28
Everything posted by madkaw
Transformed cardboard to aluminum! I’m pretty happy the way this is coming out overall . I think it will accomplish my goal to control the air in front of the car . Found some good seals on McMaster -car to help seal to the hood . Next fun task to integrate the torsion bars and CAI . I’ve been using these metal screws to hold things together and a lot of them will stay except the front panel which I will rivet before paint. Been tossing around where to put the inlet . Might go under the bumper with a 4”x 20” opening . like to hear some ideas I know my neck will be glad when I finish this project .
Someone update my status so I can post in classifieds please!
So are you saying the piston height is different from front to back? Can you rock the piston in the hole ? Stock spec piston height should be above deck .
Thank you - it does matter if I want to sound like I know what I am talking about - lol
I ran the clutch 3.90 before , but going torsion this time. I just bought a used ‘18 myself
Thanks Derek . Sounds like Subaru has been consistent .
Anyone have knowledge of more current years of diffs ??? I’m ready to purchase a torsion 3.54 . A ton on eBay as current as 2020 . They still look like the same casing but want to make sure my stub axles will work on any year .
Well this isn't about my Z , this is about my truck running ms2/3.57. Its a Z2.4 motor that I converted to MS. Everything was pretty good until the frigid temps came along . Anything under 30F and I don't get sync to start. It does light up green as I let off the starter(Which is a newly rebuilt unit) . I have a new battery , new ignition switch also. I am running the same CAS as on my car which is the Cherry Hall gear tooth sensor, running off my flywheel. I have 12v running to it. I have adjusted the pots to 2.5v as I have done before. I've done my best to keep sensor wires away from noise , but I read on the forums that the flash of green letting off the starter could mean noise from the starter. I tried to do a datalog of the tooth logger and forgot to save the file. I'll try it again tomorrow. I did put the battery on the charger overnight. Just trying to get some ideas on how to figure this out. I have a stim board but didn't think I could duplicate the issue on it. CurrentTune.msq
I recently bought both kinds . I couldn’t see a huge difference . I have precisions seals on my Z . The door in particular is just as bad on the both seals . Good luck finding Kia seals - maybe used . Some seals are only available at Vintage . I wanted the 1 piece hatch seal and only vintage had that
Made more progress on the fascia . I think my templates will help me think this out as far as sealing edges and the getting the best look . More than likely the grill won’t go back on. I think I want to bring the top of the fascia out a little , but not much . I need to cut a hole for my breather pipe . Need to find a place for the horns . I don’t plan on having any real framework since I will be using .125 sheet to fab everything .
It’s hardly far enough along to tell what I’m doing , but it will close off the compete grill area . All edges will be sealed with some kind of weatherstrip against the chassis .
Not sure I understand what you are saying. The grill opening will be completely blocked off except a small opening for the radiator . I will shooting to keep air from escaping anywhere around the fascia . all this to say, your idea is not bad but not optimal (if you care). If you do insist on keeping it narrow, I would put a slight angle inward on the sides. Sounds counterintuitive, but this creates a Venturi effect at slower speeds which will actually increase velocity into your rad. Angling outward will cause an eddy current on the sides of the rad support creating drag. Keeping a neutral angle (as you drew) will cause a thin surface to “flap” due to turbulent air flow at speed.
I’m only half done . The front grill area will be completely blocked off except a small opening in the radiator box .
Yep - I’m getting there . This is just the early stages of the project .
I had no idea what forum to post this in because it fits a lot of categories. I am modifying my from grill area to help with cooling and aerodynamics , which will affect the engine also. It’s kind of bodywork too , and some fab and welding . Anywho- here’s some pics of the start of the project . Making use of a huge box that my lawnmower came in to mock up . Goal is make this aerodynamic gain by blocking the air from getting in all the wrong places. Also getting air in the right places for cooling and better engine-temp control. At 75mph cruise I get some buffeting on the front end . I can see the hood doing a little shaking from the air getting under it . And if I get it looking clean I think it will good. Not really a sheet metal guy , but I can bend some aluminum around . I’ve been practicing with my TIG . I suck , but I’m hoping I can make some welds look pretty with some sandpaper-lol.
There is a forum for Megasquirt on this site - which would be a better place for this . I have a thread on there covering MS3x Install. It might help you . You can also put your tune on there to get help I’ll look at your tune tomorrow when I’m on my laptop . Make sure your tooth logger looks good and you don’t have any sync errors
There’s endless threads on this topic . I think you will want wider than 8” wheels to fill the ZG flares .
ZCarDepot Fan Shroud and Mishimoto 12" Fan?
madkaw replied to NorthStar's topic in S30 Series - 240z, 260z, 280z
I’m using the single fan they sell. So far so good with my stroker . I believe it’s a Mishuto also . -
Best option is z car garage axles -$$$$
So this isn’t a re-skin but replacing the complete roof and swap ?
MSA sells Precision . Vintage is not much better when it comes to that issue. Kia seals help solve that issue for me
Let me guess - MSA weatherstrip ?
I believe thats the magic number
Remember -there is no best on Hybridz-lol. I think the P90 is better for exhaust port do allow more flow for a bigger engine build. You would have to cut the P90 100 thou or more to get to the CR of the MN . Valve sizes can be matched up. The MN already has the bigger exhaust valve . My engine runs 44/35. Your right that trying to manage 11:1 might not be worth it. I've been trying to replicate the squish and CR that Brian Blake said he ran -without issues. I wouldn't try unless I was running efi . But with an aluminum head and a modern combustion chamber shape it should do 11:1 without a problem. LS1 is the easy answer for sure .
Long live the MN! I don't know, I think its the best bang for buck performance street head out there . Shaving the P90 just makes a harder turn from port to cylinder. I ran both the P90 shaved and my MN on my stroker. Didn't tell much of a difference . The MN has a slighter higher CR. I didn't dyno the motor with the P90 , but I bet they would have been close . More most builds either would be good with a 3-5CC difference in chamber volume . The ports are not that much bigger on the p90. The liners would only be an issue for the race engines . The liners in early heads(n47) aren't supported as well by the castings as well as the later versions. The MN is a really nice casting with few corrosion issues . I'm no longer running a stock bottom end so my comparisons are not lemons to lemons. Currently at 226 rwhp with a MN and a stock N42 intake. The intake at this point is the limiting factor. I am running 10.75:1 . I think EFI is about an necessity for running on the ragged edge. Blake ran the fuel fat in ping prone areas . Having timing control with knock control helps too. It is good to have some banter over cylinder heads .
