  • Replies 148
Popular Posts
Well havent done much to my car but starting to again. Will get back to that later...   Recently I was working on a friends car.  He brought his RX7 FD LS1 to me to work on the exhaust and
More progress, not much but something.  Made a new bracket for the tension arm since the original bracket wouldnt fit my newly made frame rail. I started the downward bend to early and should had star
Posted Images
Thanks for your input and concern Tume. I too had thoughts about the engine having to much force on one side of the subframe. I didnt want to weld anything to the frames. I guess the only way to find out is to drive it for a little while and see what happens. I might could make something tieing the subframe to the sway bar mounts, those sway bar mounts are beefy. I just may think about doing something like that.
Link to post
Made the passenger side inner rocker panel.
Started with a flat piece of 18g CRS sheet  with everything marked up.
IMG 1449
What it looks like after. Still need to add in the seat belt mounting. Left extra metal around the so when it comes time to actually fit it, I can trim it to exact size.
IMG 1450
IMG 1451
IMG 1453
IMG 1454
IMG 1456
IMG 1458
IMG 1461
Next will be to make the supporting/tie in plates, Hopefully I can match the other side, should had made the passenger side along with the driver side at the time, but didnt think the passenger side would be this bad.
Link to post
As always, Sensational work even if you did rip off one of my idea's LOL
LOL, Keep your ideas posted, I may end up taking more, hehe.  Anyone is welcome to using any of my ideas, though so far, nothing is really all that custom/original idea, all so far mostly just remaking factory panels.
Link to post
Thanks Datz44, just takes some practice, Ive scratched numerous attempts at various stuff, I had help after lots of researching, reading, and watching videos to help achieve what I need.
Small update, got to work on it a little bit earlier today.
Got the passenger side interior rocker trimmed up and test fitted. Made the front tie in supporting plate, the stock on is actually not in bad condition, but I would like to match the other side though.
IMG 1501
IMG 1514
IMG 1516
IMG 1517
IMG 1519
IMG 1522
IMG 1523
IMG 1524
IMG 1525
IMG 1526
IMG 1528
Link to post
  • 4 weeks later...
A bit of an update, I will again describe first then just throw all the images at you like the last heavy loaded image updated post.
Starting where I left off from my last post, I made the rear end tie in plate. Worked on the rear end corner, the flanges from the inner and outer wheel well metal was all cheesed out.  Cut the rusted metal and replaced it like I did the driver side.  Tacked and welded the both front and rear tie in plates for the rockers. Welded a plate on with a nut for the seat belt mounting onto the passenger side inner rocker panel. Got everything degreased and ready with POR15 degreaser and prep and ready. Then painted everything with POR15 rust preventative paint. After sprayed on the weldable primer in the welding zones.  Welded in the inner and out rockers.
Before I welded in the Passenger side rockers, decided to go ahead and put the doors on. Good thing I did because for some reason the passenger side outer rocker was a pain to align. Thankfully the driver side aligned, even though I never put the door on when I worked on that side. Lesson learned, if you can, Make sure to have the door, fender, and the rear quarter on as best you can to align the rockers.  I know already, I will have to work on the fender to align with the rocker and door, oh well I guess.
Worked on both the driver and passenger side rear seat belt mechanism housing (not sure the proper name, hehe).  Also worked on the front driver and passenger side lower fire wall.  Got everything cut out, made, tacked and welded.
Then decided to work on the floor pans!! This was actually fun!!  I decided to try out the tape method template for the area along the transmission tunnel, then cut it out with a razor blade, then tape it on to the floor pans.  Worked pretty good, left some extra metal on when I cut the floor pans out so I could fine tune the areas that needed exact fit up.  Other fun part was making the front drive side and passenger side seat brackets. Wasnt able to use the stock ones as the shape of my floor pans were a bit different, also I hacked up my passenger side when removing the old floor pans with the plasma cutter.  Also if your wondering why the driver side seat bracket looks a little different from the passenger side with the beading on the top is because the original stock brackets were like that.  Gotta be a reason why they did it like that, so I copied...
Where I am at now:
Still need to work on cleaning up the seatbelt mechanism housing parts, going to sandblast them first, get it all coated and welded in.  Also still need to grind down the areas I welded so far flush with the surrounding metal. Then I can get the floor pans welded in and the seat brackets welded in aswell. Still deciding whether or not to make my own rear seat brackets or just use the original ones.
Also I finally pulled the trigger on a English Wheel, Waiting for it to arrive. This will open a whole domain of working with sheet metal. Cant Wait!  Was thinking about buying only the anvil kit and building my own Frame, but shit for the price of the anvils I wanted, way out of my budget, So I decided to go with the Baileigh EW-40.  Figure this will be good for a beginner like me for a while till I can reach Pro level, then I can get the nicer quality anvils and make my own frame.
Hopefully one day I can reach Lazze's level of metalworking, True inspiration!
Looks to me this was done free handed and by eye, dont see much of a template made or a Wooden Buck.
Pictures:
IMG 1529
IMG 1531
IMG 1536
IMG 1549
IMG 1550
IMG 1555
IMG 1562
IMG 1575
IMG 1576
IMG 1579
IMG 1581
IMG 1582
IMG 1584
IMG 1585
IMG 1586
IMG 1587
IMG 1590
IMG 1591
IMG 1596
IMG 1598
IMG 1600
IMG 1603
IMG 1607
IMG 1610
IMG 1611
IMG 1612
IMG 1613
IMG 1614
IMG 1615
IMG 1617
IMG 1618
IMG 1621
IMG 1628
IMG 1629
IMG 1631
IMG 1635
IMG 1638
IMG 1645
IMG 1657
IMG 1659
Edited by disepyon
Link to post
To me
This is probably the best build thread with such attention to detail I have seen.
