ZT-R
    4
Everything posted by ZT-R
  1. for the window crank i got 10 3/4" in from the front and 9 3/4" up from the bottom. BUT THIS WAS OFF THE DOOR ITSELF, NOT THE PANNEL. I would rather someone with a panel chime in.
  2. I didnt hook mine up and it ran fine, matter of fact i just plugged it in yesterday. Guess i should see if it works.
  3. Are you still selling it? Was that your manifold on ebay?
  4. Are these from the Z-Store? Sorry for bad pics. They appear to be fiberglass with a layer of carbon fiber on the outside.
  5. Hey guys, i dont have my intakes installed yet but driving my carn when i get into boost and let off, my blow off valve vents and then as the engine rpms are coming down the turbos sound like they are outgasing or something. Is this compressor surge or is this normal? I dont know if you will hear this with filters on it or not.
  6. yup, that gets signal when the key is in the start position.
  7. Very happy with the quality and fitment. You have to run custom axles with the R230 rear end. Gabriel can hook you up with the correct lengths, they are big beefy moser axles or something. I need to adjust the parking brake now that i have been using it a lot as it will not lock the rear at a slow roll. If i remember correctly you will have to use the rear cailpers on the opposite sides (leff goes on the right) and you need to trim the brake backing plate some to accomplish this.
  8. Well, I can hit my staples easy button on this one... Speedhut directly to pin 7 on the ecu and that is it.
  9. Provides vacuum to the valve covers which an "seal the piston rings". I have scavengers on my downpipe and a check valve, so as rpm goes up i get vacuum on the valve cover ports. See my build thread if you want details/pics.
  10. Will they be predrilled or to each his own?
  11. While on the flare subject has anyone used regular zg flares on the front and the bamf ones on the rear? Pics would be great.
  12. You move fast and you have a green thumb. Purdy flowers ya got there
  13. Rear diffuser would be awesome. As far as bang for your buck, i would do a pillar gauge pod. NO ONE makes one that fits. I would like to see -Dash (maybe with 1 more gauge in the center?) -Center Console -Doors. not just skins, lets ditch our rust depositories while we are at it -1 piece fender/headlight buckets -Side skirts like below. (well i will have to upload that later, i dont have the pic on this computer) but it is a rust color z with black wheels and has a very clean sideskirt on it that goes on the door, fender and rear quarter.
  14. Hey guys, I have some carbon fiber flares from the Zstore (at least i think they are from there). Are these things as wide as the regular ZG flares? i held up the rear and it seems like it will only give me maybe 1/2 at best. I saw the bamf ones but i think those are a bit wide for my taste.
  15. Hey guys i have a 72 240z and my sending unit is leaking out the center (not the o ring). I have speedhut gauges so i was wondering if there is a better sending unit i can put in there that will not oscillate so much.
  16. Looks good. I was thinking about getting the tab slides as they sit lower and i can hack up the stock mounts, i have a plasma cutter, mig, tig and a recipricating saw, so there is not much I cant do. Your pans look good.
  17. Nice job. Do you have pics of the interior with the seats installed?
  18. That doesnt make much sense. Sell the 25 and build the 26, it doesnt take long to build it. Just my 2 cents.
  19. Will they still attach with the body pins like oem?
  20. I dont mind if you overlay mine with carbon fiber.
  21. I would like to see this cut down like 1/2 or 1/4 inch all the way round (not as high) mainly just for venting as i dont like the vented inspection lid look.
  22. What color are the wires that do the high beam indicator (72 240z) i am thinking it is red/white but i cant seem to get a reading off it with my voltmeter, I thought it might be because i removed all the light bulbs?
