27
Everything posted by madkaw
What do you mean everything works normal when you disconnect the ecu ignition wire . You are probably going to have to provide more info for help . Richard Boyk does remote tuning . Not sure how much he’s on this site anymore - but he is on FB on the Church of L page
Well I have this fancy Moroso oil catch can between the crank case and the PCV . I haven’t seen much in it honestly - so maybe a good thing . THOUGH- I have taken off my intake to find oil residue sitting in the runners near the head - so not sure what that’s about. Just under the air intake tube attached to the inner fender
The issue with the MAP sensor was that it was integrated into the ECU and the ECU was mounted in the cabin low on the tunnel . This effectively was down hill from the engine and any condensation rolled down into the MAP sensor . My MAP sensor is now separate and mounted on the firewall above the motor . Really haven’t had any “heat soak” issues . The Protunerz intake is angled up and clears the header runners well . All other intakes I’ve used I have used heat shield tape on the lower half of the runners and plenum .
Since you will have made the effort of a fuel rail and use high impedance injectors why not go to a pick n pull salvage yard and buy some cheap used Bosch that are a bit smaller . Can’t tell you if 440cc will work or not . I run them in my 3.2 NA but I have 230 rwhp . I think before these I was running 36lb VW injectors . I moved the 36 lbs ones to my 720 truck that probably has 115 hp at the rear wheels - no issues
So I’ve been having issues with my dual widebands not reading the same most of the time . My 1-3 cylinders were erratic and I could tell by the way it was running that it was more than just an erratic reading . I eliminated all exhaust and air leaks - which I did have a vacuum leak on #1 runner because the Protunerz flange is warped . I did have some pin hole leaks around my collector - got that fixed . Swapped 1-3 injectors with 4-6 . Problem didn’t follow . Then I changed the O2 sensor - still no luck . Finally swapped in a new wideband controller and issue was resolved . This did NOT fix the fact that 1-3 wideband shows lean conditions under high vacuum MAP . Unless I trim out(fatten) the injectors in 1-3 the MS doesn’t seem able to reign in this condition . Under load the cylinders all sync up , but from 65 KPA ( big cam) on down I have to add fuel . Then the MS seems to keep up . I give the ego control 20% authority but it seems to do better with injector trim added. I have run 3 different “log” intakes and they all act the same under high vacuum . So few have my set up that there’s no one to compare with .
I have switched to a GM valve . It seems to be doing well . I have to keep the valve powered on all the time but it is predictable that way .
Still available and ready to ship
You fiddled with it ? You are supposed to calibrate the voltage to as close to 2.5v’s as possible . There is a procedure that you can find on about any MS manual . I had issues with the fact that in cold weather the engine cranked to low and the signal got lost for starts. Only time I’ve had a sync loss while driving is when my hall sensor was falling off . I have ms2 on my truck and MS3X on my Z . I run batch fire on multiple coils so my set up isn’t like yours
Yes- you want to verify the 2.5v’s across the 2 pots . I had issues with my MS2 and picking up the signal from my sensor . I ended up installing an external pull up and that solved my issue
What type CAS ? Have you checked voltage across the pots in the ECU ? Do you need a pull up resistor ?
DIY Stage III Shift Kit Installation for S30 and S130 Jatco Autos
madkaw replied to RB30X's topic in Drivetrain
Did you try a PM . He eventually got back to me -
If you got the torque I’d go with the 3.54
Why would dizzy power be spliced into power for the MS unit ? Isn’t there an output for the dizzy?
It’s going to be tough to ‘feel’ your way around a tune and trying to dial it in off your VE table . I would get some help tuning - like is in a passenger that can drive while you tune . If you think the wideband is even close I would use it to get you in the ballpark . Put some realistic numbers in your AFR table and try it
I had nothing but issues with an AEM wideband on a customers car . After googling I read about many customers having issues do to faulty O2 sensors that AEM knew about .
