78zlt1
Everything posted by 78zlt1
  1. Do you mean Front Frame rails? ( not subframe connectors, I think the two terms are interchanged alot , and causes alot of confusion , at least for me.) Pete has good info for subframe connectors (link given above), that is what I used to build mine , as for front frame rails , I have a post http://forums.hybridz.org/showthread.php?t=94710 where I made mine, and the drawings I made are available in the post as a PDF file. This is for a 78 280z, the 240z's may be different.
  2. Its a floor temperature sensor for the emissions system it connects to a relay under the passenger seat
  3. That may work, It really comes down to what you feel is safe for you and your passengers. Box tube is stronger than channel , and I'm by no means an expert in chassis construction. take pictures and post your progress.
  4. That is some beautiful work Viperredls1z! Please tell about the fittings you used! I never found any that I thought would work, that put my project on hold. Looking forward to your report after everything is operational Did you powdercoat the crossmember?
  5. Actually they do protrude thru the floor , they are the same 2X3 " .093 wall reqtangular tube that I used for the subframe, and they are welded all around to the subframe. I found this pic of the Xmember tack welded to the subframe ( I've since fully welded them in) this view is the drivers side from inside the car. Make sure your cross member is very solid. Alot of bad things will happen very quickly if this comes loose.
  6. 78zlt1
    XMEM_IN
    From the album: FRAME
  7. The tans xmember is approx 11" back center to center from the original xmember and center to diff mounting flange is approx 25.5" Greg here is a PDF of the parts ( see attachment ) Its what i used to make mine, I use Unigraphics at work and design my stuff after hours, we don't have a PRT to DXF translator license so I cant distribute models. I need to stress that these dimensions are for my setup , you will have to change some things to work for you depending how your sub-frame connectors are installed. 280Z_T56_XMEMBER.rar
  8. Awsome job , Looks great , I'm jealous So what headers are you using?
  9. If I were building a track car I would most likely not do it, I would say the weight is about the same just from memory of moving them around, I haven't weight them. I found it on Ebay , took awhile but they are out there. As for why? Well this Z is a project , I'm not going to race it , It's not my daily driver, It's a hobby , a challenge to learn things, basically I'm doing it to see if I can. I'm in no hurry to complete it and when I'm done I will have a sporty fun to drive summer car that I can say " I made it" .
  10. Heres the Specs on the Subie Forester Rack :
  11. 78zlt1
    forest_rack
    From the album: STEERING
  12. That is the work of someone with alot of ambition and no taste.
  13. I rebuilt my front frame, here is the thread : http://forums.hybridz.org/showthread.php?t=94710&highlight=save+zee
  14. I believe the 914-6 came from the factory with the flat 6. That would be a fun car..... *Bart you beat me I type tooooo Slowwwww......*
  15. Datsun : Z-Series LOW RESERVE 1971 Datsun 240 Z VIN Number: 11111111111111111 Wow you sure got a weird Vin number there..........
  16. Should just be able to remove the vanes/ wipers , from inside the pump. Whoops didnt read all your post Bartman
  17. Sounds kewl , my car wont be done till summer of 2008 at my current rate , but I would like to see everyone elses rides
  18. 78zlt1
    rtm2
    From the album: Drivetrain
  19. 78zlt1
    xmember3
  20. 78zlt1
    xmember2
