    33145
    5167
    EastWaZ
    EastWaZ
  1. Yesterday
  2. Ordered the Apex track attack kit for the rear, and sent out my 370Z diff to be rebuilt with a wavetrac LSD. Going with the 3.3 gears. Did some more research and I was thinking about the gearing wrong. I’m sure it’s common sense to those with experience but I was including the overdrive gear in my analysis. For a track car, I learned you should gear it for redline in 4th on the longest straight, then you have overdrive if you need it. So going with the highlighted option below. Planning to work more on brakes this weekend, I unboxed my dual master cylinder set up, trying to understand how it all goes together and figure out plumbing. I have my new brake lines too, so hopefully replacing all the lines and get them plumbed to the master cylinders in the next few weeks.
  3. I am currently working on this same issue. I got sandersons D1 headers uncoated since I knew there would be issues, just based off the photos. On the passanger side I dented the backside to clear the mounts. It was just above the collector, I can't remember which cylinder. It was a pain since thats there the collector and primary overlaped. I also got to a point that i didnt want to dent it any more and cut a section off the motor mount. The mounts are lsbillet swap plates and jags that run chevy put together. The portion I cut off shouldnt affect the mounts, unless the engine spontaneously shifts back an inch.... The driver side I am going to modify the steering shaft based off another post. Its pretty good post. Not sure of the link, I copied it into my offline notes. Dont mind the fuel line returnin the photoes still moving things around. Ive been delayed on this project since spring. The wife to do list was piling up.
  4. Not many take on this challenge, good for you! It is for sure a challenge. If you have rack and pinion steering, you have the worst. There is manual which is not bad and i dont exactly remember the name of the other style. Its like reciprocating, or something like that. Bottom line is, i found that a "block Hugger" style fits well on Pass side. It's the driver side that i had the most issue with. 1st thing is to pin the steering shaft (I drilled and tapped through it for a screw) so you can cut-off the clamping ear. Then get rid of the Rubber Rag joint on the steering shaft. Techno toy tuning makes a solid piece to put in place. I don't know anything about the size of it though. I made mine and made it smaller diameter for clearance. I have modified a couple different sets of headers. I 1st had a Hooker High Flow Manifold that i still had to cut a window in it and have a plate welded in from the back side. Then i didn't like that i had 2 different style headers so i bought BillyBoat headers for a C5 vette. Still had to cut a tube off and re-route a new one to avoid the steering shaft. Then i was worried thet 1-5/8" primaries were not big enough and i had someone make me a set of long tube 1-3/4" headers and found that it was not worth it. I went from 375whp to 387hp (very disappointing results for the $) Take a look at all the pics. There is a pic for everything i just explained. Worse case you can run manifolds upside down and they will point fwd. If you are turboing, this will work well. If not, you have to run the exhaust fwd and down around the front, which i'm not a fan of.
  5. Can anybody share what they used for exhaust headers for a ls1 5.7l motor in a 280zx? I knew this would be a challenge but coming up short or should I say shorty
  6. Finished up the 17x8 wheel conversion on a turbo 280z. Got the geometry perfect. All the TTT suspension parts made it easy. https://www.facebook.com/share/p/15JMLRNJpd/
  7. Last week
  8. I do want to give a big thumbs up and shout out to "artishard" here on the HybridZ, I kept searching to find anyone whom had one of RIPS old custom oil pans and it turns out that "artishard" here on the HybridZ has that very pan and was kind enough to share several pictures. Those pictures were amazing as it looks like they are enough for Robbie at RIPS Racing to make a custom oil pan for my application! This is why HybridZ is so great to learn from others mistakes and share information so valuable in our pursuit of performance!
