ZT-R
    4
Everything posted by ZT-R
  1. how about a triple or double gauge pod.... NO ONE MAKES ONE..... little bit of fiberglass and pow... no sweat.
  2. what kind of resins are you using on the dash? time for mine sometime.
  3. they do make a recirc adapter for that if you want one.
  4. hey wait a second is that red or orange... must be the lighting i guess to make it look red.
  5. looks good, I would recommend not doing a hood slide out of pure joy.
  6. guys.. i have the trans angled down 2.8 degrees and the flange on the r230 is up 2.6 degrees (technically i guess thats angled down, its higher in the front than the rear) and the driveshaft angle (angle finder on the shaft itself) is .2 up (higher at the rear). that should be like a 3.0 and a 2.8 operating anlge, but i still have a good vibration (no axles, tires or anything installed)... what am i doing wrong. I talked to T3 and they said they also a lower mount for the r230. currently i have mine shimmed down as much as i can (with full thread engagement on the mustache bar mounting bolts). suposidly the driveshaft is balanced, i do see 2 weights on it.
  7. the apexi ecu keeps MAF. still a bad thing about the 240z is that it is not a baffled tank, as long as you run a surge or a sump, should be fine, i opted for both
  8. looks good, i would rubber mount it then run a ground wire from the case to the chassis
  9. sad part none it is really gains performance but thanks i need some inspiration, now if i can find a chick that gives back and neck massages i'd be set
  10. interested in a entire chassis all cf with mounts for a rb26
  11. well i dont get how to use this multiquote thing, but thanks joel. im gonna put a vac gauge on it and see how much it pulls. i know it pulls a small amount at high rpm but thats under no load. R34 heavy duty RWD, maybe the weakest link in the build?? Its a Mckinney one. no it doesnt attach to the trans but you do have to pull the trans to remove it, not all the way out but the flange will not clear the bottom of the bell housing.
  12. +1 photo shop the hood and the buckets body color except for the inside of the bucket, leave that cf... wonder if that would look badass
  13. dp hits tranny here here and here i modified it some with a 5lb slede hammer and a vice so it fits but it still rubs, gonna take care of that when i start making the exhaust and hacking this dp up. not impressed with these parts except the oil pan that was/is incredible.
  14. oh the 77 mckinney mounts are different than the 240z
  15. yea, mainly steering shafts and sheet metal limit you.
  16. well another weekend down and nothing to show for it. Got the new downpipe installed, had to modifiy this one a little bit too. It still hits the transmission mount but im thinking of how i want to make a new one anyway so f that piece of ****. I measured the droop that the mckinney one has and its 1 inch drop from unweighted to weighted no wonder there is severe drivetrain vibes, turns out it broke my speed sensor when it drooped that much. anyone have one those those (red gear).
  17. Getting burned out but getting close to a good point in taking a break.I would be done if people would send me the correct parts. I feel like that Sarah Mclachlan song Spend all your time waiting For that second chance to get the right parts For a break that would make it okay There’s always one reason To feel like cussing someone out And it’s hard at the end of the day I need some distraction Oh beautiful RB Fuel seeps though my surge tank Let it not be empty And weightless and maybe I’ll find some place to do a burnout tonight haha, sorry I have not had my coffee yet this morning..
  18. might pick up a mph or 2 on the trap speed with all that clear looking good.
  19. i think my sister just bought me a megan GT one for my bday
  20. hmm that muffler looks loud...might be a good resonator for me though..... how much u selling hks for?
  21. what kinda muffler are you gonna run?
  22. yes i did that when i was polishing it... i dont have a pic of it though... looks like elite techs though.
  23. i could probably do that but that is gonna take me a bit longer... maybe after i get everything running real good i would look into something like that. I actually havent messed with CF i could do it out of fiberglass or something.
