Brad-ManQ45
    9
  1. I am/was willing to pay whatever they wanted, realising that shipping would also be a hefty amount. They simply never responded after I sent the link from here and said it was for a daily driver and I didn't need a 75mm or larger TB... The fact that they gave no justification simply irks me no end as I believe I have good justification for my specs. Perhaps CUSTOM should not be in their business name.
  2. I am/was willing to pay whatever they wanted, realising that shipping would also be a hefty amount. They simply never responded after I sent the link from here and said it was for a daily driver and I didn't need a 75mm or larger TB... The fact that they gave no justification simply irks me no end as I believe I have good justification for my specs. Perhaps CUSTOM should not be in their business name.
  3. To answer questions in no particular order... Some people have said that on a stock manifold that the lost low speed driveability withe even a 60mm 240SX TB and wished they hadn't made the change. Being an old hot fodder (I am 62) I am well aware of reversion and it's effects and I merely acknowledged TonyD's c moments on the subject that were also backed up by JeffP's resulting experiences. I don't feel that my secs were anywhere near out of line for a custom intake given the daily driver/under 6k rpm/less than 18 lbs boost scenario that is my vision. I still haven't seen anyone's answer to my questiono - am I looking at this wrong? Let me rephrase. If you area custom manufacturer and you give the customer exactly what they wanted and paid for are you reasonable? In the same scenario are you being reasonable if you refuse to make it without at least explaining why you won't?
  4. I just had a refusal to fabricate a manifold from these people to my specifications for my L28et. https://www.facebook.com/customplenumcreations/ They asked what I wanted spec-wise and I said that I wanted to use a 240SX throttle body and have the runners 33mm inside diameter for the 35mm ports on my head. Here is what they said: "Sorry Brad I would not make a manifold along those lines. Making a manifold with a smaller port diametre vs the head will defeat all logic since it will cause more turbulence and a restriction to flow at the port entry throwing all your porting work out the window and the almost immeasurable benefit you may get from trying to reduce reversion." I then sent them to this thread on HybridZ about real world experience with JeffP's turbo'd engine: http://forums.hybridz.org/topic/101589-port-match and have heard nothing back. Since my car will be a daily driver and will have a 4l60E behind it it will be limited to 6000 RPM to keep the tranny alive. I just don't understand their thinking.....
  5. I don't think he is talking about a splitter - just a panel from the bottom of the front spoiler/air dam back to the engine... Might a kick up before/after the radiator (providing there is clearance) and then flatten out to the front of the engine provide a minimal amount of downforce?
  6. Thanks Rossman. I saw that page but wondered about what he did for the area from ports 1-4 coming into the plenum. There was absolutely no mention of smoothing or enlarging which is why I thought I may have miss3d a page...
  7. I saw the porting for the exhaust manifold already, I was wondering about the cutting open and welding like they say they can do on the intake manifold.
  8. Hi guys! It's been a long hard road the last 5 years and needless to say the '83ZXT project has been on hold. I've done my due diligence and for the life of me cannot understand why you would have the same size pipes before and after the intercooler. To me, simple physics would lead me to think that a smaller pipe after the intercooler would provide less pressure loss because cooler air is more dense and a smaller pipe would keep the pressure and speed up whereas the same size piping would cause the pressure and speed to drop. In the real world is the difference too small to consider? Would the numer of bends and length of the tubing after the intercooler enter into the equation? This inquiring mind wishes to learn...
  9. TimO: Is that for the exhaust manifold? I can see them doing the intake... TonyD: Is there a link to the writeup JeffP did for the stock exhaust manifold? I couldn'see it on his website. Thanks, Brad
  10. Are you using the stock distributor setup? if so you may have a bad ignitor...
  11. I bought the last ArizonaZ gnose and had it crated and shipped via Greyhound. Still in crate. PM me your email and I can send pics of it that are no longer on site.
  12. I'm looking for one. If anyone has/can make one or knows somebody... Thx
  13. I hope that the picture does not represent exactly where you intend to mount the engine - too far forward and high,,,
  14. Think trying to direct the flow against the "flat" part of the blades as it spins gulping in air as opposed to directly at the "edges" of the blades...
  15. the dump from the valve I agree should b3 as close to the turbo inlet as possible - and I ALSO AGREE THAT IF IT CAN BE "aimed" at th3 inlet it would be better. I believe we are in agreement.
  16. DAT280ZXT: Hence my recommendation of closer to the TB the better... Had an HKS intercooler kit w/one on an '85 Conquest. That got totalled when rear-ended and put the valve on the '87 Station ESIR I bought to replace the Conquest...at the beginning of the model year. I had to fab the pipework for it. When finished I called up HKS and told 'm they should make a a kit - hence the approximately $230 kit they came out with later.
  17. Closer to the throttle body is better. Get an intercooler and plumb it into the piping.
  18. I have an '83ZXT that I am working on and will have a GM auto behind. Thinking I might like to have a rear gear that is 3.08 or 3.36 in it because of the very short 1st gear ratio. Seems that because of the rear subframe that there may be issues with connecting the driveshaft to the front of the diff requiring a bit of surgery to the subframe for access, but haven't really spent much time underneath. Has anyone else considered something like this?
  19. I am thinking of using the distrbutor only for the single sensor for TDC on #1, then a crank sensor for the sequential needs.
  20. Two side benefits of water injection are a bit more torque (steam expands) and keeping carbon deposits down in combution chamber and back of valves...
  21. Please describe in detail the conditions that you engine shuts down under (ex: WOT passing xxxx rpm, etc.)...and is it a complete loss of power?
  22. http://atlanticz.ca/zclub/techtips/turbo/turbomaps/index.htm The above link has a pretty good explanation of what to look for in a turbo compressor. It does not show the GT 30 or GT35 ball bearing turbos though. I think the 3076 would be good compared to the GT35. Personally and for the money a T3/T4 .50 Trim E series compressor w/.63 AR stage III turbine would be ideal.
  23. Maybe I'll just get an LSx engine & 6speed auto ande PCM from a Corvette or Camaro and call it quits. A 4L60E behind the Turbo engine makes for a too short 1st gear...