  9. Datsun 240Z RB30 oil pan For my 1972 240Z, I wanted to create a reliable big horsepower streetcar capable of 800-1000 HP. To meet those goals I choose RIPS Racing whom has the proven track record in creating reliable high HP street cars, exactly what I was wanting. One of the issues I faced was that Robbie of RIPS had lost his template for a rear high-capacity oil pan for a 240Z swap. There does not seem to be any good oil pans for a 240Z RB swap. If you are building a big horsepower RB engine to be swapped into a 240Z PLEASE BE CAREFUL AS I PERSONALLY DO NOT THINK THERE ARE ANY GOOD PANS AVAILABLE AND YOU WILL NEED TO GO HAVE A CUSTOM OIL PAN MADE! Here is my sad experience thus far... After spending weeks online reviewing so many oil pans only to find that all of them were not adequate based on RIPS observations. I found this one JHK pan from U.P. Garage that appeared that it might work so I took a chance after they told me it would work, https://upgarageusa.com/collections/jhk-oil-pans/products/jhk-rear-sump-rb-cast-oil-pan When I received it, I shipped it straight to RIPS as I did not want to undo their professional packing. I did not open the box, as I just brought it to DHL and they put their label over where your label was. I sent it to Robbie at RIPS Racing in New Zealand. Unfortunately when it arrived to New Zealand it was damaged. I told Eric, & Doug @ UP Garage via email, The oil pan you shipped to me was damaged. I did not open the box, as just brought it to DHL and they put their label over where your label was. I sent it to Robbie at RIPS Racing in New Zealand. Additionally, Rob told me that this design would not work as there is insufficient clearance between the oil tube and also between the baffle and engine. I have attached pictures and an MP4 where Robbie shows the box damaged before fully opening it. This was an unfortunate expensive mistake as it cost me over $700 to ship it only to find out it was damaged and would not have been a good pan for my application. When I get my fully built engine towards the later part of this year Robbie will send your pan and I can return it. I would hope that I get a refund. Now we need to source a better pan that has more oil capacity, and a better design to provide the oil flow needed for my engine. On a phone call UP Garage said it was my fault for not opening the box before I shipped it to New Zealand. I told them I examined the box it was not damaged in anyway, so I reshipped it without opening it in order to not disturb their packaging, but they still denied any liability. I then sent them the following email, Eric, & Doug, I sent the pics you texted me to Robbie, and I am glad he explained the issues technically with the oil pan. Doug was telling me that your pan would work fine on a more stock build but reading Robbie’s great explanation, I doubt that would be the case on my 2 WD RB block. Regardless, the oil pan was damaged and if you feel that it can be resold to someone as Doug stated, I will send it to you after I receive my complete engine with the damaged oil pan from RIPS. You are specializing in a local RB market would be better suited to find a new home for this oil pan than me here in Northern CA. Doug claimed it should be easy to sell it as the damage was cosmetic, then it would make sense that afterward you resell the oil pan, you could reimburse me for my purchase or at least most of that cost. U.P. Garage sent this email to RIPS, We are, and have been, huge fans of your hard work to bring HP to the RB world!! So glad that the JHK pan has found it's way to your examination table. Here are the measurements we have taken on the RB25(rear drive block) screen configuration. Keep up the great work!! Feel free to call us: +1 253 565 9823 Doug/Erik Fatty Fat Cat www.upgarageusa.com From: RIPS Racing The pictures you have sent are not from a 2wd block, they are from a AWD block, possibly a RB26 with the longer AWD pickup. The measurements you have are with the pickup you have on your block and quite different to the measurements I have with the pickup and oil pan I have received. As stated, with the pickup bolted on (without a gasket) the pan will not go down all the way to the block, the pickup screen is holding the sump up a little bit meaning the screen is already touching the bottom of the sump before its even bolted down flat. There should be about 10mm clearance when the sump is bolted down meaning as it is, bolting the sump down will put load on the pickup and be squashing the screen and the tube inside the screen will be pretty much hard against the floor of the sump meaning a massive restriction in oil flow. RIPS also sent them this email, Hi, Just to add to this, with the oil pickup installed on the block (even without a gasket) the sump would not sit flat on the block, the oil pickup was ever so slightly holding it up so the screen on the pickup was hard against the bottom of the oil pan. This means if the sump was bolted up tight the pickup tube itself (inside the screen) would also be basically hard up against the bottom of the sump meaning major restriction is oil flow. There should be around 12-15mm clearance between the end of the oil pickup tube and usually around 5mm clearance between the screen and the bottom of the oil pan. As it was supplied there is no way it could have worked and would have surely led to an engine failure.
  10. That's a great suggestion. Adam's very responsive; it seems like FB is his preferred medium -- here's his page: https://www.facebook.com/DatsunRescue
  11. I spend the last few days cleaning the electrical connections and timing the ignition again as it was out of spec. The car runs way better but the AFR gauge still shows 11,5 at idle. I'd like to bring that down (or up depending how you look at it) to 14,7 as the car stinks of gas. The previous owner mentioned that that was the reason it didn't pass inspection (auction company didn't mention that). I tried messing with the idle air mixture screw but that didn't help. When turning clockwise a bunch the car did start to run richer but when turning anti clockwise it didn't get past 11,5 AFR. I did notice the ignition coil is a 1,5 ohm unit with a total resistance of 2 ohm with the external resistor. I believe it needs to be closer to 1 ohm total so I'll probably replace the coil with a 0,5 ohm one.
  12. The Follow Up Road Test went fine. There was no CV Axle Grease leak and the Diffferential performed well. The Differential Gear Ratio was now 3:55 compared to the old r200 3:70 so my shift points were now more spread out. I think that 3:55 gear ratio for city driving by providing less gear shifting. Highway driving was better by running at less RPMs too. The Blue Angels-the Navy Stunt F16 planes were coming to participate in an Air Show at Kaneohe Marine Base. There also had a Car Show along with the Two Day Air Show. Although, the show was on the other side of my island , I decided to enter my 240z in the Car Show. The trip would take about one Hour but most of it was on freeway roads. The Freeway would take me over the mountain to the other side of my island. On the downward leg of the trip, I noticed that a lot of pedal effort was necessary to slow down, My conclusion was that a Bigger Brake Power booster would be needed. The OEM Brake Booster was 7" booster so the next size booster would be 1978 280z booster which is 8 !/2". The local auto places did not have a 280Z booster available so I ordered one from Z Depot. The Good News is that I won the TOP TEN Trophy for Aloha Mother Fest 2025 at this show. Next- Upgrading the 7" OEM Booster with the 78280z 8 1/2"Brake Booster Next-Upgrading the Brake Power Booster with a 78 280Z Unit
  13. Hi mate, Low profile alloy air cleaner top with a carbon fibre air cleaner with the collection point in front of the radiator. Flexible rubber joiner between the alloy top hat and the carbon fibre air cleaner. The alloy piece is only about 2.5 inches high. Just another idea for cold air induction. Regards David.