Now that I looked at your AFR table and VE table I can see why it doesnt run well. Do you have tuner analyze? Its very good
Curious why you arent incorporating the AFR table in general settings? . Sure you dont have a loose connection on the fuel pump?
I assumed you were MIGing . My body shop friend recommended to fill with silicon bronze because it takes less heat .
Are you fill welding with silicon bronze ?
The actual bolt spacing is different too. The Jeep has a more narrow bolt spacing. Ive been reading up on some EFI support pages and I guess I need to actually watch the valve open and close to get the total steps correct . Not sure what your total homing steps are
Mine just refuses to open sometimes . I’ll try a GM before I go to a AAR
Not a final version , but this is where I left it last run . This eliminated all pinging . I just started to dial in more fuel to see if I could raise timing . I also having trim tables to isolate #6 if that’s the offender
Still no luck with the stepper IAC . I am going to get a used GM style to replace this Jeep style I have now to see if that helps . It seems that it just decides not to work sometimes . I get zero air at start and have to use the throttle to modulate . I am about ready to ditch the stepper all together and go ole school with a AAR Bosch valve . I have 3 of them laying around . I use them on my truck and never have a start issue .
Update : I had been fighting an erratic wideband on the rear collector -cylinders 4-6. Well it turns out I still had a leak at the collector which is before the O2 sensors - dammit . This is a Z story header and collector . The collector pipe was modified for my exhaust and I thought I had the flange true , but it still leaked . This time around I eliminated the gasket all together and used Red Loctite only . At the same time I had a new O2 sensor installed since I was that deep into it . I DID see evidence of a leak but changed the sensor anyways . FIXED! This change helped so much with the tune and you could hear it ! I was able to get the banks to harmonize much better with AFR’s and sound . This helped to mitigate the drone I was getting at low rpm cruise . I thought this would also fix an issue I’ve seen on every intake I’ve used where the AFR’s between the two O2 sensors would be different during high vacuum running - light cruise . Megasquirt didn’t seem to be able to compensate in those scenarios though I had two separate O2 sensors dividing the banks . I ended up going into the injector trims and adding fuel to 1-3 since they ran really lean under high vacuum . Maybe they suck all the air out of the plenum before it reaches the last 3 cylinders . I added almost 20% to 1-3 . At this point the AFR’s evened up and you could feel and hear the difference . This is probably the best I’ve had my L running . Happy guy right now
I’ve been using Megasquirt 3x on my 3.2 for a while now . I had a knock sensor module installed on my X board . For some reason I can’t get it to work . I have a feeling there is a defect in the pin out during install . I’m not good enough to troubleshot bad install of a module and I’ve been reading about the usefulness of a cheap audio version that could made for 50$ . Background - I had to tear down my 3.2 because I had remove the crank to clean up the snout from a bad balancer . When I popped out #6 I found a broken top ring and evidence of detonation . Admittedly I was aggressive with timing and it bit me . There were no signs of the broken ring and the pulled 225 rwhp on the dyno . In fact that cylinder showed the highest CR = 220 psi This engine trans package is very noisy . I had straight cut gears and Kameari chain tensioner and a loud exhaust . I thought I heard ping around 4300 and attributed it to a rattling shifter - oops . # 6 was the only cylinder with any damage . I also pulled coolant from #6 at the head with a bypass to help mitigate problems . This time around I want to make sure this doesn’t happen again . I followed this you tube video. i was skeptical but it really works well. I drilled a hole above the freeze plug around 5&6 . Plenty of met there and there is a flat boss area for the sensor to sit flat against the block . You can hear the valve train clearly but you can also hear the ping clearly . I ended up pulling 4 degrees out of total timing on 93 octane . Megasquirt 3 allows for individual spark trim and I am going to try and isolate the issue to number 6 if that’s the case . Anyways - it’s not as good as real time retard available on ECU’s , but it is very effective to show some limits .
