z ya Posted October 8, 2001 Share Posted October 8, 2001 I am always curious as to what some of you guys are running in your z's. I though this would be a fun thread to see what set ups other Hybrid's are running.Heres mine: 355 SBC AFR 195'S 10 TO 1'S AIR GAP INTAKE 750 HOLLEY VAC SEC 286/490 COMP MAGNUM 1.52 PRO MAGNUM ROLLER ROCKERS PROFORM HEI/TAYLOR WIRES 1 5/8 BLOCK HUGGERS 2.5 DUAL SPINTECHS TPI TH700R4/2000 STALL R200 3.54 OPEN Quote Link to comment Share on other sites More sharing options...
QWKDTSN Posted October 8, 2001 Share Posted October 8, 2001 Heh. Well, right now it's in the garage with no motor at all.. 350 high nickel content at the machine shop, I think it's never even been bored. Freshly rebuilt, should pick it up in a couple of days. Feulie double-hump heads, forged pistons, fully balanced internally & balanced 153 tooth flywheel. Schneider cam with a little lump, 6700 RPM valve springs, and 1.6 ratio aluminum roller rockers. T5 transmission (I know I'm pushing the limits with this ). Probably an Edelbrock Performer RPM Air-Gap and 650 Holley carb, mechanical secondaries (4150), though I haven't quite worked that all out yet. Maybe 700 carb though mathematically 650 will be fine. Flowtech coated block huggers. Probably just a standard HEI system. Exhaust will dump into 2.5 inch downpipes that will join after the tranny and exit via 3" to, I don't know, maybe a Spintech muffler. I haven't quite worked this out yet either. 3.9 R200 open diff, Tokico Illuminas, sectiooned struts with Ground control coilovers. really weak springs right now. (150/175 F/R). Soon to add MSA swaybar upgrade. Polyurethane bushings everywhere. Quote Link to comment Share on other sites More sharing options...
auxilary Posted October 8, 2001 Share Posted October 8, 2001 '73 240z, black -stock l24 -3" exhaust -dual webber down drafts components being installed right now (literally) -ground control coilovers -tokiko illuminas -scca's 4 piston toyota front kit -msa swaybars -p-s-t polygraphite bushings -r200 open diff, 3.54 ratio -aluminum crossflow radiator Quote Link to comment Share on other sites More sharing options...
ZROSSA Posted October 8, 2001 Share Posted October 8, 2001 This is as it is now. 260 2+2, 350 chev with a steel case supra 5 speed. lowerd all round with after market shock and anti roll bars. 16*7 rims. 225/50/16 tyres. fuelie spec heads with 2.02 int and 1.6 exhuast valves. 10.1 comp 350hp cam, 650 vac.sec holley. r200 with 3.5 diff. Thats as bought, changes will come. Looking at biger brakes, 750 double pumper and i would really like to figure out how to get 180 degree headers in there Douglas Quote Link to comment Share on other sites More sharing options...
DavyZ Posted October 8, 2001 Share Posted October 8, 2001 Awe, you just want to brag! Chevy 350 with Stealth intake, Holley 750, Comp Cams roller rockers, Summit performance cam and lifters, roller timing chain, upgraded Accel HEI, big wires, blockhuggers, etc., JTR kit, Aluminum radiator w/Taurus fan, etc, etc, all waiting to go into the right 240Z (goodbye 260Z..snif). No braggin' quite yet...except after the turbo upgrade... As for the tranny--WC T5 which will be upgraded with a Gearzone balance shaft and Pro 5.0 (or like) shifter, R200 open diff, and urethane bushings. Geez, I have almost all of it except for the right car! For protection, I have an SW 8 point rollbar/cage. Davy [ October 08, 2001: Message edited by: DavyZ ] [ October 08, 2001: Message edited by: DavyZ ] Quote Link to comment Share on other sites More sharing options...
