Brake upgrade FAQ
  • Please log in to reply
54 replies to this topic
#41 Namor
Namor
    Junior Member
  • Donating Members
  • PipPipPipPip
  • 156 posts
  • LocationAugusta, GA
Posted 10 December 2012 - 01:28 PM
The longer of the two brake lines is for the passenger side and the shorter one is for the driver side.
The passenger side should have a Male M10x1.0 Inverted Flare on the end
The driver side if I remember correctly is a different fitting with an adapter to be Female M10x1.0 Inverted Flare.
The passenger side brake line is designed to reach directly to the Tee above the diff.  It should thread directly into the Tee.  For the driver side, you will need a hardline to go from the Tee to where it will connect with the stainless steel flexible line.
#42 Fairlady240Z
Fairlady240Z
    Moving Up
  • Members
  • PipPip
  • 25 posts
  • Locationpittsburgh PA
Posted 21 December 2012 - 02:29 PM
O.K. here is a question I have that I could not find in the FAQ section. I purchased the Z31 5lug hubs from Modern-Motor Sports with +40 offset, using the 300ZX vented rotors, calipers are the Toyota S12W.  My question is what is the thickness of the spacer that is needed to push the rotor back far enough from the hub so that it will mate up with the caliper.  Tried contacting Ross at MMS but to no avail, no response.
#43 EastTnZ
EastTnZ
    Always Here
  • Members
  • PipPipPipPip
  • 249 posts
  • LocationTennessee
Posted 25 December 2012 - 09:21 AM
Ok I just got a brand new 79-81 280zx master cylinder from autozone as it was cheaper than finding one in a junkyard... Well the mc is stamped with 7/8 on the side and looks exactly identical to the mc already on my 76 280z.  So apparently they've done away with the 15/16 mc and said the 7/8 is sufficient for replacement mc's.
Has anybody run across this problem?  I would rather have a brand new or refurbished part than have to rebuild it once I pay for a used one.
After re reading this I may just take my refurbished toyota calipers (s12+8) and mc back and find a nice set of pads and new rotors for now.
Still looking for that completely rust free Z...
-1976 280Z 5.3L S366 TR6060 - 12,120+ miles since the swap...Vintage Air added
http://www.flickr.com/photos/easttnz/
-2012 2500HD Silverado CCSB 6.6L
#44 LanceVance
LanceVance
    There are some who call me... Tim?
  • Members
  • PipPipPipPipPip
  • 634 posts
  • LocationEl Paso, Texas
Posted 25 December 2012 - 10:01 AM
Possibility 1: Autozone and the like are selling the 7/8 MC as a replacement for the 15/16 unit - Unlikely
Possibility 2: Someone upgrading turned their 7/8 MC in for the core - Very likely!
Have you considered swapping your booster and MC with those found in the later ZX? Seems people have been doing that ever since the 79-81 MC supply started drying up...
2011 Subaru Impreza STI Limited Sedan - Daily Driver
1973 Datsun 240z - Running tripples, getting the L28ET!
1975 Datsun 620 Pickup - Future SR20/Ratrod project
#45 Bowtie29
Bowtie29
    Moving Up
  • Members
  • PipPip
  • 28 posts
  • LocationKalamazoo, MI
Posted 15 August 2013 - 07:58 AM
For those of you running S130 calipers on both the front and rear, what rotors and pads are you running with them? Stock replacements? Or some sort of upgrade.
I'm looking to keep my stock brakes on my '83 280zx, but I would like to put good rotors and pads on it. Anyone have the part number for some Hawk HP pads both front and rear? Everything I find online says it fits the rear calipers. Nothing's specifically says front pads.
Are any of you running slotted rotors or even some of those "ABT" rotors off eBay? Are the eBay ones any good? I'll probably just put a stock replacement rotor on the rear.
Thanks.
'83 ZX, 383 LSx/T56
'85 C10, 408 LSx/4L80e, x275 drag radial, mono leaf, CalTrac bars, 9"
'74 F100 junkyard 5.3, cam, eBay GT45 turbo, TH400, 9"
'00 Silverado 1500, 5.3, cam, daily driver work truck.
#46 skirkland1980
skirkland1980
    Junior Member
  • Members
  • PipPipPipPipPip
  • 879 posts
  • LocationMarietta, GA
Posted 15 August 2013 - 06:12 PM
MSA sells an upgrade front pad for the late S130. I haven't used them I've just seen them on the site. EBC also has some.
Edited by skirkland1980, 15 August 2013 - 06:13 PM.
:1983 280zx turbo, L28ET, custom cam grind, 96 saab 900 intercooler w/2.50" piping, 3" mandrel bent exhaust, megasquirt II v3.57, 540cc injectors, walbro gsl392 255lph fuel pump, aeromotive regulator, -6 supply lines, custom fuel rail, MSD ignition wires, MSD 8202 coil, homemade boost controller, Garrett TC4305 turbo, 70mm throttle body, Godzilla BOV, Turbonetics wastegate, custom intake, custom turbo header, Cooling Mist H2O/meth injection, 20psi boost, all stock body, stock interior and weld draglite wheels, TH350 trans 4000 stall with B&M 'street stick' shifter and hughes trans brake, nitto nt555R drag radials, best 1/8 mile of 7.53@ 98 mph
#47 Grog
Grog
    Member
  • Members
  • PipPipPip
  • 94 posts
  • LocationPennsylvania
Posted 16 November 2013 - 05:20 PM
Can anyone verify if the maxima rear brackets/280zx brakes and rotors will fit under the 14" mini-mag wheels? I mocked mine up and it appears to fit, but would feel better about going forward with this swap by hearing from someone that already did it. I want to keep the stock alloy rims, so if this set up does not work then I will stick with the drums. thanks.
