EvilC Posted November 24, 2009 Share Posted November 24, 2009 I can say for sure now that this is one clean car! Def worth the wait and money! This car is going to be very nice when done. I can't wait for the Spring to see this thing moving down the road. Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted November 24, 2009 Author Share Posted November 24, 2009 SaWEEEEEET! Quote Link to comment Share on other sites More sharing options...
ZR8ED Posted November 24, 2009 Share Posted November 24, 2009 Hmm how about some rod ends for your linkages. I seemed to have stumbled on a set in my garage..Not sure if they are left AND rights though. Make your own linkage. I've seen some nice custom setups over the years. I had mine modified with return springs on the bell cranks to reduce the stresses on the linkages. BTW it also kept them sealed up nicely for an even idle, and gave enough peddle feel to dial in subtle throttle transitions on corner exits. Congrats on the project! Quote Link to comment Share on other sites More sharing options...
mikeatrpi Posted November 25, 2009 Share Posted November 25, 2009 Dave it looks great! I'm looking forward to seeing it in the spring! Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted November 25, 2009 Author Share Posted November 25, 2009 Hmm how about some rod ends for your linkages. I seemed to have stumbled on a set in my garage..Not sure if they are left AND rights though. Make your own linkage. I've seen some nice custom setups over the years. I had mine modified with return springs on the bell cranks to reduce the stresses on the linkages. BTW it also kept them sealed up nicely for an even idle, and gave enough peddle feel to dial in subtle throttle transitions on corner exits. Congrats on the project! Sure shoot me some pics of what you can find! That would be very helpful. I intend to make my own billet drop-arms but I still need good links and balls down to the carbs. The ones on the carbs now are all sloppy. Quote Link to comment Share on other sites More sharing options...
Tony D Posted November 25, 2009 Share Posted November 25, 2009 The linkage on that manifold consisted of some drill rod (appropriate diameter, 8 or 10 mm I believe), three heim joints (Same hole diameter, with threads to mactch manifold) and jamb nuts, two stop collars (one with a hole for provisioning a return spring on it), and a few bellcranks for the rods to attach to... And cable throttle with quadrant is my preferred way of setting up the rod. Looks like you got a downrod in the 'one of these things is not like the others' catagory. All that stuff is available new TWM or any number of places sells linkage bits. Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted November 26, 2009 Author Share Posted November 26, 2009 Thanks Tony. I will check TWM. I tried the usual McMaster but they charge ridiculous prices for these things. My next guess was giant scale RC planes where nice links were available for ridiculous prices again. I may just hack out some aluminium downlinks as well. They don't need to be adjustable if the upper links can be clocked with a set screw clamp arrangement. I can just make a solid link with shoulder bolts on either end. Quote Link to comment Share on other sites More sharing options...
Titus_RacerX Posted November 26, 2009 Share Posted November 26, 2009 I can't believe how clean the floorpans are! It was well cared for and I'm glad to have been of help and very jealous! I wonder what "Sparks" is saying now to your purchase! — Lee Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted November 27, 2009 Author Share Posted November 27, 2009 Of all the car stuff I have done in my life, bodywork is the one thing I never invested any time into. I really don't have the sculptors hands. However I do know how to hold a can of spray paint. The paint in this car is OK but it is flaking in the engine bay. I posted another thread about it. I was going to strip it off and repaint it. I decided to get the loose stuff off, and spray-can it as a temporary fix. So I got online, researched the color. I was told it was an 80's Ford Red#24. After some research I found out it was 87 Ford Medium Merlot #2H. I found someone to mix me up a rattle can of #2H. So tonight I decided to sand one of the areas that had chipped. Then I primed it with a high build from a rattle-can. An then came my first time ever....painting a car...albeit with a rattle-can. I was floored. It came out MUCH better than I had expected. My goal was to get a decent coat of paint over the bare metal to keep it from rusting until a real paint job comes along. I think I got much more than that for about $25 worth of supplies. I am even more excited about this build, since I discovered I can actually make this car look really nice with only a little bit of touching up. Quote Link to comment Share on other sites More sharing options...
Sparks280zt Posted November 28, 2009 Share Posted November 28, 2009 I can't believe how clean the floorpans are! It was well cared for and I'm glad to have been of help and very jealous! I wonder what "Sparks" is saying now to your purchase! — Lee The same thing I have been saying, so wonder no more. Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted November 28, 2009 Author Share Posted November 28, 2009 It's water under the bridge, guys. +/- $1500 in a thorough Z project is peanuts. Keep it real. Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted December 14, 2009 Author Share Posted December 14, 2009 A few updates. Front end is all done. Rear end is all out and getting washed and painted with new struts springs, bushings and seals just for good measure. I mocked up the interior. I should have the rear end all freshened up and installed within the next week or two. Once the rear is in, I will work on completing the interior and going over all the HVAC stuff. Then I will bleed the brakes and put her on the Panasports. Once on the ground and rolling again, I will begin the refresh of the L28. 2 more months ETA. The fresh canvas Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted December 14, 2009 Share Posted December 14, 2009 Looking good Dave did you install a new rack or just cleaned up the old one? Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted December 15, 2009 Author Share Posted December 15, 2009 The car came with two racks and two columns...lol. I cleaned one of them up, and painted it. Fresh grease and paint. Quote Link to comment Share on other sites More sharing options...
letitsnow Posted December 15, 2009 Share Posted December 15, 2009 Wow, you work fast! Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted December 15, 2009 Author Share Posted December 15, 2009 Fast because I am laid off. Lots of garage time! Quote Link to comment Share on other sites More sharing options...
EvilC Posted December 15, 2009 Share Posted December 15, 2009 Fast because I am laid off. Lots of garage time! Tell me about it, I have a job for you once you are done! If my 70 turbo car goes half as fast I would be happy Anyway car is looking great and I know you will have her done for track in May Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted February 14, 2010 Author Share Posted February 14, 2010 Did a little more work.... BTW Long handled barbecue brushes from the dollar store, with the scraper blade on the end and the brass bristles, are AWESOME for scrubbing and scraping the dark side. 23 years of paint oxidation partially removed from a fender with a quick wax/cleaner. Quote Link to comment Share on other sites More sharing options...
Bahraini240z Posted February 14, 2010 Share Posted February 14, 2010 clean job mate... all da best Quote Link to comment Share on other sites More sharing options...
jhm Posted February 14, 2010 Share Posted February 14, 2010 The new ride is looking so fine, Dave....nice work! Those seats are SWEEEEEEEET. Looks like you're not wasting any time digging into her. Good luck with the rest of the build! John Quote Link to comment Share on other sites More sharing options...
