luigi
Everything posted by luigi
Oh.....ok, the sensor is actually reading the output shaft correct?
what year, make and model is your diff? I may have one in the basement that I can look at or take apart. Or may be able to get my friend at the dealer to look and see. I'm going with the clamp on the driveshaft ring. I can't order until Monday. I think he's racing
Request tips/products for painting roll cage
luigi replied to RebekahsZ's topic in Fabrication / Welding
Por-15 with a brush. or thin and spray. They may have it in a can by now. toughest paint I've used. -
The Ultrashield rally sport seat fit into my car (S30) pretty well. My car has simple door bars.
16x8 +15 offset on a 280Z?
luigi replied to michael wales's topic in Brakes, Wheels, Suspension and Chassis
Michael, what offset did you wind up with? -
I liked the Weir because it uses off the shelf flywheel & clutch. Not sure what the hyd. release is from, but if it crapped out, I think I could find something. I used to hate bleeding mine also. last time it was out, I added a 24 inch, -3 line to it. bleeds in no time time now. I stole the idea from the 'vette guys.
I used a Weir products bellhousing. It uses a regular old say, 198? flywheel & clutch assembly. I couldn't find his website, but his number is 800-633-9869. He's in California. nice product. You may also be able to find a Quick Time bellhousing. Tilton & quartermaster both sell hyd. release bearings. hope this helps
Last generation Toyota celica or toyota MR spyder?
I cut a 4 triangles that "boxed?" the sides. Smallest angle nearest the arm. Tig welded on the sides. Did it help? I don't know. It was an easy thing to do & it made me feel better. It did make getting the bolts into the frame a bit more difficult. You could make an X that starts on the inside of the bolts, maybe a bit more strength and easier access to the bolts.
watch out for the inside door handle. Ask me how I know Looks great!
LATEST info on Headers For SBC - YES I searched...
luigi replied to Mikelly's topic in Gen I & II Chevy V8 Tech Board
No significant difference on a low hp ZZ4 crate engine. I don't think that would be the case with Mikes combo -
Cool car! Did you get it with the engine in it? Looks like a old hooker kit? 3/8" line is ok. Well, until maybe 600bhp? That looks like a Mallory fuel pump. rebuild kits are available. I think the brushes die in them. I had one on my z for 4 years (maybe longer). gave it to my pops it finally killed the brushes last year. Keep it low buck and driveable! I wish I had!
Got one. Re-plated, yellow zinc. Can't ship it till Thursday. I'm in Nashville. Can't see shipping costing too much. I'll check again on Thursday morning. If you haven't found one, I'll ship it to you. Lewis
Carburetor butterfly flap stuck?¿
luigi replied to Datz350's topic in Gen I & II Chevy V8 Tech Board
I'm glad you got it fixed. Make sure you check for wide open throttle. That little piece of choke cable is really common. It's used to make sure the choke doesn't get "pulled" closed by engine vacuum. If the car will start without the choke being closed, don't worry about it. -
What condition does it need to be in? I will get pictures this Friday, but I would call the one I have a 4 (outta 10). Maybe 5 or 6 tops. Lewis
I also have those 3 pieces. If the offerabove doesn't work out let me know.
I like the air dam! Are there 2 oil coolers? How are they plumbed? any before and after oil temp numbers? Are the coolers painted red?
I have a set that is already set up for a coilover spring. The housings ae not cut down. Let me know if you are interested.
jt1, whose is that? Mike, what are you thinking on primary pip dia. & length? Anything that's better than the shorties? Took me awhile, the Sanderson c33 series w/1 3/4" pipes did fit my car. Not a perfect fit. Knowing what I now know I would have started with them and modified. They have a great flange, the pipes are thick, they are nowhere near equal length, they are heavy. I got 'em for $300. + shipping. -
I used the Vibrant clamps on my exhaust. I like them. I really like the way the "clasp" flips over the t-bolt, so you can just loosen the nut and disassemble. Also, I think the t-bolts themselves are a bit better. I have broken other ones. I have used the v-band clamps from Burns and they are made by another company, named something like race shop. five star makes alot v-bands also. Dynatechs clamps are mild steel on the flanges. Side note, whoever it is that makes Burns clamps (can't find them right now) also had low profile clamps and flanges to fit metric tubing. Whatever you pick anti-seize the heck outta the threads.
There are many things that set the powerband of an engine, & there is nothing that says a 327 has to have a narrow powerband. In the engine masters competition there was a 331 that hit the pump @2500 rpm with 381 lb/ft. Low number was 377 lb/ft all the way to 6500 rpm. That doesn't sound narrow to me. Get an engine analyzer program and play around. Beware that if you really are gonna try to get the last bit outta it, you're gonna may need real long tube headers or at least do some testing to see what your combo likes. Good luck. Lewis
What fuel sender did you use? Are the gauges easy to calibrate? good looking stuff thanks Luigi
Jones cams, Owner is Mike Jones. Very good person. If you want to do a bit of trending, invest in engine analyzer. If this was mine, I'd make sure a got some EDM'd lifters. Did I miss it, what make heads are on this?
350 SBC build parts list for your approval
luigi replied to logan1's topic in Gen I & II Chevy V8 Tech Board
Logan, what type of lifters are you gonna run? If your budget allows, go ahead and get the vortecs set up for screw- in studs and guide plates. That'll make your life easier latter on. cam: 225-235 @ .050 and you won't need any more than .510-.520 lift at the valve. I'll try to get the spec for the cam that we have in the engine on the dyno this weekend. Go for at least a Performer RPM (air gaps are taller I think). You can get the Professional Products intake, just be prepared to do some clean up porting on it. The Edelbrocks have a MUCH nicer casting. -
Oil pressure, temperature, starvation for road race duty
luigi replied to bjhines's topic in Gen I & II Chevy V8 Tech Board
After the pan install, did the accumulator "on" light stay off? thanks for keeping us posted about this.
