Chickenman Posted August 2, 2017 Share Posted August 2, 2017 (edited) Juts stumbled across these. From EFI hardware so should be good quality. Reasonable price IMHO. Combine with your favorite Triple manifold, add injectors and Bazinga!! Note the 6 degree throttle blades. Would be a neat conversion from a Plenum manifold for someone... whose name may or may not start with an " S " Edit I suppose a link may help: http://www.ebay.com/itm/6-Cylinder-DCOE-45mm-Throttle-Body-Kit-inc-TPS-Ram-Tubes-Fuel-Rail/261879001624?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 Edited August 2, 2017 by Chickenman Quote Link to comment Share on other sites More sharing options...
Neverdone Posted August 2, 2017 Share Posted August 2, 2017 I might be confusing a very important thing here, but how is this different than just buying two sets of Triumph Daytona 955i throttle bodies? http://www.ebay.com/itm/02-06-Triumph-Daytona-955I-throttle-Bodies-w-Injector-Rail-Fuel-Lines-/372003554885?hash=item569d23c645:g:VZQAAOSw7GRZCkiG&vxp=mtr You still need to make an adaptor plate, you still need the software to run the injectors. Again, I'm probably missing something very important here, but it seems like you'd be spending $1000 extra for not much. Quote Link to comment Share on other sites More sharing options...
Twentyfourouncer Posted August 2, 2017 Share Posted August 2, 2017 One difference at least is that you will not need an adaptor plate as the ITBs are a DCOE pattern and can bolt up to a lot of commonly available triple carb manifolds. Quote Link to comment Share on other sites More sharing options...
HuD 91gt Posted August 2, 2017 Share Posted August 2, 2017 They will easily mount to any DCOE manifold currently made for the L series... Quote Link to comment Share on other sites More sharing options...
Derek Posted August 2, 2017 Share Posted August 2, 2017 Hey those look familiar. Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted August 2, 2017 Share Posted August 2, 2017 Hmm. I like this option much better than the very expensive Jenveys. Are they quality or Chinese junk? I am weary of anything on eBay that's affordable these days. Quote Link to comment Share on other sites More sharing options...
madkaw Posted August 2, 2017 Share Posted August 2, 2017 https://www.rhdjapan.com/oer-racing-sports-injection-kit-standard-type-45mm-l20-l24-l26-l28.html I'm saving for these Quote Link to comment Share on other sites More sharing options...
Derek Posted August 3, 2017 Share Posted August 3, 2017 On 8/2/2017 at 10:29 PM, rturbo 930 said: Hmm. I like this option much better than the very expensive Jenveys. Are they quality or Chinese junk? I am weary of anything on eBay that's affordable these days. I'm happy with mine for sure. One of the butterflies is slightly off center and it has a little stick-age problem if you run closed blade idle bypass but if you crack the blades for your idle it's not a problem. The outer edges of the bodies were sharp but that was fine as I just hit them with a deburing tool. The kit had everything I needed to get it working. I did manage to knock one of the velocity stacks off of its base but it snapped right back on and never was a problem again. I had about 6000 miles on them before my head $hit the bed. I think for the money they are the best deal out there. Quote Link to comment Share on other sites More sharing options...
Chickenman Posted August 3, 2017 Author Share Posted August 3, 2017 On 8/2/2017 at 10:29 PM, rturbo 930 said: Hmm. I like this option much better than the very expensive Jenveys. Are they quality or Chinese junk? I am weary of anything on eBay that's affordable these days. EFI Hardware is an Australian company and make nearly everything in house. Personally I've always found that Australian and New Zealand products are normally very good quality. The guys over there are Hard Core. Quote Link to comment Share on other sites More sharing options...
theczechone Posted August 3, 2017 Share Posted August 3, 2017 (edited) I'm not too sure, i think that unless you are looking for a throttle plate only I would still go with the Jenveys. So you can have a pair of Jenvey's for $608 https://jenveyusa.com/collections/throttle-bodies-twin/products/jenvey-dynamics-th-body-45mm-individual-throttle-bodies-pair Or you can have a single ITB from EfiHardware for $293 https://www.efihardware.com/products/2895/E-Series-DCOE-Throttle-Body so you are saving a whopping $33 for three. Then personally i like the Jenvey's better so i guess i am biased Edited August 3, 2017 by theczechone Quote Link to comment Share on other sites More sharing options...
theczechone Posted August 3, 2017 Share Posted August 3, 2017 In contrast here are the EFiHardware ITBs on an engine by PMC engines Quote Link to comment Share on other sites More sharing options...
Derek Posted August 3, 2017 Share Posted August 3, 2017 When you add up all of the stuff in the kit purchasing them piecemeal the price goes up quite a bit. Now if you are going to discard some of the parts like linkage then it makes better sense to buy individual. Also the ones you linked to have a built in injector bung. Which is a plus if you want it. The kit I got requires bungs in the manifold which is what I wanted. Quote Link to comment Share on other sites More sharing options...
theczechone Posted August 3, 2017 Share Posted August 3, 2017 On 8/3/2017 at 1:39 PM, Derek said: When you add up all of the stuff in the kit purchasing them piecemeal the price goes up quite a bit. Now if you are going to discard some of the parts like linkage then it makes better sense to buy individual. Also the ones you linked to have a built in injector bung. Which is a plus if you want it. The kit I got requires bungs in the manifold which is what I wanted. I agree, if you buy piecemeal than you'll pay more. The kit listed in the original posting is a throttle plate with weld in bungs, not everyone has that ability and could be costly to have it done. Jenvey usa doesn't currently list a kit with three throttle bodies. I sent them a note if they could generate a price for a kit and also if they are open to group buys. I've been interested in one of these two option for a while. Just haven't pulled the trigger Quote Link to comment Share on other sites More sharing options...
Derek Posted August 3, 2017 Share Posted August 3, 2017 I think the throttle bodies with the built in bungs are the way to go if you already have a DCOE manifold. For me at the time the kit was appealing because I knew I wouldn't be constrained design wise. Now if I was going to do it all over again....Heritage Throttle Body all the way. That is as long as they get around to doing it in 48mm like they said. Quote Link to comment Share on other sites More sharing options...
theczechone Posted August 7, 2017 Share Posted August 7, 2017 working with Tim at Jenvey USA on group buy pricing for a kit perhaps we could do the same with EFI hardware. Quote Link to comment Share on other sites More sharing options...
