands from the ground up. At the end of the day, I say arguing about valve size is never a reason to not "get it done". Don't have much cash? Reuse the valves you got. Going all out? Spend the time to put in larger valves and unshroud as much as you can with them. But never flip flop back and forth if it's delaying your project.
I think a large part of that debate is that it can really depend on the build. If you're going for 300+ NA HP then larger valves never hurt. If you're building a street motor that will see mostly sub 4k rpm 95% of the time then maybe the smaller valves are fine and will actually help down low. It can also depend on the displacement. Is it going a on 2.4 bottom, or a 3.1 stroker? Changes the topic entirely. There is no best, no magic bullet. That makes it hard to definitely say which valve size is better.
Hmm... $8.19... I can't make one out of wood for that price if you consider labor at min. wage.... Then again, last time I needed one I just split a piece of wood down to size in about 5 minutes and tapped it in... Definitely going on my wishlist though.
Nissan's published figures aren't in question, and we're seeing at least a .03" difference between what was measured and what should be there... I'd call that significant.
Oh, I should mention, that if you've really got any of the "A" cams in there, and you're only reading .385 total lift on the valve then you've either got a severely worn cam or you need to work on your rocker geometry quite a bit... it really shouldn't be that low at all.
Looking at a 1972 240Z, what do you guys think?
Gollum replied to boardkid280z's topic in S30 Series - 240z, 260z, 280z
That car is save-able. But.... that's a butt ton of work. That's right up there with the "rust-free" car that mull got himself into. LOTS of work needed. And like morbias I gotta ask... this is an upgrade??? I'd look for a clean shell somewhere else, and fly to it if need be. Hell, if you think about it, the money you'll spend getting a clean running Z home is FAR less than just a FRACTION of what time you're going to have to put into a shell like that. Example: Say I pay myself $5 an hour, which is probably less than the minimum wage just about anywhere in the USA and is probably even less than what the illegals make around my neck of the woods. It'll only take about 200 hours to have paid myself $1,000. So lets do a basic estimate of hours. Get shell home, in the garage, and parked where it's going to live for the next millennium: 5 Strip interior and put worthwhile pieces in bags, bins, etc: 10 Gut doors: 10 Remove bumpers, hood, airdam, hatch, etc: 10 Pull Engine: 10 Put car on jacks and remove easy suspension parts: 10 Tear down suspension into pieces: 10+ (spindle pin...) Remove Dash: 5 Label Chassis wiring: 5 Gut chassis wiring: 5 Remove glass without breaking: 20 Remove fuel tank, fuel lines, brake lines, etc: 10 Remove other odds and ends, ebrake cable, master cylinder, etc: 15 Total: 125 hours You might just about have a clean chassis ready to be stripped now. Each of those 10 hour chunks are good weekend projects, so realistically you're looking at half a year to tear down a chassis if you're doing it casually on the weekends. The guys that do it faster are spending every evening they can on it. You're going to then have to have the chassis blasted (unless you want to go the slow way, by HAND) to make sure you've found the extent of all the rust. Then you still need to do all the rust repair! Hours of cutting, grinding, measuring cutting new pieces, trimming new pieces, welding new pieces, grinding welds, filling in weld seam, sanding, filling, sanding, painting. Once all that's done you get to reinstall! And remember, this part will go MUCH slower than the removal. You're going to be much more careful and pay attention to all the details. I'd say 200 hours is a "middle of the road" estimate for an average "no major mods" re-assembly of a car from the chassis-up. But.... you could just find a car that is in good enough shape to not even worry about tearing down. Or find one that someone has already done all that. There's also always a clean shell somewhere that has either just been sandblasted, ready to be sandblasted, or has even had it's rust repaired after being sandblasted. And they sell for a SONG!!! Last one I saw was around $1.5k and it was a clean chassis that had just been blasted and suspension put on just to roll it around. If you look at the work involved, that's a DEAL and I bet the owner just wants the project gone, which means for that price he'd probably throw in parts, or lower the price if you pushed him. End of the day, I just don't see the point in buying a car you plan to go through all that unless you are retired and can spend the 60 hours a week on it, and have it done in a few months. Otherwise, be wise with your time (which IS money, worth every penny to your family. Learn to spend it with them, or spend it on things for them.) and just save time in the long run by spending more money now. Money isn't terribly hard to come by (says the man who's signature says saving up for MS for the last 2 years....), it's how we choose to spend it that makes it more or less available. If you buy this car, you'll be throwing pennies at it constantly from start to finish. Or you can spend the money now and not run into so many "gotcha's" as you go along. -
Real men don't run windows. Saves quite a bit of weight. Common' man, it doesn't get THAT cold up there.
Valve lift is different than cam lift, and you're going to get different readings than what is advertised as cam lift on websites, catalogs, etc. In the pushrod world this is well understood, and people all understand that catalogs are just showing you "cam" specs on cams, because that's what they are... cams. But then you've got your rockers which can be run at various RATIOS, giving more or less aggressive valve lift. Even the datsun design has a bit of ratio play in the geometry and even how the valve train is setup can effect the overall lift of a cam.
Some might say that the 4.11 gears might actually help make 1st gear easier to take off in. The most important things in any car to keep the car easy to take off is #1, how heavy the flywheel is, and #2 how forgiving the clutch material is. Just practice. It was kinda funny, one person I taught to drive stick was having a hell of a time getting it down, but once I explained that "it's OKAY to let the clutch slip a bit while the car gets moving"... he was fine. He was used to bikes where you basically go from off to ON with virtually no slip. In a car, slip isn't just okay, it's a necessity (to an extent). In a car like a V8 mustang, you can basically just ease the clutch out in 1st gear with no throttle and the car will take off just fine. But that's an engine with lots of torque and a heavy flywheel. I've driven porsches that were just razor sharp to get used to. Insanely light flywheel, HEAVY clutch engagement, and not nearly enough torque to be kind. The result is a car that you have to give substantial throttle, but time it just right with initial bite. Throttle too soon before clutch grabs and you will either eat through the clutch, or eat through the tires. Too late and you stall. The key to driving any stick, is learning that place where the clutch just starts to bite. In my ZX it's so high (right now, at least 80k+ on this clutch across 15+ years) that sitting in traffic I never go to the floor to disengage. I just put the weight of my leg down and it's enough to hold it just past where it needs to be, then when I want to get going again I just lift right to where I know it's going to grab and start giving it throttle as I ease it past engagement. It's all about learning this dynamic of rolling the throttle on, while rolling the clutch out. You'll get used to it. Practice makes perfect.
I kinda wish you hadn't just said that. The 3.8 is NOT a rev happy engine. It's a low RPM brute. It's a 90 degree V6 which means it's inherently imbalanced. Combine that with the fact they just plain never built them to rev and you've got an engine set against you when shooting for high RPM. The stroke also isn't the shortest in the world, but that's not necessarily a problem that can't be overcome with good pistons. There's also a common "long rod" swap to use longer rods with pistons that have a shorter pin height. Helps reduce stress on the rods and will help the engine in the upper RPMS. But it'll still make 500hp before 5,500 with force induction, and lemme tell you, that's FUN! I still hold that the 3.8 would be lighter than the VG30, and the VG30 isn't far off in weight from the VQ at all. It'd definitely be more compact than either. But if you want something that revs to the moon, is small and compact, and affordable.... ...it's called the L series. You can even build a 170ish rwhp motor for under $1,000 if you're really careful and take your time. And no swap costs... They aren't REALLY that heavy since it has a teeny head. Not extremely unique though. Now that you threw the rev argument in there it'll be a tough nut to crack. Lemme think about it and come back to this thread.
