DREW RBZ Posted August 10, 2009 Share Posted August 10, 2009 Well...first time this car has been to the track. I have not done any quarter mile stuff in years...and now I know I need practice. First run was done at 19psi with drag radials. (dynoed at 445rwhp at 18psi.) Not sure what car weight is Reaction: .926 Sixty foot: 2.031 1/4 mile: 11.86 @ 111.159mph Completely missed 4th gear and coasted in neutral through the traps. Second run....launched at 4500rpm and snapped a half shaft...let off before any further damage. Here are some photos of the carnage below. Snapped the shaft in half. End of my day:mrgreen: So...time to upgrade the shafts...likely going with Wolf Creek Racing CV's Any guesses to what this thing might run with someone who can drive?? Quote Link to comment Share on other sites More sharing options...
mark Posted August 10, 2009 Share Posted August 10, 2009 I've never seen one break there. Good job! Quote Link to comment Share on other sites More sharing options...
janaka Posted August 10, 2009 Share Posted August 10, 2009 Either have I, wow. Nice job on breaking it well. Quote Link to comment Share on other sites More sharing options...
RS Speed Posted August 10, 2009 Share Posted August 10, 2009 How long were you running those shafts before they broke. Im only pushing around 300hp/tq and was wondering if the stock shaft will take some abuse on street tires before breaking. I've been babying them and seeing you post makes me think they can take more abuse than I thought. Quote Link to comment Share on other sites More sharing options...
DREW RBZ Posted August 10, 2009 Author Share Posted August 10, 2009 Not sure of the history of these shafts but my guess is they are well used! There are guys putting down a lot more torque than I do without doing this kind of damage. Ive seen quite a few posts about broken half shafts and most are the result of extreme shock such as drag racing with sticky tires or road racing. I would think you will be alright on the street as long as you dont dump the clutch too hard at higher revs. I will not do any more quarter mile stuff until I get the CV conversion done...I think I am lucky to have not done any damage to the underside of the car/lines etc. when it let go... Quote Link to comment Share on other sites More sharing options...
wigenOut-S30 Posted August 10, 2009 Share Posted August 10, 2009 Wow, I have not ever seen the shafts break there! lol usually its the U joints that let go. I imagine with your power and depending on the .60 ft .. it should run mid low 11's Quote Link to comment Share on other sites More sharing options...
Careless Posted August 11, 2009 Share Posted August 11, 2009 That's how we do it up North. hehehe good stuff. low 11's are quaking in their boots right now! Quote Link to comment Share on other sites More sharing options...
stony Posted August 11, 2009 Share Posted August 11, 2009 Seems the stock half shafts don't like hi rpm, rb launches. especially with a strong clutch and traction. I was ok with mine till i started adjusting tire pressure to hook up. the V-8 auto guys dont seem to have half the problems we do with twice teh HP:icon56: Quote Link to comment Share on other sites More sharing options...
Canadianz Posted August 11, 2009 Share Posted August 11, 2009 Buhahahha, when you said "broke" you meant BROKE! Great time slip man, sorry about the half shafts though. Those pics sure are impressive ! What tires are you running in the rear end? Was that with a LSD ? Props man ! Quote Link to comment Share on other sites More sharing options...
Mike Rowe Posted August 12, 2009 Share Posted August 12, 2009 God Drew that looks nasty. Like you say lucky that didnt tear through the floor. The guy who fitted my fuel surge tank has positioned it above the drive shaft which I wasnt too happy about - now I'm definitely moving it. The CVs you mentioned - what are they, do they fit an R200 etc etc regards Quote Link to comment Share on other sites More sharing options...
DREW RBZ Posted August 12, 2009 Author Share Posted August 12, 2009 Canadian Z: The diff is a 3.7 lsd. Tires are Nitto Drag radials at 16psi. Mike Rowe: The Wolf Creek Racing axles I refer to are here: http://www.wolfcreekracing.com/wcrcvhalfshaftaxlekit.pdf You have to specify that they are for the R200 when ordering. Speaking with a couple of people who have run these they seem to be very tough but also mention that they are a bit "loose" describing the play in the shafts?" Not sure how this occurs but I was hoping one of the benefits of these CV's would be to tighten things up. I might go with the 300zx shafts I have for now...not sure yet. Quote Link to comment Share on other sites More sharing options...
Careless Posted August 13, 2009 Share Posted August 13, 2009 those are some heavy duty axles. i bet those nittos hooking had something to do with the those axels going poof! the looseness or play in the shafts is probably from the CV design. perhaps being of a different design they require a lot more free play to operate at higher power levels. who do you know that runs these and what kind of power/tq are they making? Quote Link to comment Share on other sites More sharing options...
rsicard Posted August 13, 2009 Share Posted August 13, 2009 Drew: Not sure if you have a 300ZXT R200 CLSD but Modern Motorsports (MM) has BEEFY Stub Axles that replace the 280Z stub axles (Eliminating design weak spot in 280Z stub axles). These together with 300ZXT half shafts should take MUCH more torque applied to the rear drive. They were designed to eliminate MM customer repeatedly SNAPPING new MM 280Z replacement stub axles. Quote Link to comment Share on other sites More sharing options...
Tony D Posted August 13, 2009 Share Posted August 13, 2009 Normally the failure mode is at the U-Joints. It appears there was a section there which had a 'crack' previously. Hard to tell from the photos, but that would be my intuition. Especially since it looks like you have the 'zerk style' U-Joints, which generally frag-out at the tapped holes for the zerks! Put it on the "Offerings to the Gods of Speed" Shelf. Everybody has one. You should, too. It has only begun! Quote Link to comment Share on other sites More sharing options...
Mike Rowe Posted August 13, 2009 Share Posted August 13, 2009 Canadian Z: The diff is a 3.7 lsd. Tires are Nitto Drag radials at 16psi. Mike Rowe: The Wolf Creek Racing axles I refer to are here: http://www.wolfcreekracing.com/wcrcvhalfshaftaxlekit.pdf You have to specify that they are for the R200 when ordering. . Drew these look excellent and are good value I think - just expensive for freight to us in Aussie. I may get a set of these Quote Link to comment Share on other sites More sharing options...
DREW RBZ Posted August 13, 2009 Author Share Posted August 13, 2009 Put it on the "Offerings to the Gods of Speed" Shelf. Everybody has one. You should, too. It has only begun! LOL...I have begun a "Wall of Carnage"...not sure if it should be rated PG13..some images are disturbing. Quote Link to comment Share on other sites More sharing options...
900ss Posted August 13, 2009 Share Posted August 13, 2009 So 445 @ the wheels and it broke a shaft? I'd be happy with that Quote Link to comment Share on other sites More sharing options...
rsicard Posted August 13, 2009 Share Posted August 13, 2009 After getting strong half shafts, then the stub axles will break at their design weak point. After that comes breakage of the diff itself. Quote Link to comment Share on other sites More sharing options...
Slammed68 Posted August 13, 2009 Share Posted August 13, 2009 I make upper 300's and only broke the aftermarket Zerk'd U-Joints. I bought stock axles with stock U-joints for both sides and have given them hell on the street and on the track with street tires. Lots of clutching action and they still haven't grenaded. Quote Link to comment Share on other sites More sharing options...
softopz Posted August 15, 2009 Share Posted August 15, 2009 wow good work andrew! time for the 300zx cvs! Quote Link to comment Share on other sites More sharing options...
