ShinyRedZ Posted August 2, 2009 Share Posted August 2, 2009 Just pulled my invoice from MM, dated 9/5/2007. Prices may have changed. All prices quoted in US$ Billet 6061 aluminum rotor spacer, one pair, for use with 240Z hubs and vented Toyota 4x4 calipters. Includes 4x4 240Z high grade rotor hardware. $118.80 Note: I changed the order from 240Z to 280Z with no change in price. Price does not include shipping. I basically deleted everything else from the kit to only get the spacer(s). Link to comment Share on other sites More sharing options...
Cuekoo Posted August 3, 2009 Share Posted August 3, 2009 118.00 sounds way better. I bought everything else for 100 bucks. I'll try and figure something else out. Thanks for the info ShinyRedZ, i keep hitting so many bumps in this build. Link to comment Share on other sites More sharing options...
logan1 Posted August 3, 2009 Share Posted August 3, 2009 Do i really have to pay $495.00USD for the Billet '4x4' Aluminum Hub? i looked on m and m and i didnt see anything about a spacer. I have a 240z and the front s12 and 300zx rotors. all i need is the spacer. So am i stuck paying 495 for a spacer? check the link below:) http://silverminemotors.com/product.sc?categoryId=14&productId=6 Link to comment Share on other sites More sharing options...
Cuekoo Posted August 3, 2009 Share Posted August 3, 2009 check the link below:) http://silverminemotors.com/product.sc?categoryId=14&productId=6 OMG love you logan! haha jk. Thanks man i appreciate it, i was feeling a bit discouraged about my build but that was a pick me up. Link to comment Share on other sites More sharing options...
Kevin.pk Posted August 3, 2009 Share Posted August 3, 2009 Do i really have to pay $495.00USD for the Billet '4x4' Aluminum Hub? i looked on m and m and i didnt see anything about a spacer. I have a 240z and the front s12 and 300zx rotors. all i need is the spacer. So am i stuck paying 495 for a spacer? you can change the selections in this product at MM to buy only the spacer..... for the stock 4 lug 240z, the spacers costs $110. http://www.modern-motorsports.com/catalog/product_info.php?cPath=60_61&products_id=48 Link to comment Share on other sites More sharing options...
ron260z Posted August 4, 2009 Share Posted August 4, 2009 Silver mine motors beats prices. Send him the link and he will give it to you for a better price. Plus they are in the us so shipping Is cheaper. Link to comment Share on other sites More sharing options...
logan1 Posted August 17, 2009 Share Posted August 17, 2009 Here’s the rotor spacer I designed for the 240Z hub. It features a lip that centers the rotor. This makes it more difficult to make but other spacers I have seen just use the mounting bolts for rotor centering which is not good engineering practice: http://home.earthlink.net/~zcarfan/sitebuildercontent/sitebuilderpictures/spacer.jpg oh yeah one more thing. is your spacer for a 240z hub or a NA z31 hub on a 240z spindle? i still have the issue of Q1. i think i read on the forums that for my setup id need a 0.5in spacer, but i cant seem to find it again or confirm. just asking because i notice your drawing shows 0.663in thick. thanks, john Anyone know which the exact dimension of the spacer required for the stock 240Z HUB? is it 0.5" or 0.663"? Link to comment Share on other sites More sharing options...
zcarnut Posted August 18, 2009 Share Posted August 18, 2009 Anyone know which the exact dimension of the spacer required for the stock 240Z HUB? is it 0.5" or 0.663"? I’ve used my adapter on over twenty conversions. The correct thickness is 0.663 inches. Why would it be “exactly†0.5 inch?? Link to comment Share on other sites More sharing options...
logan1 Posted August 21, 2009 Share Posted August 21, 2009 I’ve used my adapter on over twenty conversions. The correct thickness is 0.663 inches. Why would it be “exactly†0.5 inch?? thanx for the clarification. Link to comment Share on other sites More sharing options...
