Unnatural Aspiration part 3
stony
Prepped left rear for the subtle z 1/4s. There was a crap load of bondo in the fenders. glad i decided to do that vs bonding them to the existing stuff. some of the bondo actually broke off as i was grinding!!!
Also got some of the front striped of undercoating (this stuff is a BIATCH!!!) and teh dor jams are ready for primer.
All the other parts are primed and ready for final sanding and paint. once those get painted the shell goes over.!!!!
On the trailer going to paint shop
All the parts sealed.
Base coat applied to parts
Clear coat applied.
Cant believe i may have a car ready to put back together in a month or so !!!!!
might pick up a mph or 2 on the trap speed with all that clear :) looking good.
Hope so :wink:
I'm also considering sending the converter in to get it restalled. right now its way too low and i cant get it to boost without NOS. shift at 9.5K and rpm drops back down to around 6K if i launch at a higher rpm and keep the rpms higher throughout the run it should make huge improvements.
Car just went to the body shop. We are going to bang heads on the best way to do it. but one way or another to give strength to the body, the wheel tubs will have to be welded to the body. The steel panels WILL have to be cut to accommodate the tires.
Any suggestions are more then welcome.
