D1t Posted October 30, 2020 Share Posted October 30, 2020 Introduction Hi everyone, my name is Noah and I design all sorts of hotrod suspensions and chassis for a living, and have been using my 240z to play around with some of my more hair-brained ideas. I'm @noahdropkin on instagram if you want to see more of my over-engineered Z parts. I'm putting all this out there because I'm confident that nobody would actually take the time to reverse engineer what I've done here and turn it into a marketable kit, its just far too expensive to produce. You can go take the parts off a wrecked 2015 mustang and hack them up, I promise you it wont work worth a damn. For anyone who really wants one, if you can arrange 5 people to each pay ~$5K for a complete set of double adjustable coilovers and a complete front end suspension kit, then I'll find a way to do a small run. If you want to know why this thing is so expensive, see the exploded view down below. (I spent weeks hunched over a lathe.) I built one more kit for Mr. 280Z-LS3 (he's doing a build thread, go check it out), because having to deliver him a kit was the motivator I needed to actually get the whole thing done, and because it was many long chats with him that got me thinking and sent me down this rabbit hole. Yes, I could've done a double wishbone setup, but that's been done before and has some inherent compromises I wanted to avoid. I recently got the chance to compare the kinematics of this setup to one of the dual wishbone front ends out there for a Z, and was very pleasantly surprised to see how advantageous this is in terms of scrub radius and camber change. Lets dig in: I knew when I picked up my 240Z I'd end up building some sort of specialized suspension setup for it, but I didn't quite know what. I knew I was going to need a new rear end to handle LS power and came across a Ford Super 8.8” (2015+ Mustang Diff) IRS swap kit that seemed to tick all the boxes, and got my hands on one of the first kits. That kit uses a 2014 Mustang front spindle so that the front and rear bolt patterns match, and so that you can use 2014 Mustang front brakes to match the rear. Unfortunately, using a 2014 mustang spindle on a 1972 240z doesn't work out that well for a couple of reasons. The first is that the wheel gets pushed forward in the wheel well the better part of 2 inches. If you compare a 240z front spindle and a 2014 Mustang you can see that the Mustang wheel center is pushed forwards of the kingpin axis, which is the axis which connects the lower ball joint and the coilover mount, and is what the wheel rotates about as the wheel turns. Now, this isn't an unsolvable problem. If you've got fender flares on your car you can mount the flare and cut the fender up so that it doesn't look like the wheel is that far forward, but if you're not using flares you're a bit out of luck. If you were to try pushing the lower ball joint rearwards, either by hacking up the arm or flipping the front control arm bushing around, you'll end up with no caster angle, which means the wheels wont self-center themselves correctly when driving. The second problem is one that all Z's using wide tires with big offsets share, and is exacerbated if you've got fender flares. The scrub radius of the suspension is the distance between the center of the tire contact patch and the point where the kingpin axis intersects the ground. The larger the scrub radius, the harder it is to steer the tire, so small scrub radii are desirable. In order to change the scrub radius of your suspension without moving the tire you need to move either the lower ball joint or the upper shock pivot. In many cases, the brake rotor gets in the way of where you'd want to put the lower ball joint, and nobody wants to cut up their strut tower to move the shock mount drastically. If you could move the lower ball joint out or the shock mount in you'd also increase the kingpin inclination angle, which means you'll have more camber change as you steer the wheel. Now, this isn't great, you want a pretty low kingpin inclination, but often times you have to take what you can get. (For those of you following along at home, we're on page 626 of Milliken and Milliken's Race Car Vehicle Dynamics) So, how do you push the lower ball joint out with a brake rotor in the way? Well that's where the 2015 Mustang spindle comes into play. This spindle uses what's called a "split lower link" where what used to be one lower A-arm with three pivots (which is what the S30 uses, it's just split into two parts) is replaced by two links with two ball joints each. In this setup, the kingpin axis is formed between the upper pivot and the instant center formed by the two lower links (the intersection of the two links). This is shown on the 2015 Mustang spindle below, looking up from the ground. (THIS IS WHERE THE MAGIC HAPPENS) So here's where this gets even trickier. On the 2015+ Mustang the two links go to the front and middle of the car (shown in green), and the S30 has it's two mounts at the middle and rear of the suspension (shown in red). Luckily this can be used to our advantage. Ford wanted to keep the lower instant center in (more or less) the same place as on the 2014 Mustang. By shifting the links around we can push the lower instant center towards the front of the car, bringing the wheel backwards! This gets the center of the wheel right back to where it was in stock S30 suspension, solving the biggest problem with the 2014 spindle. The difficult part in doing this is connecting the linkages to the mustang spindle in ways Ford never intended. The 2015 Mustang uses one link on top and one on the bottom of the knuckle, which helps prevent them crashing into each other. Because the S30 control arm mounts are on an axis parallel to the ground, if you were to mount the two links to the stock frame locations and the stock points on the spindle, you’d have undrivable amounts of camber change. So, in order to adapt two spherical bearings onto the Mustang spindle I machined tapered spacers that are pressed into the spindle, through which two 190ksi 12-point aircraft shank bolts pass through, bolting the whole thing together. The price on these bolts is eye watering. Luckily the spindle can be steered to the stock steering angle before the two links collide, though a hard stop is required on the steering rack to limit travel. The steering arm on the 2015 spindle is rather short, but should be well suited for autocross and track day driving, though it might be a bit twitchy on the highway. The 4° of caster should take care of high-speed stability. Rather than pay someone a fortune to build custom coilovers for this I decided to tackle that myself, using a universal Koni double adjustable strut insert as my starting point. To make life a little bit easier I got in touch with TechnoToyTuning and asked if they would sell me the threaded shock tubes with gland nuts that they use in their coilovers and they were happy to oblige. They also supplied the spring perches and threaded sleeves. For springs I settled on 350lbs/in in the front and 300 lbs/in in the rear, each paired with a tender spring. This nets me roughly 2” of droop travel from ride height and 4” of bump travel. Spring rates were determined based on a target roll gradient of 2.85 °/g, which can be increased to 2.55°/g by use of a 1” dia. 0.065” wall anti-roll bar up front and .75” dia. 0.125” in the rear. Thanks for reading the whole thing! DO NOT TRY THIS AT HOME. Statics: 2014 2015 Kingpin Angle (°) 14 15.61 Caster Angle (°) 3.16 4.05 Scrub Radius (in) 3.79 2.52 Front Roll Center Height (in) 0.9 1.96 Steering Arm (in) 4.2 3.39 Mechanical Trail (in) -0.32 0.379 Wheelbase (in) 92.6 90.9 FVSAL (in) 215 146 2015 Spindle (left) vs 2014 Spindle (right) Quote Link to comment Share on other sites More sharing options...
