docjim Posted March 26, 2012 Share Posted March 26, 2012 Hi, I've got a 375 Hp/350 and a T5 installed in my '74 260Z. I'm just finishing up wiring the aftermarket wiring harness and have the interior completely gutted. I know this engine is going to dump a lot of heat to the passenger compartment and since I live in Phoenix, which is always hot anyway, I need to insulate the passenger cabin floor and firewall. So, what do you recommend for the best heat insulation so I don't have to drive a rolling sauna? Jim Quote Link to comment Share on other sites More sharing options...
johnc Posted March 26, 2012 Share Posted March 26, 2012 Tiles from the space shuttle. Remember rule 4: 4. There is no Best! No best tires. No best engine. No best shock. No best big chrome foot gas pedal. Every car builder and driver is in a different situation. What's good for one might suck for another. The decision on what is "best" for you and your car is completely up to you. As with any decision time, effort, and research is needed by the decision maker - you! Instead of asking what is "best", do some research, explain your situation in excruciating detail, and describe what alternatives you're considering in your decision. Posting a thread with "What's the best..." in the title it is a sure way to get that post tossed into the Tool Shed. Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted March 26, 2012 Share Posted March 26, 2012 Put down a layer of lizzard skin, then dynomat or other sound/heat matting. Quote Link to comment Share on other sites More sharing options...
zero Posted March 26, 2012 Share Posted March 26, 2012 I used EZ-Cool. Lightweight, easy to install and the price was right. http://www.lobucrod.com/ Quote Link to comment Share on other sites More sharing options...
zgeezer Posted March 26, 2012 Share Posted March 26, 2012 :DI started with TG1 from Cascade Audio, which is advertised as R-12. I expect to add more product such as DynoMat or some other material over the TG1 for sound and vibration suppression. Probably add a few pounds to the Z. The issue is not unique to Z's. Google some of the hot rod and low rider forums. Quote Link to comment Share on other sites More sharing options...
Leon Posted March 26, 2012 Share Posted March 26, 2012 Tiles from the space shuttle. Remember rule 4... Best answer ever. Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted March 27, 2012 Share Posted March 27, 2012 AC Quote Link to comment Share on other sites More sharing options...
bjhines Posted March 30, 2012 Share Posted March 30, 2012 Gold is the best heat reflector. Lol... Gold plate the entire underside of the car then buy gold foil and ceramic heat barrier to add even more layers. Quote Link to comment Share on other sites More sharing options...
Nelsonian Posted March 31, 2012 Share Posted March 31, 2012 Gold plate just as used on the Mclaren f1. You wanted the best, and you got the best,the hottest insul in the land, its GOLD! Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted March 31, 2012 Administrators Share Posted March 31, 2012 Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted March 31, 2012 Share Posted March 31, 2012 I have a few of those engines sitting in my garage... Now what to put them in? Quote Link to comment Share on other sites More sharing options...
tyler031734 Posted April 8, 2012 Share Posted April 8, 2012 Ive been told lizard skin adds microscopic ceramic balls to there coatings to add insulation properties and can be bought from a qualified paint supply. Add them to any paint you will add for an extra insulation layer, but use a face mask as if they get into your lungs, bad things could occur. Im sure in there fine powder form they are very light. Cover that with gold and then those ceramic tiles, your AC would frost your windows!! Quote Link to comment Share on other sites More sharing options...
Wedge Posted April 10, 2012 Share Posted April 10, 2012 secondskin makes something like lizard skin to but it called sludge or whatever its a paste you lay by hand or with a brush. Quote Link to comment Share on other sites More sharing options...
galderdi Posted April 10, 2012 Share Posted April 10, 2012 Ive been told lizard skin adds microscopic ceramic balls to there coatings to add insulation properties and can be bought from a qualified paint supply. Add them to any paint you will add for an extra insulation layer, but use a face mask as if they get into your lungs, bad things could occur. Im sure in there fine powder form they are very light. Cover that with gold and then those ceramic tiles, your AC would frost your windows!! Lizard skin adds balls you say. Well my car could do with some more balls Quote Link to comment Share on other sites More sharing options...
Mdantonio Posted August 8, 2012 Share Posted August 8, 2012 Look up Kool Mat out of mooresville nc. Kool mat blocks up 26 decibels of sound and 2000 degrees. It's a silicone and fiberglass like dry flexible material used primarily by NASCAR. That gray flooring material in the race cars....I guarantee you won't find a better sound deadner or heat resistant material. Kool mat is being used in military humvees and buildings in Mideast. I had a kit made for the 260z 2+2 so others can order quickly. It's a thousand times better than lizzard skin and deadens sound better than any other product out there....I have the others in my H2 and they pale in comparison to Kool mAt. If you call, ask for pat and tell her Charles sent you and that your a member of hybridz, you'll get a discount. I've already got my kit so I receive no financial benefit in sending anyone to koolmat. Outstanding stuff. I did take a welder to a piece of Kool mat and metal at same temp setting and had cut through the metal first....it works. Disclosure, I have absolutely zero interest in Kool MAt financially or otherwise. Quote Link to comment Share on other sites More sharing options...
jnewby Posted August 10, 2012 Share Posted August 10, 2012 edead is a good lower price alt I applied two layers to the floorpan doors and firewall and I have to say it is much better in the summer heat. Quote Link to comment Share on other sites More sharing options...
Wedge Posted August 24, 2012 Share Posted August 24, 2012 I ended up using Heatsheild product for firewall and trans tunnel and thermotech on the floor. Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted August 24, 2012 Share Posted August 24, 2012 Cjc Too bad that you had a 2+2 I wonder what it would take to get a kit made for a coupe? I checked out their website and I love the idea of that over lizard skin and dynomat. Quote Link to comment Share on other sites More sharing options...
Mikelly Posted August 24, 2012 Share Posted August 24, 2012 (edited) This is timely... I'm replacing the material I've been using. My car gets horribly hot and I need a new solution. BTW, Took me a bit to dig up Coolmat's website... http://www.koolmat.com/ Mike Edited August 24, 2012 by Mikelly Quote Link to comment Share on other sites More sharing options...
johnc Posted August 25, 2012 Share Posted August 25, 2012 Air is the best insulator - by far. The Space Shuttle tiles are 90% air. The best you can do is get air flowing through the hot areas in your engine compartment. Quote Link to comment Share on other sites More sharing options...
