1 fast z Posted April 5, 2007 Author Share Posted April 5, 2007 Those are old pics in that thread, non of that holding/clamping mechanisim is going to be in the build. There are 4 long tie bolts going the length head, which is 17-4 PH stainless, for a high yeild strength. They are doweled together using hollow dowels, in ears that come off the thirds of the head. Ill post pics this weekend, of how it works. As for a tranny, I am going to be using a Z32 tranny, but IM going to see if I can get the ZXT T5 tranny to hold as long as I can. That weld is the finished product. Ive welded a "few" intakes, and never had a problem, so For now no grinding. NO time for that, LOL. Link to comment Share on other sites More sharing options...
Guest Surfsup Posted April 5, 2007 Share Posted April 5, 2007 very nice. indeed Link to comment Share on other sites More sharing options...
Daeron Posted April 5, 2007 Share Posted April 5, 2007 Those are old pics in that thread, non of that holding/clamping mechanisim is going to be in the build. There are 4 long tie bolts going the length head, which is 17-4 PH stainless, for a high yeild strength. They are doweled together using hollow dowels, in ears that come off the thirds of the head. Ill post pics this weekend, of how it works. As for a tranny, I am going to be using a Z32 tranny, but IM going to see if I can get the ZXT T5 tranny to hold as long as I can. That weld is the finished product. Ive welded a "few" intakes, and never had a problem, so For now no grinding. NO time for that, LOL. but you basically are counting on the head(s) being bolted down to hold it all together, as much as everything else? the bolts would hold it from any possible lateral force, which would be minimal, the dowelz hold it straight, and the headbolts (as always) hold it down? And you simply put gaskets between the head sections? I *really* like the look of this engine. You also said your camshafts were a secret.. are you being secretive just about the grind, or the vehicle from which your camshafts were sourced? as of the most recent info I had read, I thought I heard something like a standard RB cam would fit the saddles...?? Sorry to rehash it all, but threads on this subject are many and its difficult to find the "definitive" answer any way other than asking directly. Beyond that, just simply.. wow... Link to comment Share on other sites More sharing options...
1 fast z Posted April 5, 2007 Author Share Posted April 5, 2007 No Read my post again. FOUR 17-4 PH tie bolts go the length of the head that pass through 4 hollow dowells on each third to hold it in the latteral direction. Link to comment Share on other sites More sharing options...
Daeron Posted April 5, 2007 Share Posted April 5, 2007 No Read my post again. FOUR 17-4 PH tie bolts go the length of the head that pass through 4 hollow dowells on each third to hold it in the latteral direction. Beg pardon, I wasn't entirely clear.. thats what I meant by this... the bolts would hold it from any possible lateral force, "the bolts" being the lateral bolts, not the head bolts... Cool, I just wanted to make sure I grokked your final solution. That was about what I had figured you were gonna be left with. In the end, it seems absurdly simple.. more so than *I* ever thought it would actually be, anyhow. I just CANT GET OVER the fact that you've actually DONE this!! thanks for the reply Link to comment Share on other sites More sharing options...
1 fast z Posted April 24, 2007 Author Share Posted April 24, 2007 Ok, Heres an update on 4-24-07. Here I am boring the rods on the CNC for full floating pins using alluminum bronze bushings. Here we are setting up the rear third of the cylinder head for dowell reaming. Heres the block right after the block was done with machine work, and painted. Here are the ARP Main Studs Installed, getting ready to check for bearing clearences. Here is the crank inserted. Here is the VO7 Crank, as if I would use anything else, HAHA. Here is the rear third with the dowells installed for alignment. Here are the TIE RODS that clamp the entire head together for the force of gasket surfaces to be clamped. The tie rods are made out of 17-4 Precipitating Hardening Stainless, for a high yeild strength. And here the head is semi complete. Its Dowelled, Has the correct gaskets installed, and tie bolts. Here is how we attached the LOWER tie bolts to some blocks that we precision dowelled and counter sunk screwed to the front third head. This is the plate that bolts to the rear third head that the four 17-4 tie bolts go through and use as a clamping plate. Here is how the UPPER tie bolts attach to the front third head, we threaded right into the thickest part of the casting. Pic Of the tie bolts again. Here are the FORGED piston pictures, after I lightened them ofcourse. They have a mass of 325 grams, thats WITH a 250 thousands of an inch thick domes. Notice the strut that I left the center of the piston for strength. 25cc dish for a 8.25-1 Compression ratio, with KEEPING quench pads, VERY important. .125" wall A-2 Tool Steel wrist pins, full floating. Wrist Pin bushing installed with oil hole, on ONE side. Crank Installed after maintaing a .0012" Oil Clearence. Updated Timing Pictures, We decided not to use the geared sprocket idler, after some calculations, the forces would of been too high, so we modified some stock L series guides pretty heavily, and a few other tricks that are kept secret and here we are. Final Test Fit of the block and head. Pistons Installed. And the paint on the car didnt look good at all, so we through a "quicky" paint job on it for the time being. Link to comment Share on other sites More sharing options...