fastzcars Posted October 8, 2001 Share Posted October 8, 2001 old scarab conversion i bought 3 years ago. In the process of rebuilding. here goes my list. 350 crate engine rated @300 hp notZZ version but whats called a CC.Holly 750 (3310)vac secondaries.weiand stealth intake.msd hei dist and wires.in the process of conversion to JTR specs. T56 aftermarket trans w/2.97 first gear.Mccloud clucth and throwout bearing, wilwood M/C.Lakewwod scatersheild. R200 diff w/Quaife LSD 3.70 gears.tokico illum with cut struts. DP products coil over system with 225 front, 250 rear coils. DP products 4 wheel disc brake conversion with wilwood 4 pistons in front and 2 in rear. Brembo 12.3"x 1.25" front disc and 12.5"x.5" solid rear.17x7 centerline coronas w/michilin 235/45 front, 245/40 rears.Full rebuild of suspenion w urethane and delron bushings. Suspension techniques anti-sway bars 1.125" front .75" rear.Inside I have 2 recaro srd seats.new carpet.fulldash cover w/full Autometer ultra-lites.6 point rollbar and subframe connecters. large 14.5"sparco rally steering wheel.all in a 73 240 silver z.All thats left is a good paint job. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 8, 2001 Share Posted October 8, 2001 thought id add my specs i havent posted in awhile. 73' 240z with 82' L28ET 88mm 8.2 compression high heat coated JE pistons 9mm L24 rods LD28 crank f54 block, p90 head stock valves with high heat coating on exhaust valves. stock exhaust manifold with t04 turbo stock intake manfold with all those nasty vaccumm lines welded and grinded. Looking for 400bhp, controlling with SDS. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 8, 2001 Share Posted October 8, 2001 My specs are: 1972 Datsun 240z, burnt/oxidized orange. '95 Miata seats, autometer gauges, MSA A/C 350 Goodwrench V8 (250hp stock) Weiand stealth with Holley 600 vacuum sec 1995 Camaro T-56 six speed transmission MSA sways front and back, with suspension tech. springs. New urethane bushings in front. 7" weld draglites front and rear, 205/55/15 Goodyear Eagles. Future plans: 6 pt Roll bar with harnesses, Fuel Injection and a Turbo. R200 or possibly a live axle 9" ford. Painless wiring harness. Regards, Lone Quote Link to comment Share on other sites More sharing options...
stony Posted October 8, 2001 Share Posted October 8, 2001 Hi yall!!!! 260z 1974 engine RB-26DETT, trust gtr FMIC, SDS engine management, skyline GTS-t 5 speed tranny, r-200 LSD, coilovers, koni struts. chromoly tubular control arms, kakimoto 90MM exhaust. couple of the normal gages. wheels are Watanabes ...front 15x8, rear 15x10 with BFG drag radials. future. getting ready to rip out the rear suspension and tub and rollbar the car. 4 link with ford nine inch or maybe a 12 bolt just depends on what i find the best deal on when i m ready ;> current best time with the surrent setup 11.138 @ 121mph. with lots of tire spin and the motor still setup in bone stock trim ;> Quote Link to comment Share on other sites More sharing options...
Guest super280z Posted October 9, 2001 Share Posted October 9, 2001 good idea for a post! here goes, 79 280zx, dupont red. black interior. completely gutted awating full measurement (cross your fingers for 2400) / weight dist, 1994 LT-1, 1-5/8" headers, FRC's, 200-4r trans w/ trans-go SK, 3.54 r-200, 2.5" duals to 3" dynomax ultra flow round, CAI, Griffin aluminum radiator, 16" electric fan, and waiting on a bunch of goodies. 75% complete. about all i can think of.. Quote Link to comment Share on other sites More sharing options...
blueovalz Posted October 9, 2001 Share Posted October 9, 2001 Ford 289 with 10:1 pistons. Victor Jr intake with the aluminum J302 heads using Chevy valves & a 780 Holley. 1.75 equal length tube headers. Solid roller road camshaft, and 8k valve train. Griffith aluminum radiator with underdrive crank pulley. McLeod aluminum flywheel and hydraulic T/O bearing. T-5 to an R200 (Gleason-Torsen) with ZX turbo 1/2 shafts (soon to be Porsche 930 CV jointed). Rear mounting plate for diff, sway bar, & suspension pickup points. Custom rear toe adjuster. Camber plates, HD swaybars, roll center spacers. Tokico race inserts in 230 F/265 R lb/in 10" springs 315/35ZR17 tires on 11" wheels. Supra front and Maxima front (on the rear) brakes. Ford power assist rack, 8 pt cage. driveshaft driven alternator. And a little ol' fiberglass body atop a custom fiberglass interior. Quote Link to comment Share on other sites More sharing options...
