4
softopz last won the day on December 9 2018
softopz had the most liked content!
About softopz
- Birthday 11/06/1972
Contact Methods
Website URL
www.protunerz.com
Gender
Male
Location
Ontario Canada
Recent Profile Visitors
18535 profile views
softopz's Achievements
Megasquirt Plug and Play Harness and Pre configured ECU's
softopz replied to softopz's topic in Vendor's Forum
Say no more. Ms3x kit has been out for some time we don't post much on the forums.. fully sequential, flex fuel, oil/fuel pressure sensors, pwm idle, stepper IAC, boost control. Launch, fan control, and much more . Includes pressure sensors x2, speed sensor, TPS, air and coolant temp sensors. https://protunerz.com/collections/plug-and-play-harness/products/ms3x-ecu-l-series-plug-and-play-harness-kit -
Progress on my insane VQ35HR 240Z project
softopz replied to markrolston@mac.com's topic in Nissan V6 Forum
😍 Been following this one for awhile. Keep it up more info on transmission please. Which ECU are you going with? -
ProTunerz l-series intake manifold w/ throttle body + fuel rail
- 11 replies
- intake
- intake manifold
(and 2 more)
Tagged with:
NO hes hearing the injectors click not dizzy. Could be a bunch of reasons Here are some I would check in this order. Could be no power to the coil simple check with a light. IF YES check this.... Relay, Fuse, Physical connection. IF NO PROCEED to next Coil Wire to dizzy nice and snug. if yes continue COIL is bad How to check- Check FSM there are resistance test. IF good proceed. bad connection between COIL (NEG) to transistor source external / internal pin36 Ohm out. Bad transistor external / internal ( I doubt it ) If I had to guess its the BIP transistor touching the heat sink/too much thermal paste. Assembly guide as for using metal screw i use the nylon there. IF it is this you still learned something like trouble shooting flow chart. Goodluck
I got one pm me , tried pm'ing you says you cannot recieve.
INTAKE (4 colors Red, Blue, Flat Black , Polished) Anodizing at no extra charge Angled Plenum/Runners: improves air flow smooth transition into head allows easier access to Header/DownPipe for maintenance. Less Heat soak due to reduced heat absorption properties of materials (when compared to stock and other aftermarket manifolds). CNC BILLET Flange with built-in fluted runners to minimize eddy turbulence and promote nearly even cylinder head aspiration at all ports. Gorgeous Fabrication: TIG welded Aluminum Bolts and Fittings included. Vacuum ports: 4 on the top/side to support vacuum-based accessories and accurate MAP readings. Durable Finish FUEL RAIL (5 Colors Black, Polished, Red, Blue, Purple) Fuel Rail designed for 14mm/11mm Or oem Barb style Injectors ORB-8 inlet with 6AN male fitting ends Fuel Pressure/Sensor Port (Plug included) THROTTLE BODY (Will match chosen manifold color by default. (Otherwise message us for different color selection). 90mm Throttle body, Improve throttle response and increase air flow! Cable actuated. Improves throttle feel and smooths pedal feedback. (Plus no more yellow balls and ugly mechanical linkage!) Utilizes stock OEM TPS/240sx or 2jz adapters included! (for modern Engine Management Systems that require potentiometer) Shipped Via Express Tracked and insured. Intake is very well packed with dense foam to ensure perfect delivery. Please view pics- 11 replies
- intake
- intake manifold
(and 2 more)
Tagged with:
I went through the same struggle for a number of years too!! Thats why I mentioned MS2 ironically we now are a dealer for Megasquirt and offer a turn key package. That includes Pre-configured ECU, plug and play terminated harness + fusebox/sensors/
I would start with when this happened you mentioned 4 years ago it was running. And then what suddenly no spark? Can be a couple of things. I would start troubleshooting backwards if that helps. You mentioned You swapped an HEI module why did you do this? Pull out the FSM for zxt there is tests you can do for: COIL CAS IGNITER (transistor) You can try to the PRW2 ignitor from later Nissans they are plentiful. There is a writeup on that somewhere. "Now i had this engine running 4 years ago although not very well I think it was low spark from the old coil." This all to familiar to me. Honestly, do yourself a favor and get rid of the stock 82/83zxt ECCS system they are very troublesome. You can get a 300zx ECU/MAF for cheap or ms2 system (we do offer a plug and play complete system) I went through the same thing 15 years ago trying to diagnose, trouble shoot and crap shoot everything. Even when it ran would sputter and backfire. Ahh good memories........ Also did you verify with multimeter while IGNITION ON and RUN something easy overlooked. You also mentioned you get a spark jump while you turn on ignition on that is very strange.
I know who makes these hes local to me and he does good work. Support smaller local Datsun Parts suppliers who are hobbiest just like you and I. p.s. we need to talk me and you
240z,260z,280z,300zx, L28Turbo Garage Sale w free stuff
softopz replied to DZtinkerman's topic in Parts for Sale
Do you still have the hazards / choke, and I'll grab the distributor off you. -
I haven't done the cooling mod. To be honest I don't know at the moment.- 11 replies
- intake
- intake manifold
(and 2 more)
Tagged with:
As you guys may have seen on social media we are almost finished putting the final touches, for a custom intake manifold for the l-series. We thought it only be fair to post here as well. Here are the details... Finally a Beautifully Tig welded Aluminum Intake Manifold For the L-Series motors. With a choice of 75/ 90mm Throttle body and Fuel Rail. We have been researching and devoloping this behind the scenes it is a very well thought out piece that has function and form combined. Link to store with full details (75mm intake set) Follow us on our Facebook and Instagram by giving a like to stay up date with new product development and sales. now check out sweet shots!! More on our social media pages Link
- 11 replies
- intake
- intake manifold
(and 2 more)
Tagged with:
Does that intake clear inner fender? Specifically throttle body/tps. Mine is hitting needs to be either clocked 90 put cable from top of manifold, cut out/bang fender/shock tower, or change angle of the flange at intake side. Thats for me with 2jz, cx mounts(altered them to have motor in the middle though. Dont know about if you fitted before or not.
I wouldnt tie into sensors grounds for the reasons you described above. CLT sensors are like 20 bucks (pm me I carry metric and npt type with connectors) if you sucked it up for an ms3pro and speedhut. You dont have to run the oil pressure sensor for ms but with so much spares inputs , it is a nice additional add on you can set parameter like limp mode if oil pressure goes down etc.
JoesZbuild started following softopz
softopz changed their profile photo
240z parts R200 VLSD 300zx Turbo axles, r200 finned cover l28et engine
softopz replied to softopz's topic in Parts for Sale
NO Finned cover left ! TURBO MOTOR SOLD updated in the top.
