fl327 Posted March 4, 2005 Share Posted March 4, 2005 Venus Auto in Sacramento is selling 1jz front clips for 1500.00 Quote Link to comment Share on other sites More sharing options...
cyrus Posted March 16, 2005 Author Share Posted March 16, 2005 I am tired of fooling around. I am now fabricating a full 3.5 inch (monster) exhaust system with formed bends and straight through mufflers. I also installed an Apexi SAFC II for fuel ratio. A Greddy BBC to eliminate the fuel cut that occurs at 15 PSI. A Apexi AVC-R to set the boost at 18 PSI. A Innovative Wide band sensor to keep the whole thing from blowing up. This car now sounds "ANGRY" under full throttle! Quote Link to comment Share on other sites More sharing options...
cyrus Posted March 28, 2005 Author Share Posted March 28, 2005 I just got a miller 210 mig-o-matic, which ROCKSSS! I just finished welding up my 3.5" exhaust system. The car is still quiet and the boost jumped from 11 to 16 PSI. 400RWHP here I come. Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted March 28, 2005 Share Posted March 28, 2005 Right on!! Keep the updates coming!! Quote Link to comment Share on other sites More sharing options...
cyrus Posted March 30, 2005 Author Share Posted March 30, 2005 I just got an Innovative LM-1 which I am just learning to use but can say that if you have a modded turbo car, buy it. I am trying to set the fuel at 12.0 but that is not easy to do on the road. A long 5 gear pull would be nice but not realistic, so I might go to dyno. I need to start posting picture of this stuff, unfortunately I do not have a service that will do this yet. Quote Link to comment Share on other sites More sharing options...
Clifton Posted March 30, 2005 Share Posted March 30, 2005 I found it's easiest to use the lowest gear you have traction in, get it to were it makes boost or whatecer rpm you need and left foot brake hard so you can see what the a/f is with out accelerating. Quote Link to comment Share on other sites More sharing options...
Hybrid240z Posted March 31, 2005 Share Posted March 31, 2005 Cyrus, go ahead and send me pics. I'll post them for you. You can send them to my hotmail account. Marcos Quote Link to comment Share on other sites More sharing options...
cyrus Posted April 4, 2005 Author Share Posted April 4, 2005 Here is my secret engine bay design Like an Oreo double stuffed Installed Beautiful Old 3" new 3.5" with straight through mufflers. Notice modified mid muffler Tuning is were it is at! If I only understood half of this... Quote Link to comment Share on other sites More sharing options...
Guest Battle Pope Posted April 7, 2005 Share Posted April 7, 2005 That 2J fills up the engine bay quite nicely! Quote Link to comment Share on other sites More sharing options...
ARZ_ Posted May 23, 2005 Share Posted May 23, 2005 Did you get the detonation under control? Quote Link to comment Share on other sites More sharing options...
cyrus Posted May 27, 2005 Author Share Posted May 27, 2005 I think the detonation is false as the ratio is 10 to 1 afr and the comp does not pull timing... Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted August 28, 2005 Share Posted August 28, 2005 I think the detonation is false as the ratio is 10 to 1 afr and the comp does not pull timing... Have you put an OBD scanner on it? Why do you think you have detonation? when you run race gas at the track is the MPH going up? Honestly - I'd snag an EBAY header, a small(ish) single, and put down some serious numbers. The stock twins are well good and fine to a point but are heavy (VERY!) and run out of breath early. A 61mm or better a 67mm turbo would allow you to make an easy 500RWHP - a T78 on my car running pure 93 pump made 550RWHP at just 1.2BAR of boost I end up at 720RWHP on my car on good gas with stock cams running a 71GTQ, 34PSI, a full 4inch exhaust, and an AEM EMS that I tuned. I have a ported head and cams which would've bumped HP by at least 100 however the car was totalled by a dumbass and I'm fighting with his insurance company. An SC300 and my chassis will yield one FAST SC300 and a GE drivetrain for the 240Z The GE motor with a GTE head will be wonderful and 600+RWHP is available with pump gas and meth injection. Are you finding the shifter position a problem? Any pics of the console? How did the dash turn out? Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted August 29, 2005 Share Posted August 29, 2005 ah ohhhh he's back... mike Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted August 29, 2005 Share Posted August 29, 2005 ah ohhhh he's back... mike Lol, I'm not totally gone. Just been concentrating on the other car and depressed at it's demise. The V8 just didn't quite suit me I think, I dunno'. I really like forced induction. I have a miniram for the V8 so who knows. After all I've learned about the 2JZ it's REALLY a motor I admire. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted August 29, 2005 Share Posted August 29, 2005 Hey John Doe!!! Glad to see you are still here. Sorry to hear about the car. Hopefully you can salvaged the drivetrain as it sounded like a killer setup. Hope to see you around and see what you put that drivetrain in. Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted August 29, 2005 Share Posted August 29, 2005 The drivetrain doesn't appear to have been damaged although the intercooler is wadded. I am fighting for a pretty HUGE settlement and will try to get the car back as sourcing all of those parts is a PITA. The car ran high 10.8s on pump with good tires and a smaller turbo, I figure with the ported head and race gas the motor will do great in an SC300. Once the SC300 is setup I'll turn my attention to the Z so this won't be overnight. I may even get it running again with the SBC before Winter truly hits. How's the RX7 doing? Holler sometime and update me on things! Quote Link to comment Share on other sites More sharing options...
Drax240z Posted August 29, 2005 Share Posted August 29, 2005 Hey Jim, been running across your posts on supraforums the last couple of days as I've been working on a 2jz-gte IS300... Glad you haven't forgotten us! Quote Link to comment Share on other sites More sharing options...
TomsCoupe Posted August 29, 2005 Share Posted August 29, 2005 ok, not trying to ruin this thread but DAMN!!! 24,000 views Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted August 29, 2005 Share Posted August 29, 2005 Hey Jim, been running across your posts on supraforums the last couple of days as I've been working on a 2jz-gte IS300... Glad you haven't forgotten us! Lol, of course I've not forgotten! I've got two L28s on my back porch I'm trying to get rid of cheap cheap - I cannot help but think of you guys when I trip over them Seriously though, I always point people this way who are working on weird swaps or 240Zs! Quote Link to comment Share on other sites More sharing options...
cyrus Posted August 30, 2005 Author Share Posted August 30, 2005 BLKMGK, your pics of 240Z 1jZ on your site were a big part of me deciding to do my swap. Last run the car was at 12.1@122mph. I think I can get more power out of the setup. I enjoy the thrill of turbo, too! Presently, the car is being rollcaged right now. I have tons of pics. and Quote Link to comment Share on other sites More sharing options...