73BOTIZ Posted October 9, 2001 Share Posted October 9, 2001 73 240Z 358 C.I. SB TRW 11:1 Forged pistons,Cheverolet"pink" rods Comp Cams 292H hudralic cam Weiand Team G Intake manifold, Holley 750 carb. L-98 corvette heads, ported and gasket matched. The trans. is a T-5 5 speed Front brakes are 4- runner calipers with 300zx rotors. Rear brakes are 83 280zx disc. Rear end is an r-200 with cv joint half shafts. Every bushing has been changed to urethane. Exhaust is from flowtech block hugger headers through 2-1/2 pipe into two flowtech mufflers. My immediate future plans are to move to the interior now that it is running, and then decide what I want to do to the exterior. Later, Mike D. Quote Link to comment Share on other sites More sharing options...
Guest Zpeed Posted October 9, 2001 Share Posted October 9, 2001 well mines pretty boring, but i like to just add a reply anyway just about bone stock 76 260z, L26, oversized pistons, larger valves, currently have some crappy flatops on, but need to rebuild my SU's, next on the to do list, is paint (grey, might put some lines down, but havn't decided if to ricey or not), once that is done... suspension koni adjustables, with coil overs, then brakes, vented disk with 4 pot calipers at front, 280zx rear disk brakes, also waiting a few years to put the 350 chev in there, or maybe a Rb26dett havn't decided yet... i am going to get all the suspension and brakes and rear end done before i am going to do the conversion Quote Link to comment Share on other sites More sharing options...
Mikelly Posted October 9, 2001 Share Posted October 9, 2001 Click on my link to the home page to see what mine used to be. Click here: http://photos.yahoo.com/dat74z to see what I'm up to now: Motor: SBC 383 Stroker Heads: Dart Conquest 205/160 valves Valvetrain: Roller Hydraulic with 1.5 Roller Rockers. Oil Delivery: Canton Pre-luber Accusump, Canton Billet filter relocated to front of radiator, 8-an lines, Canton roadrace pan to be ordered, Mellins Hi vol. pump. Induction: Cutler FI Intake & 1000CFM TB, 42# Injectors, still looking for computer and controller, but will be laptop programable. Fuel Delivery: Bosch FI Pump, JAZ/ Summit Fuel safe-22gallon unit, 8-an line and 1/2 aluminum line up and back, Canton Fuel filter, Cutler Rails and regulator. Trans: T56 with Centerforce DF Setup with Centerforce 153 tooth Flywheel. Rest of Drivetrain: CV Axles connected to R200 LSD model with 3.7 gears, custom drive shaft and safety loop. Cooling: Griffith Radiator, Edelbrock aluminum waterpump, RobertShaw Hipo thermostat Suspension: Ground Control Coil Overs, Eibach Springs, Suspension Techniques Sway Bar up front, Energy Suspension bushings, ZF Racing Control Arms and TC Rods Brakes: 12.2 inch X 1.25 thick veined and vented rotors on custom aluminum hats up front with Outlaw 4000series calipers. Rear use 1985 300ZXT 5 lug rotos and wilwood Dynalite 2 piston calipers, no e-brake, but brake lock switch and proportioning valves are in place. Wheels/ Tires: 5 lug conversion to use Cobra R style 17X9.5 wheels with 255-40 and 275-40 Bridgestone RE730 tires. Safety: 21 point cage including a trunk built around the rear hatch to protect cockpit from fuel delivery system. Phoenix Fire system to be ordered, TRW CAMLOCK 5 point harness to be used, Corbeau A4 seats with mandatory Seatback brackets to be used during races, nomex fire suit, and approved Simpson Bandit helmet, along with gloves and boots to be purchased. Body: G-NOSE, 2 inch flares up front, 2.5 inch flares in the back, sheet metal wing to be purchased for the rear, raingutters cut flush, fuel door and vents smoothed. Gauges: Autometer Phantom series all around. Did I mention I plan to have a FULL INTERIOR, CD CHANGER AND HEAD UNIT, and AC when the car is finished??? Mike Kelly ZF Racing LLC [ October 09, 2001: Message edited by: Mikelly ] Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted October 9, 2001 Share Posted October 9, 2001 Click on the link below for more details. Drivetrain: 87 Buick V-6 Turbo, .020 Fed Mogul Hyper pistons, ARP rod bolts and head studs, Upgraded turbo (23psi boost on race gas), Stock TH200R4 trans with transbrake, Pro-Ratchet shifter Exhaust: 3" mandrel SS DP and exhaust with single straight-thru muffler Suspension/Brakes: Front - hi-po springs, Tokico Illuminas, 82-3 calipers/84 vented rotors Rear - Currently upgrading to C-4 Corvette IRS, 3.07 LSD, 11.5" brakes, coilovers Wheels/Tires: Front - Wheels TBD, 225/55-15 Michelin Pilots Rear - Wheels (16") TBD, 255/50-16 BFG DRs Performance to Date: From datalogger - 0-60 2.83, 0-100 7.11, 1/4-mile - 11.10 @ 121.50, Looking for 10s, Top Speed - I DONT WANNA KNOW!! Quote Link to comment Share on other sites More sharing options...
