Mikelly Posted March 3, 2012 Author Share Posted March 3, 2012 The car is on hold waiting for the traction control hardware. Should get it back next week. Mike Quote Link to comment Share on other sites More sharing options...
Mikelly Posted March 4, 2012 Author Share Posted March 4, 2012 Did I mention I'm dying to get this thing back? Spent yesterday mounting some Corbeau CR1 Seats in the BMW. Also mounted a Sparco harness bar that is a "universal" type deal. Will probably come out... Anyway, I need to get the 295-30-18s in for the rear so I can have those mounted up to the CCws. Can't wait to get that all mounted up and the car out for a little test and tune! Thing is going to be visually stunning. Mike Quote Link to comment Share on other sites More sharing options...
Mikelly Posted March 6, 2012 Author Share Posted March 6, 2012 Latest update... The car should be done and tuned, dyno'ed and ready for pick up by Thursday morning. There were some serious issues surrounding the fitment of the distributor that required serious work to it. Traction control is installed and everything else is being buttoned up now... Mike Quote Link to comment Share on other sites More sharing options...
EvilC Posted March 6, 2012 Share Posted March 6, 2012 Mike traction control controlled via rev limiter? Can't wait to see the car finish and to hear what you think. Quote Link to comment Share on other sites More sharing options...
Mikelly Posted March 6, 2012 Author Share Posted March 6, 2012 It runs off a pickup on the driveshaft. Pulls time when it detects lack of load. Should have it on track by the end of March, beginning of April. Mike Quote Link to comment Share on other sites More sharing options...
Mikelly Posted March 8, 2012 Author Share Posted March 8, 2012 I guess I spoke to soon. The trans apparently has to come out of the car. It's at the shop, and the bill is just climbing while I say to them "Go ahead, fix it" every single time something else pops up. Pretty disgusted with this 9 year project. I'm sure I'll be "excited" to get the car back running, but I'll be equally excited to see this MotherF'er go to a new home. Mike Quote Link to comment Share on other sites More sharing options...
rags Posted March 8, 2012 Share Posted March 8, 2012 What is wrong with the trans? Quote Link to comment Share on other sites More sharing options...
Mikelly Posted March 8, 2012 Author Share Posted March 8, 2012 Clutch will not travel... Can't push the pedal in more than 1/2 an inch. Mike Quote Link to comment Share on other sites More sharing options...
Mikelly Posted March 9, 2012 Author Share Posted March 9, 2012 Just got off the phone with the shop. They dropped the trans, replaced the clutch fork and release bearing. Saw now evidence of damage to the clutch or pressure plate. However, once everything was back together we still have zero clutch travel. I'm guessing there is damage to the clutch disc or pressure plate. More $$$$! My Porsche 996TT, yea I miss it sooooo much... Mike Quote Link to comment Share on other sites More sharing options...
stony Posted March 9, 2012 Share Posted March 9, 2012 Hey i have the same wing ;> let me know how it does at high speed. im kinda worried about it : > Quote Link to comment Share on other sites More sharing options...
EvilC Posted March 9, 2012 Share Posted March 9, 2012 Mike when you say zero clutch travel, you mean the pedal makes full travel but the clutch does not release? Just starting from the top, double checked the rod and clevis for the clutch master? I had one where the threads actually got stripped and I couldnt tell it was binding under the dash. Clutch master in good shape? Last would be to check the slave. I can't see if there isn't any physical damage to the pressure plate and the what I call fingers are still stiff why that would need to be changed out. Quote Link to comment Share on other sites More sharing options...
bjhines Posted March 9, 2012 Share Posted March 9, 2012 Wild guess... The splined hub has broken or is installed backwards and is blocking any movement of the diaphram spring. Quote Link to comment Share on other sites More sharing options...