#48 gijohnny23
gijohnny23
    Newbie
  • Members
  • Pip
  • 16 posts
  • LocationTn
Posted 27 January 2014 - 08:30 PM
I need help and apparently am too new to make a new topic. I have a 75 280 that I've swapped an 83 booster and mc to. Since I'm using the stock proportioning valve it seems the chamber for front and rear are backwards on the 83 compared to the stock is this correct? Also for the life of me I cannot get one of the lines seated into the master cylinder. When I tighten it it leaks u der pressure. This is a bran new line pre fabed from autozone. The stock was replaced for the very same reason. Any help would be greatly appreciated.
#49 Interceptor
Interceptor
    Newbie
  • Members
  • Pip
  • 3 posts
  • LocationFrance
Posted 18 July 2014 - 04:47 AM
Something I'd like to know about the boosters, since it's not covered a lot on the first post.
What we learn from it is : the 280ZX MC is compatible with a 240Z stock booster
I'm gonna change the booster with the MC on my 240, and I don't want to use a 280ZX booster, 'cause I don't want to drill the firewall of my car.
is it compatible with a 280Z booster or should I stick to a stock 240Z booster, cause I don't gain much from swapping a 240Z booster for a 280Z one?
is there anything particular to do to make those boosters fit to the 240Z body? (like drill holes)
thx!
Edited by Interceptor, 18 July 2014 - 05:04 AM.
#50 vbgambini
vbgambini
    Moving Up
  • Members
  • PipPip
  • 33 posts
  • LocationMiami
Posted 17 April 2016 - 02:19 PM
Wussup guys Im having an issue with my brakes. Ive been searching but cannot seem to find what I am looking for. Sorry if its a little long.
I have a 1978 280z. Went to take it out for a little drive around the block just to get it running and making sure everything still works. When I pulled out of the driveway when a few feet and my brakes were almost non existent. The pedal became very hard to push and barely stopping the car even when going 10mph. So I decided after researching that the master cylinder is probably going bad and mostly the brake booster needs to be replaced (Seemed like still original parts)
So I ordered a new master cylinder and brake booster from Black Dragon. Disassembled all the old parts. Mostly took out the brake booster, and left the master cylinder for now since it is still full of liquid.
Received my parts from black dragon this weekend. Here are my issues.
Black Dragon part numbers
#64-162-Z brake booster
#64-103 Master Cylinder
1. The old nuts that went on the old master to booster, 3 of them fit but the top one. The nut cant even be screwed in. It looks like they sent me a bad part. Threads on the stud looked stripped. And even at an angle. But all other 3 nuts screwed in.
2. The new master I received has only 2 stud holes when the old master had 4 is that normal? So I said what the hell I will try and make it work. Ill just use the two vertical studs. So I just test fitted the new parts together out of the car, the master cylinder had to be wiggled in since the stud wasnt straight, and now when it slid in, theres a gap between the master and the brake booster. I dont recall there being some sort of spacer on the old master. I even tried the new master with the old booster, slid in perfect but still a gap.
3. New brake booster looks significantly larger than OEM, Measured the rectangular indentation that fits in the firewall on the new one and the old one. The new one is larger. Will it even fit in my car?
Just frustrated because I wanted to get this done over the weekend and even ordered SS lines from MSA. And wanted to get it back on the road. Please if anyone can help me. Thanks.
#51 Miles
Miles
    Miles ahead!
  • Donating Members
  • PipPipPipPipPipPip
  • 1858 posts
  • LocationSacramento, CA
Posted 17 April 2016 - 05:38 PM
wrong forum
“Life is like arriving late for a movie, having to figure out what was going on without bothering everybody with a lot of questions, and then being unexpectedly called away before you find out how it ends.”    -Joseph Campbell
#52 juxsa
juxsa
    Regular
  • Members
  • PipPipPip
  • 61 posts
  • Locationknoxville, tn usa
Posted 04 May 2016 - 02:37 PM
 I just ordered the modern motorsport S30 rear caliper adapter to replace my drums with 240sx calipers. I have read through many threads and I am confused. Can I use S14 rear calipers and is the parking brake bracket I would need to make for the S13 calipers the same for the S14s?
Edited by juxsa, 04 May 2016 - 04:55 PM.
#53 ib_juan_kenobi_240z
ib_juan_kenobi_240z
    Newbie
  • Members
  • Pip
  • 7 posts
  • Locationimperial beach, San Diego, CA, US
Posted 16 June 2016 - 08:09 PM
Do the s12w have a different thread pitch than the 240z stock caliper for the brake line? I read somewhere that the s12w are standard...? How would I go about ordering the ss brake lines if that were the case. Sorry in advance if this is a stupid ?.
#54 Miles
Miles
    Miles ahead!
  • Donating Members
  • 1858 posts
Posted 16 June 2016 - 09:45 PM
They are the same M10 x 1.0 .
Note: do not use brake lines with banjo fittings on the Toyota caliper. The caliper is not designed for bango fittings. If used they will not seal and they will leak.
There are many options for brake lines for the Toyota swap discussed in the brake forum. Search.
#55 superduner
superduner
    Member
  • Members
  • PipPipPipPip
  • 157 posts
  • LocationSAN DIEGO, CALIFORNIA
Posted 06 December 2016 - 07:54 PM
Looked for the answer to my question but I Sourced a set of. Máxima brackets for the rear disk conversion. I'm wondering if the 4 lug 300zx rear rotors will also fit the 82 caliper conversion as I read the modern motorsports aftermarket bracket uses these.
~The Only Person You Should Be Better Than, Is The Person You Were Yesterday.~
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
