L28ET Intake Manifold Flange Dimensions
Onshape Import of Solidworks document, fork and modify! The Open Source way. :-)
https://cad.onshape.com/documents/62ec8d4c1b6a326b006e0e4f/w/829e4a2841936f5429ec421d/e/db10d8b7ab8801d4d61a16c5
Note that this is based off of Ron Tyler's flange he made (or had made?) which is spec'ed to the tube he used witch had a 1.5ID for the port size, with a centerline raised, so that the floor of that 1.5 landed on the stock port floor. If you wanted to use stock diameter runners, you'd want to move the centerline down. More/most ideal would be to undersize the hole, then bolt it to your head and match it.
Hope that helps you out.
Link to post
  • 1 month later...
According to what I've seen Blake (1fastZ) say recently, you could likely make 10 and have them in stock for sale for about 5-10 years...
That said, the recent intake group buy had a lot of buy in, buy also had a lot of angry customers. If you can provide a complete product for cheap there tends to be interest. But a DIY product or something more than a blue collar paycheck and it's going to sit.
Link to post
Yeah that makes sense. Not everyone has access to a TIG welder or wants to bother with fabricating their own. A complete product would sell better, you're right.
3 hours ago, HuD 91gt said:
Pending price, I’d buy one.
Intake manifold is on my project list.
Sounds good. I'll keep you in mind when I'm going forward with my manifold.
Link to post
i can make them out of steel, not aluminum, price would depend on thickness / demand but i can probably get a few made between 120-200 depending on thickness / finish. message me for details
edit: for clarification, would be laser cut just the flat pattern
Edited by nzarano
Link to post
  • 3 months later...
On 4/4/2019 at 8:30 PM, jkelly said:
@Gollum Any idea what the demand for these is? I was trained on our CNC machine at work the other day and I'm really wanting to machine one for myself and weld my own manifold. I would consider cutting a few of these if people are interested.
LMK if you are going to  cut some of these flanges.  I am also looking to do a custom intake manifold.
Link to post
  • 11 months later...
*gravedigging*
As I am informing myself on building an intake manifold I found this thread and the original(?)
From what I have gathered, the injector spacing in the 3d model is wrong, it should be like this InjectorLocations.png
Source: https://forums.hybridz.org/topic/70721-l28-injector-spacing-port-dimensions/?do=findComment&comment=669440
Edited by Ereschkigal
Link to post
