subtle_driver Posted March 9, 2013 Share Posted March 9, 2013 I'm confused. So this OBX diff is confirmed to bolt in to a 280z r200, or a 280zx 3.90 diff? I have a 3.90 from a 280zx with halfshafts in my 240z and want to buy this and the install kit. Will it work? Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted April 2, 2013 Share Posted April 2, 2013 So my OBX diff should arrive this week, and my rebuild kit is here already. I took a look at the FSM to see what I'm in for as far as putting it back together again and my head began to spin. I hear mention on hybridz of shimming the ring gear and checking backlash upon reassembly but that's it. What about shimming the pinion gear, side bearings for preload, and checking the pattern on the teeth? I would imagine all this can be thrown off when installing a cheap Chinese carrier, but mention of these procedures is scarce. If I can get my hands on a dial indicator, I figured I'd put it back together the way it came apart and check the back lash tooth wipe patterns. If they don't look right I supposed i could stuff my pockets with cash and head down to a driveline shop, but ideally I'd like to do it myself. Am I over-thinking this, or are most people neglecting (to mention?) these crucial steps? I have zero experience with diffs, and minimal experience with transmissions, but I'd at least like to try it myself before shelling the cash for someone else to do it. Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted April 9, 2013 Share Posted April 9, 2013 Update: Diff has a arrived. I pulled it appart and found that 1 bolt that was about 1/2" shorter than the rest, and was stripped to hell. it also damaged the thread in the case which I attempted to retap, however the case material seems very hard (good thing I suppose) and it just stripped my tap. I thought my tap set was decent, but I supposed I'll bring it to a machine shop to have them do it. Perhaps they can check runout on the ring gear flange. It seemed Honda guys were have issues in that department, but I haven't heard of that here. Also I may be crazy, but the alignment dowel in the case seemed to have magically disapeared. I swore there was one there, though I can't see it being a huge deal if it's missing. Link to comment Share on other sites More sharing options...
DuoWing Posted May 16, 2013 Share Posted May 16, 2013 I too just got my OBX, which I decided to go with after reading through these threads. Haven't opened it yet, that will be the weekend project. Anyway from what I can tell through the small holes on the side that it looks like my gears are actually facing the correct way, but I'll find out once I open it up. I have the rbryant rebuild kit ready to go so this should be an interesting experience. Link to comment Share on other sites More sharing options...
DuoWing Posted May 28, 2013 Share Posted May 28, 2013 Sorry to double post in this topic, but I'm past the point of editing my previous post. Anyway I'm curious how you guys judge when the case is snug? I'm in the process of doing this and basically what I'm doing is just leaving the diff on the floor and using a wrench to tighten the bolts until the point where I can't tighten the diff case bolts anymore without holding onto it/clamping it down. So every turn past this is at least now starting to register torque on my digital torque wrench. Is this a good way to judge or should I be further back? Link to comment Share on other sites More sharing options...
spiff Posted September 19, 2013 Share Posted September 19, 2013 Hi guys, I have now installed my obx diff and I have a question for you, have anyone noticed their diffs getting louder after install, howling or whining? Mine is howling pretty loud in the 45-70kph area, disappears completely under or over that speed Problem is I can't compare with how it was before because I have never driven with this diff. Stock I had a 3.5 installed, then I bought a zx turbo engine and driveline and put the obx in the 3.36 diff and installed it in my car just recently. The car the diff came from had about 260-270 thousand km's on it so it's definetely got some mileage on it though....could it be a worn pinion bearing perhaps? Link to comment Share on other sites More sharing options...
JMortensen Posted September 20, 2013 Share Posted September 20, 2013 Pinion bearings are a common issue on the R200s. It's usually the ball bearing right inside the pinion flange. You could remove the LSD and then spin the pinion and feel for gritty feeling to test it. Link to comment Share on other sites More sharing options...
Ben280 Posted October 19, 2013 Share Posted October 19, 2013 Just a thought, has anyone tried drilling out and re tapping the ring gear to accept 12mm bolts? I have a set from a s13 diff that I would like to try and use. I can think of a couple issues that slow and methodical work would fix, but any major problems I should be aware of? Link to comment Share on other sites More sharing options...
Trevor Posted October 30, 2013 Share Posted October 30, 2013 (edited) Quote ..has anyone tried drilling out and re tapping the ring gear to accept 12mm bolts? I have a set from a s13 diff.... short nose gear set won't work in a long nose diff housing. Edited October 30, 2013 by Trevor Link to comment Share on other sites More sharing options...
Ben280 Posted November 1, 2013 Share Posted November 1, 2013 I'm aware of that, should have clarified, the bolts I'd like to use are those from the s13 rear end, and fit the OBX better than the 280z bolts. I've done some reading, and it sounds like the ring gear is pretty tough to drill, but anybody have any success? Link to comment Share on other sites More sharing options...