I only wish you were down the street so I could stick my head in and admire this in real life.
Cheers
John
Thanks John, your too kind, hehe.
I wont be able to work on my car this week and weekend due to making some rockers for some people. Hopefully I can knock those out fairly quickly and get back on this project.
Link to post
Thanks LLave and Grannyknot
I can start posting more pictures of the tools im using. Some have already been posted. Been using my bead roller and sheet metal brake a lot.
I actually did not think I would be doing this much repair work, just thought it would be your typical minor common repairs most people do on these cars. Probably should had bought another less rusty Z but im kind of glad I didnt because I have learned a lot working with sheet metal and in the end I enjoy it even though it can get fruatrating at times.
Link to post
like the shoemaker's son!
This whole thread feels an instruction manual for all the repairs I need to do to my car in the next year or so. Thanks so much for sharing all the information and detailed photos, it's not only such a help in doing the work, but it's inspiring as well and helps guys like me feel less overwhelmed by the scope of the project!
Link to post
Thanks Kevbo82
Here is an update to the Interior rocker panels your waiting on. Refer to my vendor thread for more pictures of the process. I am finished with the panels, now just need to make the seat belt mounts and tie in plates.  Will probably go to my local shipping supply store to see if they sell any boxes that will fit this, if not I will most likely have to order online which isnt a big deal, however I would hate for the other customer and you waiting too long due to waiting on packaging materials, though better for the parts to arrive safely with proper packaging than damaged.
IMG 1892
Lucky for you guys, these panels are damn near close to the originals, way better than the ones I made for my car. Somebody had to be the lab rat, hehe. I actually remeasured everything, tested some stuff out and finally made a template.
No problem with the pictures, I always feel I dont take enough and post, yet I sometimes go a bit crazy on some stuff, hehe.
Link to post
wow you're getting used to making those huh!
Also check out a fedex store if you have one locally, I ship guitars a lot and need big/long boxes and I was amazed how cheap fedex was for some of those boxes. They had to order them in and it took a few days, but a good price (their shipping rates seem to be better than ups and usps as well these days). Uline is also a good option. Another thing I've done a lot is if you find a box the right dimensions but only say half the length, you can use two boxes and overlap them at the center then tape them together.
Link to post
Small update:
Sanded down the welds of the rear corner of the floor where the seat belt mechanisms are and the front lower fire wall.  On the driver side had to replace a small section of metal.  Still working on blending the metal together after welding and sanding.  Just hard to do in the flat areas.  Though I will admit, my fitment in some areas were not that great, had some big gaps. I really didnt spend much time in prep work, that is having good fitment before welding.  Also doesnt help trying to weld in awkward positions. Dont care too much on the back side/underneath the car side of the welds since you wont see them, just did some light sanding.  I really just need to start practicing each day with welding, sanding and blending sheet metal together, at least weekly if anything...hehe
IMG 1925
IMG 1927
IMG 1932
IMG 1937
IMG 1938
IMG 1949
IMG 1954
IMG 1955
IMG 1958
IMG 1959
IMG 1961
IMG 1962
IMG 1963
My English Wheel finally arrived earlier this week.  If anyone is thinking about buying this brand (Baileigh EW-40), I would probably reconsider, I am not to happy so far with the quality. Had to modify the bottom anvil cradle on one side because the bottom anvil/wheels didnt align/set flush against the top wheel.  Not only that but the bottom anvils are off centered from the top wheel. So far those are the only complaints I have.  One other thing that kind of bothers me is that the top wheel is not the same width as the bottom anvils. Of all the videos and pictures ive seen, the top wheel is either same size width (majority of them) or wider, not thinner.  Overall though, its a nice wheel for the money I guess, though I am a Noob at this, so I cant really say much.  The frame is extremely robust, so there isnt any flexing going on when wheeling, which is good. The anvils that come with it are alright. Wish they would have ditched the useless step and bead anvils for tighter angled anvils. I really want now a more rounded bottom anvil to get into tight spots.
IMG 1972
IMG 1973
My very first practice pieces. Just screwing around, mainly practicing my wheeling pattern.
IMG 1969
IMG 1971
IMG 1977
IMG 1978
IMG 1980
IMG 1981
IMG 1983
IMG 1984
IMG 1986
IMG 1987
Kind of getting side tracked from the car since the english wheel arrived. Been on the interweb feeding my brain with a bunch of youtube videos and reading material on shaping metal with the wheel.
More to come...
Link to post
Sandblasted some parts. Appears I will need to fill in some rusted holes shut.
IMG 1995
IMG 1996
Finally got the floor pans in permanently, still have some miscellaneous holes to weld in shut though.
Pictures showing clecos holding in the floor to the tunnel and frame.  Tried my best to get the edges aligned and butted with little gaps.  Some areas had some gaps, the driver side near the front end and rear end had the largest gaps but managed to get those welded fine without hardly any warpage.
IMG 1998
IMG 1999
IMG 2006
IMG 2007
IMG 2008
IMG 2009
IMG 2010
Tacked welded.
IMG 2014
IMG 2016
IMG 2017
IMG 2018
Tack welds sand smooth.
IMG 2023
IMG 2022
All welded in.
IMG 2026
IMG 2028
IMG 2024
IMG 2032
IMG 2033
Welds sanded and smoothed out. Had to do some hammer and dolly work on the welds to stretch them out and get the metal flush again.
IMG 2051
IMG 2054
IMG 2055
IMG 2058
IMG 2059
IMG 2048
Will be working on the seat brackets getting them prepped for installation and the parts I sandblasted.
Edited by disepyon
Link to post
