Here we go:
Straight six, wasted spark on a 7mgte, 6+2 config on Vems, problem happens with firmware 1.0.73, and firmware 1.1.70.
I foul my plugs in about 10 min of running, due to running pig rich. Plugs 2 and 5 are never discolored, simply covered in fuel. Plugs 1,3,4, and 6, are so fouled you could paint with them.
Injectors are getting signal, my LED fires right up when cranking.
Coil packs are getting signal, my LED fires right up when cranking.
Spark plugs are firing, I get spark from all 6 plug wires.
I thought maybe the coil handling 2 and 5 was only firing intermittently or something, so I replaced it (I have 6 spares ). Did not help.
I thought maybe I had connected my coil to a logic driver instead of a big boy driver. My rational behind this was that just because I get a spark, doesn't mean it's intense enough. I pulled wires 5 and 6 to compare their spark intensity (seemed the right thing to do), and they seem to be equal with any other spark from a running motor.
I noticed today that plugs 2 and 5, when I pulled them, had a little black, as if they were firing, but there was no soot.
To me, this means that the plug is firing, the injector is firing, the cyl is getting fuel, since the plug is covered in it, but it's not exploding and causing soot.
WTF is going on? Bent valves maybe? It seems like the most logical choice to me so far.
