Sign in if you own an s130!
007max
I owned an 80 280zx back in 82-84. Sold it when the family started arriving. Got the Z bug again in 2001 and bought my current 81 280zxt. Same silver over blue color as my first, but this one has t-tops and its a turbo!! I've slowly modified her from auto to 5-speed swap the first year to an intercooler last summer. Now I need to address the rust issues.
  frank280zx said:
I use generic coils the are in the 300 range and stiff as hell!
On the 40 tires and no rubber in the front strut assembly to be found all i can say from a little test ride ..
it is blood pissing stiff!
Given the struts are on their heaviest setting, also i use msa sway bars and adjustable end links ( one poly rubber in there)
do you happen to have a site mate to where you got them? easy install?
Great cars guys....
Here is mine:
Suspension:
1) Custom made coilovers front and rear with Tokico ProDraG imported from Japan
2) Suspension Techniques sway bars front and rear
3) Poly-urethane bushings front and rear
4) Every piece replaced....sand blasted and painted
Engine:
Stroker 3.0L LD Crank
240Z 9mm rods
JE pistons - 8.3:1 compression
Ceramic coated piston tops and skirts
Diamond Like Coatings on Wrist Pins
WebCams Turbo Grind Cam
Whitehead Performance extensively ported and polished head
Speed Shop Thagard T3T4 Turbo Stage 5 wheel - 360degree thrust bearings
Corky Bell Custom Made Intercooler - 2.5" inlet and outlet
ARP Head Studs
ARP studded bottom end
ARP rod bolts
Arizona Z Car flywheel
Clutchmasters Clutch
Flexalite twin 10" Electric Fans with manual overide and thermostat
Arizona Z car Radiator
Haltech E6X
JSK Fuel Rail
550cc Injectors
Walbro 255lp/h Fuel Pump
Aeromotive FPR
Lots of braided lines and polished parts
SFP custom made Exhaust Manifold
JamieT custom made intake manifold with 67mm Throttle Body
Tial 38mm wastegate
HKS SSQ BOV
3" Jeff Priddy Down Pipe
3" exhaust with Burns Stailness Muffler
Autometer Boost, Oil Temp, Oil Pressure, Water Temp and AEM AFR Gauges
Shooting for 450+ whp sooon.
Yasin
  cpt jack said:
is the 305 a smaller v-8? and well anyways do u like the motor? i been thinkin of goin with a 350...
smaller displacement but the same external dimensions as a 350. I haven't got to drive the car too much, but it seems to have a fair amount of bottom end torque.
^^^sorry to hear that, hope you get your car back to were it was. Iv always liked your ZX
Some people wanted to see how my car looked with the BRE spoiler so heres some pictures. Please excuse the wheels, im in the middle of either getting new wheels or spacers for my Advans
I've had my '83 for a little ove ten years now. T-top, 5 spd, NA coupe. I finally started really tearing into it at 274k miles. As she sits now:
Flat top pistons with N42 head.
Balanced internals, ARP Studs and Rod bolts.
Z31 ECU with Nistune. (Still wiring)
Much more stuff, but I'm too lazy at the moment.
  mikeatrpi said:
I think I'm in love KTM! Very tastefully done! I like the blacked out lighting and the drop- just makes the dark colored car look even more sleek. What are the window stickers? I'd buy a hybrid z sticker if it wasn't 2 square feet in size!
Thanks alot, its a PeteZ and Zdriver sticker. Dont usually like stickers on my car but there not to big
