                Posts2009
                Days Won3
Everything posted by Dan Juday
	"Puller" fans are more efficient. It has more to do with the properties of air low. Your get better flow over a heat exchanger (in this case a radiator) by inducing a low pressure over the back side and drawing the air through it. Trying to "push" the air through the front creates much more turbulence and much less actual air flow per unit of energy consumed by the fan motor. If you look at any industrial heat exchanger, like say your home air conditioner, you will see this is how they are all designed. It's just the characteristics of fluid dynamics. With cars though, things like proper engineering take a back seat to style and packaging. Oh, and having the obstruction of the fan assembly in front of the radiator isn't any worse than having it behind the radiator. Wherever it is in the path of the air flow it will be a restriction.
	I would encourage you to make a mold. You might be able to sell one or two if the design is a hit. But make the motivation for your effort your car and not hopes of making money. I like the idea of options. I have a fiberglass dash cap that was designed for the Tomahawk Z kit, I like the fact that it is different and gives me a place to mount another gauge.
	  My car rides like a skateboardDan Juday replied to SUNNY Z's topic in Brakes, Wheels, Suspension and Chassis 9. Spring rates.
	That's the only German car that churns my juices. The wife loves them too. She likes the coupe and would be happy with the V8. Much cheaper but still not close enough for my budget. When I first saw one in person I was surprized at how small the car is. They look much larger in pictures, at least to me.
	Just my experiance, yours may vary: I've lived in California all my 50 years and I have never run a front plate on any of my personal cars and trucks. I just think they look ugly. I always keep the plate somewhere in the vehicle and I have a prepared story for the officer, "I've ordered the mounting bracket but it hasn't come in yet". But I have NEVER been been bothered about it from any type of officer. Never even asked. I've been pulled over for other infractions (it's been quite a while since the last time) but none were ever interested in checking my front plate.
	+2 Just tell me where to send the check. I'm also up for replacements for the interior plastic trim panels. And the rear interior quarter panels with the vapor tank bump removed.
	  Z Race Products coil overs and camber plates.Dan Juday replied to sidewaz's topic in Brakes, Wheels, Suspension and Chassis You will want to reinforce the underside of the top of the strut tower with a plate similar to the one on top. Otherwise the entire weight of the front of the car is held with the four nuts on each camber plate. This was discused in another thread on GC camber plate installs. Otherwise it looks like great stuff.
	  Sectioning question with BZ3125 strutDan Juday replied to blueshark123's topic in Brakes, Wheels, Suspension and Chassis Things change when you lower a car. Things like camber, caster, roll centers. The lower you go the more they change. I'm sure, for liability reasons, T3 is doing a little CYA by recommending a maximum 30mm drop.
	  Sectioning question with BZ3125 strutDan Juday replied to blueshark123's topic in Brakes, Wheels, Suspension and Chassis If you have adjustable coilovers and your plan is to lower the car it shouldn't be an issue. Now, there are always other issues that come with lowering but that is considered part of the deal.
	PM sent.
	  Next Gen Z will be lighter & cheaper! Good or Bad?Dan Juday replied to ArchetypeDatsun's topic in Non Tech Board That "mini-Z" is not pretty. Maybe the Chinese will like it, it's being built for them and other emerging markets. We likely won't see it, thank God.
	Rubber can indead seriously abraid metal. I work on belt driven blower systems (HVAC) and we replace sheaves all the time because the rubber belts have worn out the steel sheaves and pullies.
	Just to confirm Leon's assertion: That is a 1972 and later R180 bar. I whipped out my JTR book (7th ed. page 6-5) and your picture #2 matches the books picture exactly. And all S30's after the diff-shift rearward had the curved rear crossmember. Might be worth your while to just pick up an R200 bar while you have everything apart. The enlarged holes in the bar you have look like they may have be done with a torch. Not unheard of since the bar is spring steel and tears up drill bits. If it was done with heat that bar is likely weakened in that area.
	  Carbon Fiber REAR bumpers on 75+?Dan Juday replied to str8pipez's topic in S30 Series - 240z, 260z, 280z There is a difference in the rear quarters as well. The 240 has recesses that the bumper ends tucks into on each side. The 280 is smooth sided other than the mounting holes. This may be what the OP is referring to.
	www.reactionresearch.com And John is near you in Scottsdale.
	  Ground Control Camber plate install methodsDan Juday replied to svMike's topic in Brakes, Wheels, Suspension and Chassis Once you mount them underneath the top side of the plates are going to get all buggered up and you won't want to show that. You could talk to GC and see if they would sell you another pair of bare plates. It wasn't that hard to fab up steel copies out of 1/4" flat stock. Heck, I did it with a sawmill, drill press, angle grinder, and a couple of files.
	  Ground Control Camber plate install methodsDan Juday replied to svMike's topic in Brakes, Wheels, Suspension and Chassis I made the misstake of bolting the plates on top of the slotted towers because I saw a picture with them mounted that way and the kit didn't come with any instructions. Pretty bone head for a guy who prides himself on his engineering skills. But I drove it that way for a couple of years without any problems. Just a street car and not really pushed very hard. When I finally stumbled on a thread here that talked about this issue I cringed at my stupidity. The problem was they look so good that way and so crappy looking when installed correctly. So, I was doing some other welding in the engine bay anyways, I fabbed up a couple of steel copies and welded them to the underside of the tower tops. A couple of slightly longer bolts later and now I can have the clean look of the anodized aluminum plates on top and the funtional steel reinforcements where they belong on the underside. Overkill and a little extra weight for a race car but mine is more show than go.
	I have one available but I'm in Nor-Cal about an hour south of Sacramento.
	  Looks like Michelle is selling her GTO replicaDan Juday replied to SpeedRacer's topic in Non Tech Board He's a she. (The owner is behind the ropes in the second picture.) And, as you can see by the incredible car she built, doesn't make mistakes. I'm waiting for her next creation. Wish I had the loot to buy this one.
	Well John's white so...
	Revisit the rear radiator mount idea. Install a Pantera hatch louvre/slot the flat section. Mount the radiator flat and louvre/slot the floor. Weld in some sheet metal to close off the radiator area from the cabin. Plenty of room for fans and helps shift some of the weight rearward. And score bonus points on the cool scale.
	  s30 Fiberglass tilt front clip i've googled for hrs...Dan Juday replied to vega's topic in Body Kits & Paint Really? Have you read much here? John Coffee, John Washington? Both excellent companies with great products and both are active site members.
	  V8 240z Z spring optionsDan Juday replied to DatsunZman04's topic in Gen I & II Chevy V8 Tech Board JTR (Mike Knell) doesn't sell springs so there is no monitary motivation in his statement. There is already a lot of good advice here. Miles advice is best of all.
	  R200 conversion from 90 300zx NA to s30Dan Juday replied to Nismodealer's topic in S30 Series - 240z, 260z, 280z Roseville is in NorCal near Sacramento. There is a good driveline shop in Sacramento I've used before. Check the phone book Nismodealer. You should have no problem.