calZ Posted October 30, 2020 Share Posted October 30, 2020 If there's one thing HybridZ loves, it's actual engineering. Nice work. Quote Link to comment Share on other sites More sharing options...
Invincibleextremes Posted October 30, 2020 Share Posted October 30, 2020 This is incredible. Love the charts showing everything. Quote Link to comment Share on other sites More sharing options...
D1t Posted October 30, 2020 Author Share Posted October 30, 2020 Final product: Quote Link to comment Share on other sites More sharing options...
280Z-LS3 Posted October 30, 2020 Share Posted October 30, 2020 Oh sure, blame this madness on me, lol! Seriously, your work is incredible and completely thought out! Working as fast as possible to get to the point of installing the 2015 spindle kit. Sourced four Koni 8611 1259 Race dampeners which should arrive next week so now have everything needed. Quote Link to comment Share on other sites More sharing options...
LLave Posted October 30, 2020 Share Posted October 30, 2020 This is amazing and inspirational. Thank you for sharing. Quote Link to comment Share on other sites More sharing options...
TUME Posted October 30, 2020 Share Posted October 30, 2020 (edited) Are those numbers directly from mustang? What are geometry numbers in 240Z with these parts? Same? My suspension is made of 240SX parts, and cost almost nothing except coilovers. BUT, I moved strut upper mount. I think it is still better idea, i`ll get KPI 14deg, caster 7deg, scrub is near zero with ET35 wheels and rest is adjustable. Well, so is caster, but thats what I want. Caster is good to be half of KPI, that is giving good camber behavior when turning. I haven´t measured camber curve or bump-steering yet, but will try to get time for that. Of course there are difference with bolt on parts, but most cases result is better and much cheaper with so fabrication involved. Just my thoughts, no hard feelings... Btw, there are pics in my build topic: https://forums.hybridz.org/topic/128677-arttus-240z-never-ready/ Edited October 30, 2020 by TUME Quote Link to comment Share on other sites More sharing options...
D1t Posted October 30, 2020 Author Share Posted October 30, 2020 9 minutes ago, TUME said: Are those numbers directly from mustang? What are geometry numbers in 240Z with these parts? Same? My suspension is made of 240SX parts, and cost almost nothing except coilovers. BUT, I moved strut upper mount. I think it is still better idea, i`ll get KPI 14deg, caster 7deg, scrub is near zero with ET35 wheels and rest is adjustable. Well, so is caster, but thats what I want. Caster is good to be half of KPI, that is giving good camber behavior when turning. I haven´t measured camber curve or bump-steering yet, but will try to get time for that. Of course there are difference with bolt on parts, but most cases result is better and much cheaper with so fabrication involved. Just my thoughts, no hard feelings... Btw, there are pics in my build topic: https://forums.hybridz.org/topic/128677-arttus-240z-never-ready/ These numbers are all as-installed on 240z. Some of the images show the 2014 spindle and some show the 2015 because I had designed the complete 2014 kit before changing direction. Caster is adjustable by using spacers on the clevis where the rear link mounts to the chassis. 7 degrees of caster is quite a bit, but with zero scrub that's reasonable. There are definitely pro's to moving suspension points around by fabricating new mounts, but I wanted to leave all the stock mounting for a few reasons: Many competition classes restrict you to "stock suspension mounting points" which, I would argue, this uses. I wanted the challenge of doing this with stock mounting points. In case this all went south, I wanted the option to be able to switch back easily. If I were to sell this as a kit, it's substantially more marketable as "bolts right in". Quote Link to comment Share on other sites More sharing options...
1 tuff z Posted October 31, 2020 Share Posted October 31, 2020 My brain hurts after reading and, attempting to digest this all. Great work! Quote Link to comment Share on other sites More sharing options...
