I think its been a month now that I've had this problem. It all started after a night of tuning at 20 lbs of boost and getting the revs above 6k rpm. All went perfect, until the next morning while dropping it into 4th to take an exit. I felt a stumble. Also that morning my turbo (holset) started smoking. Rebuilt the turbo that week no more smoke but the stumble is still there.
Let me define the stumble. It feels like I'm hitting a rev limit. and seems to only happen above 14lbs of boost. But sometimes it does not happen at all. If I lower the boost to say 12lbs, the car will rev to 65k rpm. During the stumble the tack stays in place does not jump around, fuel psi builds and holds steady does not drop off, wide bands goes LEAN during stumble, but the injector pulse width and duty cycle hold steady.
Sometimes it will pull through, so rpm holds at say 48k rpm, fuel builds to say 50lbs and holds. But then boom the car takes off as though nothing was wrong.
I've changed the cap and rotor with Nissan parts. check the plug wire ohm's, new plugs. put a test light on fuel pump before and after the relay. test light on coil, neither losses power.
Nothing has changed from that tuning night a month ago. I've ohm'd the injector wires, signal wire from dizzy, TPS wire, put noise filters on all 12+ going to megasquirt. And I've rewired the CLT and IAT sensors with shielded wire.
I'm left thinking its my turbo? I rebuilt it but did not have it balanced. I've done that before on my other holset but I've checked EVERYTHING and thats what I'm left with?