JMortensen Posted November 1, 2013 Share Posted November 1, 2013 On 11/1/2013 at 3:42 AM, Ben280 said: I'm aware of that, should have clarified, the bolts I'd like to use are those from the s13 rear end, and fit the OBX better than the 280z bolts. I've done some reading, and it sounds like the ring gear is pretty tough to drill, but anybody have any success? The tapped holes are in the ring gear, so you'd not only need to drill them but also blind tap them. Just run the 10mm bolts with the mcmaster.com spacer. The ring gear bolt strength isn't likely to be an issue. Link to comment Share on other sites More sharing options...
Ben280 Posted November 2, 2013 Share Posted November 2, 2013 Thanks Jon! Link to comment Share on other sites More sharing options...
subtle_driver Posted November 5, 2013 Share Posted November 5, 2013 So to clerify, I have a 280zx n/a 3:90 diff in my 240z all stock axles. I bought the mc master ring gear bolt spacers, and the washer/bolt kit. is there anything else i need to finish this project? does this sound right? so i pull the stock cover off, and the axles, then remove the two half-moon shaped pieces to remove the center housing with the ring gear attached. then i remove the ring gear, and install it to the obx unit, then install it again and install those c-shaped parts and check for backlash? what steps am i missing? Link to comment Share on other sites More sharing options...
JMortensen Posted November 5, 2013 Share Posted November 5, 2013 http://forums.hybridz.org/topic/54124-step-by-step-installing-an-lsd-into-your-open-diff/?p=488661 Warning! The OBX apparently isn't machined to the same tolerances as the Nissan stuff so most people ARE having to adjust the backlash. Not a big deal to do that, but the writeup says that you probably won't. Link to comment Share on other sites More sharing options...
Rob240z Posted November 6, 2013 Share Posted November 6, 2013 I can confirm what Jon just said. I put an obx in this summer and the backlash was not right. At the time I didn't have the shims to adjust it, but if I switched the shims to the opposite side it was pretty close, but not within specs. I put a couple hundred miles on it like that and it was whining pretty badly. I'm about to take it back out and shim it correctly this time. Hopefully I didn't damage anything. Maybe someone will read this and not make the same mistake I did. I wouldn't normally do something like that, but it was only a couple days to zcon and I didn't want to miss it. Rob Link to comment Share on other sites More sharing options...
DuoWing Posted February 28, 2014 Share Posted February 28, 2014 (edited) I just finished installing my OBX into the housing a few minutes ago. I put it in with new Timken bearings, and kept the shim alignment exactly as it came out, I'm also using an R200 out of the Z31 if that makes any difference so I didn't need the spacers for the ring gear bolts. Anyway I measured the backlash, and unless I did something wrong I was coming out at right about .006in. I didn't have the tool for when I took the diff apart, so I'm just going with the fact that it fit factory specs. Edited February 28, 2014 by DuoWing Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted March 20, 2014 Share Posted March 20, 2014 (edited) On 11/5/2013 at 4:26 AM, subtle_driver said: So to clerify, I have a 280zx n/a 3:90 diff in my 240z all stock axles. I bought the mc master ring gear bolt spacers, and the washer/bolt kit. is there anything else i need to finish this project? does this sound right? so i pull the stock cover off, and the axles, then remove the two half-moon shaped pieces to remove the center housing with the ring gear attached. then i remove the ring gear, and install it to the obx unit, then install it again and install those c-shaped parts and check for backlash? what steps am i missing? You will definitely want to replace the bellville washers and case bolts with higher quality ones from R Bryant or Mcmaster & Carr, check to make sure the gears are properly orientated, and many, including myself opt to file down any rough edges or casting flash that could break off later. All of this is covered earlier in the thread. You will have to press carrier bearings onto the OBX case, removing the old inner races intact can be tricky, but if you are able to order straight from the bearing manufacturer, the bearings are very cheap to replace (think I paid about $12/ea straight from SKF). When it's back together, check back lash and shim accordingly, and finally check the gear wipe pattern. This might be best done at a driveline shop if you don't have the tools and a collection of shims. I paid about $150 to have it done. Edited March 20, 2014 by m1ghtymaxXx Link to comment Share on other sites More sharing options...
JMortensen Posted March 20, 2014 Share Posted March 20, 2014 You shouldn't need to check the pattern. The pattern is largely determined by the pinion depth. If you get the backlash back to where it started, the pattern will be the same as it was before. Link to comment Share on other sites More sharing options...
DuoWing Posted April 11, 2014 Share Posted April 11, 2014 (edited) Do these obx units not have axle circlips in them? This is something that I didn't realize when assembling the obx and now I can't seem to pop the axle shafts into the diff and get them to lock in. Anyway, I managed to pull the circlips out of the old diff. Now I have no clue how to compress and install them into the new one. Any tips? I tried to put one in an attempt, ended up managing to mangle up the clip and get it back out. Are there any generic ones that have the eyelets that can be used? Edited April 12, 2014 by DuoWing Link to comment Share on other sites More sharing options...
Rob240z Posted April 12, 2014 Share Posted April 12, 2014 I did a very similar thing when I installed the obx in my car. This is the thread on here that describes how I got them in without taking the diff apart. I did it with the diff installed in the car. http://forums.hybridz.org/topic/114145-what-happens-if-you-dont-install-retaining-clips-for-280zxt-cv-axles/ Link to comment Share on other sites More sharing options...