Andrew Bayley Posted October 9, 2001 Share Posted October 9, 2001 My turn to bite... Vehicle: 1974.0 260Z Motor: 358 Small Chevy (350 0.040" over) 10:1 compression Flat Hydraulic 0.510" @ 240 degrees - 112 seperation Edlebrock Performer RPM Heads Crane 1.6:1 rollers Performer RPM dual plane intake Modified 680cfm Holley double pumper MSD dizzy, box, wires, etc... Full length 1.75" headers Laughing Gas Hot underhood-air induction Drivetrain: GM TH-700R4 4 speed automatic overdrive transmission Datsun 3.54:1 R200 single slide rear end 280Z stub axels and half shafts Suspension: Ground Control Coil-Overs on all Fours Tokico (sp?) non-adjustables Stock brakes 280ZX 14x6 rims with very crappy generic street tires. Eagle 15x8 rims with BFG 275/50/R15 Drag Radials for the track Interior: S&W 8 point roll bar 5 point harness for driver Cheap, plastic, very uncomfortable "JAZ" seat for driver Original crack-free dash!!! Autometer Phantom series gauges B&M Mega Shifter "Custom" Mr. K signed glove box door Winter Updates: (already got them, just need to get around to installing) 10 gallon fuel cell CV axels Toyota 4-pistons Street Flares for front and back Cold Air induction For pictures and complete story, visit the link below. -Andy [ October 09, 2001: Message edited by: Andrew Bayley ] Quote Link to comment Share on other sites More sharing options...
Guest Fast Frog Posted October 9, 2001 Share Posted October 9, 2001 Hello gents: Here's my specs: Chevy 383 with 9.5 cr Edelbrock Performer Rpm hds with 2.02/1.60 Crane HR cam .488/.509 lift 214/222 dur TPIS 1000cfm fuel inj mini-ram MSD 6000AL Accel DFI engine mgmt sys Hooker 1 5/8" hdrs with dual 2 1/2" exh Black Magic 150 elect fan JCR 4 core "Datsun V8 conversion" radiator WC T5 Camaro 5 spd tranny 10"X15" Centerline rear whls 7"X15" Centerline front whls Dunlop sp 8000 tires (245VR15 rear) Quickor lowering and stiffening sprg kit Schroth 3 point harness with custom interior [ October 09, 2001: Message edited by: Fast Frog ] Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted October 9, 2001 Share Posted October 9, 2001 1974 260Z 1989 5.0L mustang engine and T-5 transmission Stock 5.0 fuel injection Tilton hydraulic throw-out bearing Tilton clutch master C&L 73mm MAF 24# injectors 1.72 roller rockers dynomax block-hugger header dual 2.5" exhaust w/ 2 chamber Flowmaster RCI 16 gallon fuel cell centerline 15x8 (5in backspace wheels) Dunlop 245/50/15 tires GroundControl coilover springs(200#/175# R/F) Koni single adjustable struts Suspension Tecniques sway bars polyurethane everything 11.5 x.81 rotors w/ outlaw 2800 series calipers on front Maxima 10.75 x .81 rotors and outlaw 2800 series calipers on back. adjustable proportioining valve Soon to install Edelbrock Aluminum Heads, Crower cam, Cobra Intake. Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted October 9, 2001 Share Posted October 9, 2001 '72 240Z with a fuel injected 327 and T56 6 speed. The engine was dynoed at 435hp, and 493tq! It has a Edelbrock Pro-Flo EFI and Trick Flow G2 heads.I mini tubbed the wheelwells and custom made the rear frame to fit a shortened 12 bolt chevy w/3:73 posi, moser axles, disc brakes, panhard bar, coil overs, Jeg's street/strip suspension. I also custom made frame connectors, and instaled an S&W 8 point roll bar. front: shortened struts w/Ground Control coil overs, camber/caster plates, 1 1/4" sway bar. It has AC, with a Vintage Air heat/AC system, Autometer gauges, cassette/CD radio. Weld, Rodlite wheels 15X6 front, 15X10 rear 295-15-50 rear tires Quote Link to comment Share on other sites More sharing options...