Mikelly Posted March 10, 2012 Author Share Posted March 10, 2012 (edited) Nope... But good guesses... I was at the shop today and actually got to hear the thing run, and it's sick... Car is going to be so impressive with this stand-alone setup really... So I took the old Steel flywheel to them and chatted about a number of things, all related to the work I authorized. I then paid the current balance of $3500. It's pretty friggin' expensive to get professionals to troubleshoot and resolve issues like these... $900 dollars was due to parts replacement... So the parts... I kept that fuel injection so long that the injectors wouldn't flow even numbers, remotely. So the troubleshooting, the cleaning/ultrasonic activity to try and resolve them, and then the replacement of them, ran me about $750 for eight 42# units. Then there's the traction control hardware. Nothing right now available for my driveshaft, so they had to fabricate "stuff" for the sensor and make it work. There was also the broken starter... Yea, broken starter... Now we get to the crux of the issue with my clutch/trans... Remember the aluminum Fidanza Flywheel I just bought? Well I didn't get what I paid for and I didn't triplecheck the unit. And I installed it. Apparently it was the wrong flywheel, not being thick enough, by over 1/2 an inch. That flywheel ended up costing me what will likey be $2000 worth of troubleshooting (trans has been out a total of three times by the time this post has been made), and broke a starter, the clutch fork and release bearing. Yea, F' trying to get the car down on weight... I'll have it functional over form... The car will likely be done, and be home by Monday. We expect that the car will make much more power. The shop will be doing between 10-20 dyno pulls trying to simulate roadcourse laps on their Superflow dyno. It's been a long grind to get to this point. I think the move to FAST efi was the right move. I just wish I'd done it sooner. Mike Edited March 10, 2012 by Mikelly Quote Link to comment Share on other sites More sharing options...
Mikelly Posted March 10, 2012 Author Share Posted March 10, 2012 Things left to do at this time once the car is back home: Pull both front hubs and install ARP studs Get R6s mounted up to CCW wheels and on the car Collect parts for AIR tube evac on the exhaust and fab that up Locate a catchcan that will receive plumbing from valve covers and exhaust Order OEM CV Axle boots Install the Fuel Cell Suround panels. I still need to order a fire supression system and a coolsuit kit. Mike Quote Link to comment Share on other sites More sharing options...
bjhines Posted March 10, 2012 Share Posted March 10, 2012 I can't wait to see it. Mine is front heavy with the iron heads and iron waterpump. Quote Link to comment Share on other sites More sharing options...
Mikelly Posted March 11, 2012 Author Share Posted March 11, 2012 (edited) I want to recap a couple of design/specs items here, becuase after 21 pages some items will always get lost in the noise... Based on feedback from sharp guys like John Tedder and Mark Icard, I chose to go a different route with regards to the suspension and upgraded to 500# springs up front with 400# springs out back. My car's ride height was also adjusted based on specs based on John Coffey's recommendations from a couple years ago. My ground clearance from bottom of Xpipe (lowest spot on the car) to the ground is 2.75 inches. We're running a front 1 1/8th inch bar, with no rear bar. Using Koni 8610 struts and I plan to section the front strut tubes in order to allow more adjustment. Camber is adjustable both top and bottom with control arms and camber plates. Mike Edited March 11, 2012 by Mikelly Quote Link to comment Share on other sites More sharing options...
jt1 Posted March 12, 2012 Share Posted March 12, 2012 Quote Based on feedback from sharp guys like John Tedder and Mark Icard.... This is getting scary. jt Quote Link to comment Share on other sites More sharing options...
Mikelly Posted March 12, 2012 Author Share Posted March 12, 2012 Gonna pick the car up tomorrow, as they've called and said it's done. We picked up an average of 20HP and torque across the board from the switch to EFI. I'll have everything back tomorrow and a better idea along with the dyno charts... They said the car is very drivable and exceptionally "Crisp from off throttle all the way through redline. Mike Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted March 12, 2012 Share Posted March 12, 2012 Great news! Cannot wait to see it with the new wheels and Hoosiers! Dave Quote Link to comment Share on other sites More sharing options...
Mikelly Posted March 13, 2012 Author Share Posted March 13, 2012 The car is home... Still got a list of things to address, and the front wheel/tire combo is slightly to wide, causing some fitment issues... But here's a few teaser pics... Mike Quote Link to comment Share on other sites More sharing options...