logan1 Posted August 21, 2009 Share Posted August 21, 2009 Anyone have a good drawing (with dimensions) for the rear caliper mounting bracket to mount the 280ZX calipers. Link to comment Share on other sites More sharing options...
logan1 Posted August 21, 2009 Share Posted August 21, 2009 Anyone have a good drawing (with dimensions) for the rear caliper mounting bracket to mount the 280ZX calipers. Anyone? I remember seeing one on the site but cant find it now that i need it. Link to comment Share on other sites More sharing options...
gildia Posted August 22, 2009 Share Posted August 22, 2009 You can find it here http://240z.jeromio.com/reardiscs.html http://240z.jeromio.com/images/RearDiscBracketSized.JPG Hope it helps Link to comment Share on other sites More sharing options...
Scott_M67 Posted August 23, 2009 Share Posted August 23, 2009 Steve, Did you ever have a chance to verify how much thinner your spacer can be machined to fit the 280 hubs? TIA "If you want to use the 260/280Z hub the rotor spacer can be thinner. I think the difference is 8mm but I am quoting from memory. I need to re-measure my spare hubs to verify." Link to comment Share on other sites More sharing options...
Swervey McZCar Posted September 1, 2009 Share Posted September 1, 2009 9mm is the correct thickness for the spacer when doing this swap on a 280z using the 84 vented rotors and the S12+8 calipers from a 87 Toyota 4x4 (with 4 pistons the same size, not the S12W). I know you didn't need that much information, but this thread has lacked some specifics I did have to "touch up" my calipers a bit with a carbide bit as the rotors glanced them a bit on their outside radius when the tire spun. I got a batch of remans that looked pretty used, so individual results will probably vary. Don't be scared of it, it was only a minute amount of material. -Stan Link to comment Share on other sites More sharing options...
jbryan Posted October 13, 2009 Share Posted October 13, 2009 Not to beat a dead horse - but can you use an aftermarket rotor such as the vented, slotted and cross drilled rotors of r1 concepts that are made for the stock 240-280z calipers with the S12, S12W or later 86-88 S12+8 Toyota calipers without using the rotor spacer? I am trying to save the $100-150 cost of the spacer. Thanks, John Link to comment Share on other sites More sharing options...
Silver Mine Motors Posted October 14, 2009 Share Posted October 14, 2009 you can use a stock rotor with an s12+8 caliper. the s12w caliper is vented and won't work with stock rotors. you would have to get the vented 300zx rotors with the spacers to make it work. if you need more help just pm me. Link to comment Share on other sites More sharing options...
FiveSeventyZee Posted October 16, 2009 Share Posted October 16, 2009 any chance anyone knows how much pick n pull charges for rotors/calipers? I found a set of 280zx rotors and calipers for $100 I can get semi locally, does that sound like a decent deal? Link to comment Share on other sites More sharing options...
Swervey McZCar Posted October 16, 2009 Share Posted October 16, 2009 That is a good deal. The calipers from an 82-83zx are $70-100 + the cost of the rotors. Pallnet has some for sale right now for $50 that include the braided hoses. He also has the correct brackets for sale. If you get them from a junk yard, make sure they come from a manual trans as the parking brake will surely be seized on an automatic car. Link to comment Share on other sites More sharing options...
FiveSeventyZee Posted October 18, 2009 Share Posted October 18, 2009 okay, I talked to the guy and I can get the calipers for $50 and I found new rotors for around $50. I figure since it costs the same, I should get the new rotors. they are selling 79-81 rear rotors and 82-83 rotors. which do I want? Link to comment Share on other sites More sharing options...
Swervey McZCar Posted October 19, 2009 Share Posted October 19, 2009 Go to page 1 of this FAQ. http://forums.hybridz.org/showthread.php?t=103767 For the rear, there are several different options depending on the calipers and bracket you use. What year car did the $50 calipers come from? Link to comment Share on other sites More sharing options...