1 fast z Posted April 24, 2007 Author Share Posted April 24, 2007 Here also is the head installed on the block with cams installed. Link to comment Share on other sites More sharing options...
gjc5500 Posted April 24, 2007 Share Posted April 24, 2007 Wow. that is simply amazing. i wish i had access to a machine shop/the know how to do that. You should get some dyno numbers when its done and start producing those heads. how many hours/cost did the head itself take? Link to comment Share on other sites More sharing options...
nismopu Posted April 24, 2007 Share Posted April 24, 2007 if one was to surface grind each section of head would gaskets be needed you think? We do alot of surface grinding here at work for some of our plastics molds and in house parts occasionally placing an o-ring or two inside for extra sealing but its not common. With aluminums incredible expansion rate would a gasket still be needed, or even more so? peace. Link to comment Share on other sites More sharing options...
JSM Posted April 24, 2007 Share Posted April 24, 2007 1 fast Z, are you a machinest or just have lots of $$$$ or both? Very, very nice work! If you had to pay to have something like this developed, what kind of $$$ would that cost? Link to comment Share on other sites More sharing options...
Daeron Posted April 25, 2007 Share Posted April 25, 2007 1 fast z, I take it from the filename of the images that you dont really have a link you could post up for us to look at higher res versions of these images? The small pics are tantalizing, its almost not fair Link to comment Share on other sites More sharing options...
Tony D Posted April 25, 2007 Share Posted April 25, 2007 Is that car painted black? Midnight blue? Waitaminit, in 48 hours I'll see it anyway. I'll wait till then. But I know who it is at 10PM Friday night if the phone rings and someone is asking me if I still have my towbar handy... LOL See you at MSA Bryan! Nice shots. I like the Tie-Rod Idea. Link to comment Share on other sites More sharing options...
eec564 Posted April 25, 2007 Share Posted April 25, 2007 What are you going to use for a valve cover? Are you going to have to section the ones that came with the heads you sectioned? BTW amazing work, and how did you first even figure out this would work? Link to comment Share on other sites More sharing options...
nismopu Posted April 25, 2007 Share Posted April 25, 2007 people have been putting KA heads on L-4's for a couple years now because the head bolt spacing is the same and water jackets are pretty damn close too. I believe theres an oil drain on the back of the head that needs to be plugged but I am not sure in the DOHC case? 1 fastz do you think gaskets are absolutely neccessary between each section of the head if theyre surface ground? I am really ponderign doing this! peace. Link to comment Share on other sites More sharing options...
Mack Posted April 25, 2007 Share Posted April 25, 2007 History of the KA head idea and part 2 Bryan is just the closest to finishing it, or will actually finish it. dont hear much from TBS anymore. I should have mine running within a month or so, not in time for MSA obviously. The guy working on mine recently had a trip to England to hang out with an F1 team. Meh, Id rather do that than work on my head as well. P.S. Hey Bryan, half of your head is still mine, lol! Link to comment Share on other sites More sharing options...
