FI_JUNKY Posted September 21, 2005 Share Posted September 21, 2005 hi, new to the site... my question is what is a good injector(s) (not too pricy) between 400-500cc that i can find and drop in with no sort of mods needed to run? and also will i have idle problems if i go any bigger than 500? because i would really like to go 550 with out causing myself problems. can anyone please help??? by the way i have a pretty well bone stock '83 280zx. any recomendations would be well appreciated, thanks! Link to comment Share on other sites More sharing options...
cygnusx1 Posted April 12, 2006 Share Posted April 12, 2006 Here is some NICE injector info regarding some Bosch high flows. Low imp. http://wwwrsphysse.anu.edu.au/~amh110/Technical_pages/bosch_403_fuel_injector.htm Link to comment Share on other sites More sharing options...
KTM-EXC Posted July 18, 2006 Share Posted July 18, 2006 Hey, I have a quick question.... Since the 7MGTE 440cc injectors work with a Pallnet fuel rail wouldnt aftermarket injectors such as RC engineering 550cc for the 7M work too? Thanks Rob Link to comment Share on other sites More sharing options...
pallnet Posted July 19, 2006 Share Posted July 19, 2006 I'm 99% sure if they are made for the 7MGTE motor that they would work just fine with one of my 11mm rails and the stock L28 intake manifold. Link to comment Share on other sites More sharing options...
twoeightythreez Posted August 8, 2006 Share Posted August 8, 2006 For people looking for a bolt in slighly higher volume injector Jag XJ6 injectors use the barbed fitting, are low impedance, use the bosch connector (injector part #280-150-153) and flow 238cc/min @36psi I have a set I can give away if anyone wants them (I went with the Ford 5.0 TBI injectors- 280-150-400 438cc/min@36psi) I also have a set of 7MGTE injectors that need a home. I was gonna just take the covers off the end of the ford injectors but I decided to just make the hole in the intake bigger instead. Had an exhaust leak anyway. Drill bit of 10.3mm works fine (for some reason I forget the standard measurement but a 3/8 drill bit is 9.5mm) I do have a question....Can you use hoses on the end of the ford injectors? THe TBI units had a tiny little o-ring for sealing and the top is "stepped" Link to comment Share on other sites More sharing options...
twoeightythreez Posted August 8, 2006 Share Posted August 8, 2006 Roggaman, I believe that full part # is 280-150-036 Link to comment Share on other sites More sharing options...
sfpar Posted January 28, 2007 Share Posted January 28, 2007 From what I've seen so far, you should be able to run Eclipse injectors (450cc/min)...these can be found for practically nothing. I personally have 4 sets laying around. Hey AWD.......any chance you would like to unload 6 of those bad boys? I'm in the market for that exact injector. PM me the details if it works for you. Thanks. Scott Link to comment Share on other sites More sharing options...
ben280zx Posted November 13, 2007 Share Posted November 13, 2007 I'm using the 440cc/min supra turbo ones in my car now, and they are high impedance. Hey Drax, So it ok to run it with high impedance on the l28det? I though tony240zxt said it was low? So I dont have to mod anything inorder to make it fit in my stock setup? Sorry to bring this thread back from the dead Link to comment Share on other sites More sharing options...
softopz Posted August 3, 2010 Share Posted August 3, 2010 Iam pretty sure supra 440 are low Link to comment Share on other sites More sharing options...
