Brad-ManQ45
    9
  1. I think tubing is tubing and what's done on the ends in the enum make a difference... If it works then that's it. I'd rather have performance over looks and I don't like the angles I saw for the first cylinders.
  2. I don't think so, and it looks like it would have 1st cylinder air distribution problems compared to ProtunerZ's...
  3. My buddy had his cone filter behind the headlight bucket with piping bent appropriately and through the inner fender and the valve cover hose tapped in after the air filter...
  4. Get factory workshop manual. Clean all grounds in engine compartment and the connectors for the ECU and fuel injectors. TPS, AFM, all sensors.
  5. It's like the opposite of polishing the beam on connecting rods to eliminate stress fractures/weaknesses. You are inducing a weakening of the surface and assembly.
  6. If you get a bigger turbo you won't heat the air as much as the small one. I ran an S3 trim turbo to 14 psi with no problems stock - but I limited my rpms to about 4500 at that boost.
  7. I'm not negative in any way - shoot, I'm all for saving a buck - more do than most because I had to retire early for health/disability reasons. I ask questions and make statements but don't judge - some of us are here to learn and share knowledge. I honestly didn't know the OP got the PCM very cheaply as it wasn't in his original post.
  8. I have the ATI trans adapter kit and lockup torque converter (9") along with MS3Pro and MicroSquirt for my '83 ZXT. Currently waiting to paint engine compartment prior to installing engine, transmission and upgrades including ported and ceramic coated exhaust manifold, Protunerz intake and even larger upgraded turbo. Have had health issues.
  9. $500 when not on sale...plus - MS programmability.
  10. Or you could use a MicroSquirt connected by CAN to a MegaSquirt to control the 4l60/80...
  11. Thanks - I think I will be using my stock turbo exhaust manifold and rout the output from the turbo under the engine to go forward through the radiator support to a cross flow intercooler and have the cooler air back thru on the intake side to my Protunerz intake. Looks like I should have no problem...
  12. How about a pic underneath to show clearance? Thx.
  13. https://www.angelfire.com/extreme/280zxt/
  14. When you can get over 600 hp with a ported stock manifold I don't see getting an aftermarket one...particularly since Boone has done a before/after...
  15. Put in that 3" exhaust before anything else...
  16. The washer motor is switched - not constant...run it to the positive battery terminal.
  17. Looks like Advanced Auto has an option to ship from factory on rebuilds - 2 sizes...
  18. ATI has an adapter kit for GM automatic transmissions: https://www.atiracing.com/products/adapterk/akit.htm I bought the kit and a high stall 9" lock up converter from them for my '83 Turbo...
  19. I specifically looked for your model and year...