1 fast z Posted April 25, 2007 Author Share Posted April 25, 2007 Well, half the head as far as EDM cost goes is yours, but engineering and Labor to this point is My dads and I! LOL. We are making doubles of what were doing, as my dad wants to prove this head on a NA car, so Were going to put the head on a flat top 3.1 liter that is in my silver 77 car. Link to comment Share on other sites More sharing options...
Mack Posted April 25, 2007 Share Posted April 25, 2007 and dont forget the heads themselves! Im just playin, foo! glad it looks like its gonna work out. Is ol' silver getting ITB's for it? Link to comment Share on other sites More sharing options...
1 fast z Posted April 25, 2007 Author Share Posted April 25, 2007 There is ALOT of cost in time that has gone into this project. Over 500 Man hours Between my father and I for sure. We have been doing LOTS of calculations, trial and error, quality controll, etc. The pics just show ideas. The ORIGINAL idea WAS mcadams Idea, plain and simple, and he came to me with the idea and we worked on some first ideas that some worked and some didnt. he then had to move to Minn. So he does recive credit for the ORIGINAL idea. Its not too dificulet to come up with an Idea, but making the idea WORK is the tricky part. Just like you cant patend an IDEA, per say, but you have to show a working model or proof of it. Lots of people have been telling me to patend this working model when its running, im not sure yet though. Like doweling the heads together, Im not going to post on the boards HOW we located, Where we located from, to be so precise. The pics were taken of the thirds before some final critical opperations were made, for the reason that we dont want to give out all of our secrets, but just to give you guys an idea on HOW it works. Im not going to go into detail on how we got the tie rods to be EXACTLY parrelell and perpendicular to eachother fron the rear of the head to the front, as they HAVE to be exact or they WILL exert forces in un-wanted directions and cause un-even clamping and therefore a possibly leak. These heads were off of two different KA engines also, and they were cut at different thicknesses in past time, as well as warped. So these pics give the basic idea, but FAR, and I mean FAR from the whole story from an enginerring aspect. MANY, of people on the boards, said to just weld the heads together, or JB weld them. Those ideas would of never worked, they would of created MANY forces/stresses that could of NEVER been taken out and therefore un-even cam wear, as well as rotaters, etc. As for a valve cover, its a full sheet metal one, thats completed, but dont have the camara here at the shop, but pics will be up soon. 1 Link to comment Share on other sites More sharing options...
alexideways Posted April 26, 2007 Share Posted April 26, 2007 :shock:WOW:hail: Link to comment Share on other sites More sharing options...
Careless Posted April 26, 2007 Share Posted April 26, 2007 There is ALOT of cost in time that has gone into this project. Over 500 Man hours Between my father and I for sure. We have been doing LOTS of calculations, trial and error, quality controll, etc. The pics just show ideas. The ORIGINAL idea WAS mcadams Idea, plain and simple, and he came to me with the idea and we worked on some first ideas that some worked and some didnt. he then had to move to Minn. So he does recive credit for the ORIGINAL idea. Its not too dificulet to come up with an Idea, but making the idea WORK is the tricky part. Just like you cant patend an IDEA, per say, but you have to show a working model or proof of it. Lots of people have been telling me to patend this working model when its running, im not sure yet though. Like doweling the heads together, Im not going to post on the boards HOW we located, Where we located from, to be so precise. The pics were taken of the thirds before some final critical opperations were made, for the reason that we dont want to give out all of our secrets, but just to give you guys an idea on HOW it works. Im not going to go into detail on how we got the tie rods to be EXACTLY parrelell and perpendicular to eachother fron the rear of the head to the front, as they HAVE to be exact or they WILL exert forces in un-wanted directions and cause un-even clamping and therefore a possibly leak. These heads were off of two different KA engines also, and they were cut at different thicknesses in past time, as well as warped. So these pics give the basic idea, but FAR, and I mean FAR from the whole story from an enginerring aspect. MANY, of people on the boards, said to just weld the heads together, or JB weld them. Those ideas would of never worked, they would of created MANY forces/stresses that could of NEVER been taken out and therefore un-even cam wear, as well as rotaters, etc. As for a valve cover, its a full sheet metal one, thats completed, but dont have the camara here at the shop, but pics will be up soon. <3 Link to comment Share on other sites More sharing options...