  14. Was looking for an old post from you because of the Panasport wheels you had and remembered this great thread. Any good progress since last year?
  15. Got rotors and calipers on. A few minor challenges making it fit for the 240Z, but very happy how it came out.
  16. Adam Sylvester at Datsun Rescue or Jenny at Junkyard Jenny's.
  17. Ok, so update....thanks to those who warned me about these Edelbrock foam air cleaners. I started reading, one back fire and they will catch fire and turn into goo and run down into your carb/TBI !!!!! oh no! So, i looked online, because this filter was also hitting my hood. I found this company: Pro Series Screens - Intensity Racing Products I bought the mesh screen to work on my carb mouth. So glad you guys said something. WHEW! see pic, I got the low profile with the single hole.. 98 bucks....115 shipped. Saved my life.
  18. Continuity was from the ecu to the plug that connects at the sensor, when the ecu was plugged into the harness. When the ecu was unplugged there was no continuity from the plug end at the ecu, to the plug end at the sensor. That led me to think the ecu was shorting to ground inside the ecu. I'll check out the video and test out the crank sensor, and its gap. I'm assuming their ok, as i am using a new crank gear, new crank sensor and new oil pump...but I know assuming is a dangerous game so I'll test it. Thanks for the link!
  19. Barely know what you're working with but I did find a crankshaft position sensor online for the 2jz and see that it's a two wire unit. That means it's a variable reluctor system. There will be continuity across those two pins in the sensor harness to the sensor. There should be a resistance of a few hundred ohms, typically. It's not clear what you mean when you say you measured with the plug connected and got continuity. Can't tell which side of the plug you're measuring, to the sensor or to the ECU. Anyway, the signal to the ECU is generated when the metal teeth of the trigger wheel pass by the sensor. The sensor has to be within a certain distance from the sensor, that's very important. There's spec but it's usually a few thousandths. Pretty close. The basic testing is to measure resistance across the two pins to be sure the coil is intact and will work. Then set the air gap. Then test that a signal is being generated. https://www.jdmgarageuk.com/90919-05037.html Here's a pretty good video about the basics. .
  20. I'm a bit stuck and not sure the best direction to move with my swap, hoping someone can help me figure out where my problem is. I've got a 2jz ge that im swapping into a 280z, im going the nat route with an aristo gte ecu. I reworked the wire harness and got the the point of startup, but it only cranks and doesn't fire. I wired a check engine light and got a "1..2.." code. So I checked the crank position plug and was getting continuity from the two terminals on the plug. Thought maybe I wired it wrong, so unplugged the ecu and checked the plug again, no continuity. Then I checked the ecu and was getting continuity with pin 4, 5, 6 and 7. 4 is a ground, 5,6 are cam position, and 7 is crank. So I thought maybe the capacitor that sits on those pins was bad, went to an electronics store that gave me a capacitor that "should" work, then had a place remove the old and put in the new. After all that, Im still in the same place as I started. Crank, no fire, code "12". Any thoughts as to a next step, other than another ecu (which i did but on ebay, waiting for it to show)? Any help would be awesome!
  21. Hello everyone, maybe somebody can help me. My 1977 280z is running rich at idle and the idle mixture on the AFM doesn't seem to help. I spend the last few days cleaning the electrical connections and timing the ignition again as it was out of spec. The car runs way better but the AFR gauge still shows 11,5 at idle. I'd like to bring that down (or up depending how you look at it) to 14,7 as the car stinks of gas. The previous owner mentioned that that was the reason it didn't pass inspection (auction company didn't mention that). I tried messing with the idle air mixture screw but that didn't help. When turning clockwise a bunch the car did start to run richer but when turning anti clockwise it didn't get past 11,5 AFR. Does anybody have any tips or things I should look at? The AFR does seem to be working alright as far as I can tell. I did notice the ignition coil is a 1,5 ohm unit with a total resistance of 2 ohm with the external resistor. I believe it needs to be closer to 1 ohm total so I'll probably replace the coil.
  22. I disconnected my throttle cable and lubed it up, now it moves freely with no drag, in doing so, I re-arranged some of the items attached to the carb thus cleaning it up. A short amount of time to work on stuff today and I'm happy I was able to get it done. Also was able to tighten the spring for the secondary butterflies which is basically required to keep them working right. My thermostat probe adapter that goes into the top radiator hose also arrived and snapped a few pics.
  23. Its already fixed. I have these unusual gnose wide body panels i think are fairly aero efficient. So really the only decisions are if I want to run a cowl induction hood vs. standard no vents. And tall rear 7" spoiler vs whale tail. Input is welcome. Leaning standard hood and big spoiler. Working on mounting these NOW.
  • Who's Online   0 Members, 0 Anonymous, 283 Guests (See full list)
